Home » Eclipse Projects » Eclipse Platform » [DataBinding]Bug in ListBinding?
[DataBinding]Bug in ListBinding? [message #329001] Tue, 10 June 2008 06:54 Go to next message
Hi all
In the ListBinding class in the updateModelToTarget and
updateTargetToModel methods the ListDiffs are computed against
Collections.EMPTY_LIST and not against the old content of the underlying
lists. This has the effect that changed entries in the lists are marked as
new entries, added again to the list and in the end these changed entries
are twice in the list.
Is this behaviour intended or is it a bug? If it's a feature how can I
avoid these doubled entries?
Thanks for any help
Daniel
Re: [DataBinding]Bug in ListBinding? [message #329016 is a reply to message #329001] Tue, 10 June 2008 11:28 Go to previous messageGo to next message
Originally posted by: malloovidio.bluewin.ch
Hi Daniel,
have you tried whether you are indeed getting those double entries?
I think this should not happen with the current implementation since
on explicit updates, the target list is always cleared before performing
the update. See the flags passed to the doUpdate(...) method.
Ovidio
Daniel Zweifel wrote:
> Hi all
> underlying lists. This has the effect that changed entries in the lists
> are marked as new entries, added again to the list and in the end these
> changed entries are twice in the list.
> Thanks for any help
> Daniel
Re: [DataBinding]Bug in ListBinding? [message #329036 is a reply to message #329016] Tue, 10 June 2008 16:25 Go to previous messageGo to next message
Daniel,
If Ovidio's response didn't help and you are still seeing double entries,
can you please file a bug (ideally, with a test case or snippet with which
we can reproduce)?
Boris
"Ovidio Mallo" <malloovidio@bluewin.ch> wrote in message
news:g2m6jh$6bf$1@build.eclipse.org...
> Hi Daniel,
> Ovidio
>> Hi all
>> as new entries, added again to the list and in the end these changed
>> Thanks for any help
>> Daniel
Re: [DataBinding]Bug in ListBinding? [message #329045 is a reply to message #329036] Wed, 11 June 2008 03:53 Go to previous messageGo to next message
Hi Boris and Ovidio
Thank you for your answers.
Yes, I really see these double entries whether it is in the wrapped list
in the debugger or in the setter method of the model, they are there.
I will try to make a snippet and file a bug.
Thank you
Daniel
Boris Bokowski wrote:
> Daniel,
> we can reproduce)?
> Thanks
> Boris
>> Hi Daniel,
>> Regards,
>> Ovidio
>>> Hi all
>>> Thanks for any help
>>> Daniel
Re: [DataBinding]Bug in ListBinding? [message #329052 is a reply to message #329045] Wed, 11 June 2008 09:13 Go to previous message
Thanks! You have indeed found a bug - JavaBeanObservableList.clear() did not
have any effect. The fix for this will be in 3.4.1 (sorry - too late for 3.4
unfortunately), but I have described two possible workarounds in bugzilla:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=236605
Boris
"Daniel Zweifel" <daniel.zweifel@adesso.ch> wrote in message
news:b603d063026fcde3bd9b6e6275f412c2$1@www.eclipse.org...
> Hi Boris and Ovidio
> Thank you
> Daniel
>> Daniel,
>> which we can reproduce)?
>> Thanks
>> Boris
>>> Hi Daniel,
>>> Regards,
>>> Ovidio
>>>> Hi all
>>>> Thanks for any help
>>>> Daniel
Previous Topic:.syncinfo file deleted RDZ
Next Topic:Problems with keeping editors opened
Current Time: Wed Apr 16 10:03:28 EDT 2025
Powered by FUDForum. Page generated in 0.03730 seconds
