Exception on debug app? [message #33313] |
Tue, 21 May 2002 14:47  |
Originally posted by: jason.379.com
I was working through the payroll sample, all well and good. However, I am
getting an exception every time I try to launch the debugger, or even
executable the application from the run menu. The log file follows. I also
tried a couple of other small projects, same result. Any assistance much
appreciated.
Jason Perkins
An unexpected exception has been detected in native code outside the VM.
Unexpected Signal : 11 occurred at PC=0x4207a25a
Function name=(N/A)
Library=/usr/java/jdk1.3.1_03/bin/i386/native_threads/java
NOTE: We are unable to locate the function name symbol for the error
just occurred. Please refer to release documentation for possible
reason and solutions.
Current Java thread:
org.eclipse.core.internal.plugins.PluginRegistry.shutdownPlu gins(PluginRegistry.java:255)
org.eclipse.core.internal.plugins.PluginRegistry.shutdown(Pl uginRegistry.java:250)
org.eclipse.core.internal.runtime.InternalPlatform.loaderShu tdown(InternalPlatform.java:531)
at java.lang.reflect.Method.invoke(Native Method)
org.eclipse.core.internal.boot.InternalBootLoader.shutdown(I nternalBootLoader.java:859)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:782)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:319)
at org.eclipse.core.launcher.Main.basicRun(Main.java:190)
at org.eclipse.core.launcher.Main.run(Main.java:549)
at org.eclipse.core.launcher.Main.main(Main.java:390)
Dynamic libraries:
08048000-0804c000 r-xp 00000000 03:03 342450
0804c000-0804d000 rw-p 00003000 03:03 342450
40000000-40013000 r-xp 00000000 03:03 338789 /lib/ld-2.2.5.so
40013000-40014000 rw-p 00013000 03:03 338789 /lib/ld-2.2.5.so
40024000-40025000 r--p 00000000 03:03 48391
/usr/lib/locale/en_US.iso885915/LC_IDENTIFICATION
40025000-40032000 r-xp 00000000 03:03 290411
/lib/i686/libpthread-0.9.so
40032000-40039000 rw-p 0000d000 03:03 290411
4003a000-40043000 r-xp 00000000 03:03 36039
/usr/java/jdk1.3.1_03/jre/lib/i386/native_threads/libhpi.so
40043000-40044000 rw-p 00008000 03:03 36039
40044000-40234000 r-xp 00000000 03:03 2578
/usr/java/jdk1.3.1_03/jre/lib/i386/client/libjvm.so
40234000-40334000 rw-p 001ef000 03:03 2578
4034b000-4034d000 r-xp 00000000 03:03 338802 /lib/libdl-2.2.5.so
4034d000-4034e000 rw-p 00001000 03:03 338802 /lib/libdl-2.2.5.so
4034e000-40360000 r-xp 00000000 03:03 338806 /lib/libnsl-2.2.5.so
40360000-40361000 rw-p 00012000 03:03 338806 /lib/libnsl-2.2.5.so
40363000-40384000 r-xp 00000000 03:03 290409 /lib/i686/libm-2.2.5.so
40384000-40385000 rw-p 00020000 03:03 290409 /lib/i686/libm-2.2.5.so
40386000-403ba000 r-xp 00000000 03:03 371876
/usr/lib/libstdc++-2-libc6.1-1-2.9.0.so
403ba000-403c6000 rw-p 00033000 03:03 371876
403c8000-403d9000 r-xp 00000000 03:03 165091
/usr/java/jdk1.3.1_03/jre/lib/i386/libverify.so
403d9000-403db000 rw-p 00010000 03:03 165091
403db000-403fc000 r-xp 00000000 03:03 165082
/usr/java/jdk1.3.1_03/jre/lib/i386/libjava.so
403fc000-403fe000 rw-p 00020000 03:03 165082
403ff000-40413000 r-xp 00000000 03:03 165092
/usr/java/jdk1.3.1_03/jre/lib/i386/libzip.so
40413000-40416000 rw-p 00013000 03:03 165092
40416000-4114a000 r--s 00000000 03:03 2628
/usr/java/jdk1.3.1_03/jre/lib/rt.jar
41177000-4146e000 r--s 00000000 03:03 2572
/usr/java/jdk1.3.1_03/jre/lib/i18n.jar
4146e000-41484000 r--s 00000000 03:03 2629
/usr/java/jdk1.3.1_03/jre/lib/sunrsasign.jar
41b7b000-41ba6000 r--p 00000000 03:03 48441
/usr/lib/locale/en_US.iso885915/LC_CTYPE
41ba6000-41bac000 r--s 00000000 03:03 242200
/usr/lib/gconv/gconv-modules.cache
41bac000-41bad000 r--p 00000000 03:03 48392
/usr/lib/locale/en_US.iso885915/LC_MEASUREMENT
41bad000-41bae000 r--p 00000000 03:03 48396
/usr/lib/locale/en_US.iso885915/LC_TELEPHONE
41bae000-41baf000 r--p 00000000 03:03 48390
/usr/lib/locale/en_US.iso885915/LC_ADDRESS
41baf000-41bb0000 r--p 00000000 03:03 48394
/usr/lib/locale/en_US.iso885915/LC_NAME
41bb0000-41bb1000 r--p 00000000 03:03 48395
/usr/lib/locale/en_US.iso885915/LC_PAPER
41bb1000-41bb2000 r--p 00000000 03:03 64640
/usr/lib/locale/en_US.iso885915/LC_MESSAGES/SYS_LC_MESSAGES
41bb2000-41bb3000 r--p 00000000 03:03 48393
/usr/lib/locale/en_US.iso885915/LC_MONETARY
41bb3000-41bb9000 r--p 00000000 03:03 48440
/usr/lib/locale/en_US.iso885915/LC_COLLATE
41bb9000-41bba000 r--p 00000000 03:03 48397
/usr/lib/locale/en_US.iso885915/LC_TIME
41bba000-41bbb000 r--p 00000000 03:03 48439
/usr/lib/locale/en_US.iso885915/LC_NUMERIC
41bbb000-41bbf000 r--s 00000000 03:03 19706 /opt/eclipse/startup.jar
41bbf000-41bc3000 r--s 00000000 03:03 293523
/opt/eclipse/plugins/org.eclipse.ant.core/antsupport.jar
41bc3000-41bc4000 r-xp 00000000 03:03 293532
/opt/eclipse/plugins/org.eclipse.core.resources/os/linux/lib core_2_0_5.so
41bc4000-41bc5000 rw-p 00000000 03:03 293532
41bc5000-41bcb000 r-xp 00000000 03:03 196012
/usr/X11R6/lib/libXp.so.6.2
41bcb000-41bcc000 rw-p 00006000 03:03 196012
41bcc000-41bd5000 r-xp 00000000 03:03 338822 /lib/libnss_files-2.2.5.so
41bd5000-41bd6000 rw-p 00009000 03:03 338822 /lib/libnss_files-2.2.5.so
41fd6000-41fe8000 r--s 00000000 03:03 19577
/opt/eclipse/plugins/org.eclipse.core.boot/boot.jar
41fe8000-41fea000 r-xp 00000000 03:03 258984
/usr/X11R6/lib/X11/locale/common/xlcDef.so.2
41fea000-41feb000 rw-p 00001000 03:03 258984
41fec000-41fee000 r-xp 00000000 03:03 242152
/usr/lib/gconv/ISO8859-15.so
41fee000-41fef000 rw-p 00001000 03:03 242152
41fef000-41ff6000 r--s 00000000 03:03 178207
/opt/eclipse/plugins/com.ibm.debug.daemon/daemon.jar
41ff6000-41ff9000 r--s 00000000 03:03 181028
/opt/eclipse/plugins/org.eclipse.cdt.dstore.extra/dstore_ext ra.jar
42000000-4212c000 r-xp 00000000 03:03 290407 /lib/i686/libc-2.2.5.so
4212c000-42131000 rw-p 0012c000 03:03 290407 /lib/i686/libc-2.2.5.so
44135000-4413c000 r-xp 00000000 03:03 195990
/usr/X11R6/lib/libSM.so.6.0
4413c000-4413d000 rw-p 00007000 03:03 195990
4a5ac000-4a5df000 r--s 00000000 03:03 19587
/opt/eclipse/plugins/org.eclipse.core.runtime/runtime.jar
4a5df000-4a884000 r--s 00000000 03:03 309508
/opt/eclipse/plugins/org.eclipse.ui/workbench.jar
4a884000-4aa3d000 r--s 00000000 03:03 197097
/opt/eclipse/plugins/org.apache.xerces/xerces.jar
4aa3d000-4aab6000 r--s 00000000 03:03 293534
/opt/eclipse/plugins/org.eclipse.core.resources/resources.ja r
4aab6000-4aabf000 r-xp 00000000 03:03 258988
/usr/X11R6/lib/X11/locale/common/xomGeneric.so.2
4aabf000-4aac0000 rw-p 00008000 03:03 258988
4aac0000-4aae1000 r--s 00000000 03:03 245442
/opt/eclipse/plugins/org.apache.lucene/lucene-1.2-rc2.jar
4aae1000-4aae9000 r--s 00000000 03:03 245446
/opt/eclipse/plugins/org.apache.lucene/lucenedemo.zip
4ab5f000-4ab6c000 r--s 00000000 03:03 51933
/opt/eclipse/plugins/org.eclipse.jdt.debug/jdi.jar
4ab6c000-4ab7f000 r--s 00000000 03:03 84186
/opt/eclipse/plugins/org.eclipse.jdt.launching/launching.jar
4ab8e000-4abfa000 r--s 00000000 03:03 229423
/opt/eclipse/plugins/org.eclipse.cdt.cpp.ui/cpp_ui.jar
4abfa000-4ad7b000 r--s 00000000 03:03 81055
/opt/eclipse/plugins/com.ibm.lpex/lpex.jar
4ad7b000-4ae4f000 r--s 00000000 03:03 178287
/opt/eclipse/plugins/com.ibm.debug.pdt/ibmdebug.jar
4ae4f000-4ae68000 r--s 00000000 03:03 309653
/opt/eclipse/plugins/org.eclipse.debug.core/dtcore.jar
4ae6c000-4ae89000 r--s 00000000 03:03 293541
/opt/eclipse/plugins/org.eclipse.help/help.jar
4ae89000-4af68000 r--s 00000000 03:03 19593
/opt/eclipse/plugins/org.eclipse.swt/ws/motif/swt.jar
4af68000-4afad000 r-xp 00000000 03:03 19597
/opt/eclipse/plugins/org.eclipse.swt/os/linux/x86/libswt-mot if-2034.so
4afad000-4afb0000 rw-p 00044000 03:03 19597
4afb1000-4b135000 r-xp 00000000 03:03 19707 /opt/eclipse/libXm.so.2.1
4b135000-4b148000 rw-p 00183000 03:03 19707 /opt/eclipse/libXm.so.2.1
4b149000-4b21b000 r-xp 00000000 03:03 195992
/usr/X11R6/lib/libX11.so.6.2
4b21b000-4b21e000 rw-p 000d1000 03:03 195992
4b21e000-4b22a000 r-xp 00000000 03:03 196000
/usr/X11R6/lib/libXext.so.6.4
4b22a000-4b22b000 rw-p 0000c000 03:03 196000
4b22b000-4b273000 r-xp 00000000 03:03 196020
/usr/X11R6/lib/libXt.so.6.0
4b273000-4b277000 rw-p 00047000 03:03 196020
4b277000-4b28b000 r-xp 00000000 03:03 195986
/usr/X11R6/lib/libICE.so.6.3
4b28b000-4b28c000 rw-p 00013000 03:03 195986
4b28e000-4b2a9000 r-xp 00000000 03:03 258983
/usr/X11R6/lib/X11/locale/common/ximcp.so.2
4b2a9000-4b2ab000 rw-p 0001a000 03:03 258983
4b2ab000-4b2e9000 r--s 00000000 03:03 178285
/opt/eclipse/plugins/com.ibm.debug.pdt/epdc.jar
4b2e9000-4b317000 r--s 00000000 03:03 309916
/opt/eclipse/plugins/org.eclipse.search/search.jar
4b317000-4b379000 r--s 00000000 03:03 309738
/opt/eclipse/plugins/org.eclipse.debug.ui/dtui.jar
4b379000-4b38a000 r--s 00000000 03:03 309503
/opt/eclipse/plugins/org.eclipse.core.target/target.jar
4b38a000-4b395000 r--s 00000000 03:03 181036
/opt/eclipse/plugins/org.eclipse.cdt.dstore.miners/dstore_mi ners.jar
4b395000-4b3a9000 r--s 00000000 03:03 258816
/opt/eclipse/plugins/org.eclipse.cdt.cpp.miners/cpp_miners.j ar
4b3a9000-4b3ca000 r--s 00000000 03:03 129687
/opt/eclipse/plugins/org.eclipse.cdt.cpp.miners.parser/miner s_parser.jar
4b3ca000-4b3f3000 r--s 00000000 03:03 97522
/opt/eclipse/plugins/org.eclipse.cdt.dstore.core/dstore_core .jar
4b3f3000-4b40f000 r--s 00000000 03:03 197163
/opt/eclipse/plugins/org.eclipse.cdt.dstore.ui/dstore_ui.jar
4b40f000-4b41c000 r--s 00000000 03:03 326194
/opt/eclipse/plugins/org.eclipse.cdt.dstore.hosts/dstore_hos ts.jar
4b41c000-4b425000 r-xp 00000000 03:03 165089
/usr/java/jdk1.3.1_03/jre/lib/i386/libnet.so
4b425000-4b426000 rw-p 00008000 03:03 165089
4b426000-4b438000 r--s 00000000 03:03 293933
/opt/eclipse/plugins/org.eclipse.cdt.linux.help/linux_help.j ar
4b638000-4b6b3000 r--s 00000000 03:03 19696
/opt/eclipse/plugins/org.eclipse.jdt.debug.ui/jdiui.jar
4b6b3000-4b73f000 r--s 00000000 03:03 51928
/opt/eclipse/plugins/org.eclipse.jdt.debug/jdimodel.jar
4b73f000-4b79c000 r--s 00000000 03:03 309804
/opt/eclipse/plugins/org.eclipse.compare/compare.jar
4cbb3000-4cdc2000 r--s 00000000 03:03 148696
/opt/eclipse/plugins/org.eclipse.jdt.core/jdtcore.jar
4cfc2000-4d24b000 r--s 00000000 03:03 261592
/opt/eclipse/plugins/org.eclipse.jdt.ui/jdt.jar
Local Time = Tue May 21 14:41:46 2002
Elapsed Time = 108
# The exception above was detected in native code outside the VM
# Java VM: Java HotSpot(TM) Client VM (1.3.1_03-b03 mixed mode)
Re: Exception on debug app? [message #33419 is a reply to message #33385] |
Tue, 21 May 2002 16:30  |
Jason Perkins wrote:
> That said, I figured out the problem: I needed to specify the full path
> the program executable. I guess CDT couldn't find the executable, and
> threw an exception as a result.
That indeed happened to me too when I tried to reproduce.
I opened a defect for it:
http://bugs.eclipse.org/bugs/show_bug.cgi?id=16681.
Thanks for the info.
Robert.
PS. If you look at the defect, you will notice that my .log is quite
different from your trace. I am not sure why.
FUDForum. Page generated in 0.11108 seconds
