Home » Eclipse Projects » Eclipse Platform » surcharge the open file
Re: surcharge the open file [message #328943 is a reply to message #328941] |
Sat, 07 June 2008 11:17 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
The problem with the open file action is that you (user) have little
control over which editor is opened. It will just open the default
editor for that file. There are bugzillas open for enhancing this, but
it's a tricky problem because until the file is selected, you can't
really provide reasonable editor choices, and the file open dialog isn't
extensible. Are you designing your own editor? Can you make it the
default for the type of file being opened? I'm not sure you can
override or specialize the open file action...
julien wrote:
> hi all,
> Always trying to make a plugin, I try to open an external file.
> When Launch the plugin I have alwready a open file in file menu but
> when I open a file, I have nothing, just an ERROR message in the editor.
> I would like to know, is there any extensions to overright the
> openfile action or I just have to make a action set call open file
> and the open file in file will diseappear , replaced by mine?
> thanks
> a++
Re: surcharge the open file [message #328944 is a reply to message #328943] |
Sat, 07 June 2008 14:56 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
No real name![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=elekis%40gmail.com) Messages: 64 Registered: July 2009 |
Member |
hi,
yes, and in fact, I try to make a perpective like java (with less stuff)
for a new language. but this thing will be wait.
thanks
a++
Can you make it the
> julien wrote:
>> hi all,
>> thanks
>> a++
Re: surcharge the open file [message #328946 is a reply to message #328944] |
Sat, 07 June 2008 16:24 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
julien,
Keep in mind that if you use file open to open something in the file
system (I wonder if that's actually what you meant), the editor input
won't generally be an IFileEditorInput.
julien wrote:
> hi,
>> but it's a tricky problem because until the file is selected, you
>> can't really provide reasonable editor choices, and the file open
>> dialog isn't extensible. Are you designing your own editor?
> stuff) for a new language. but this thing will be wait.
> thanks
> a++
> Can you make it the
>> julien wrote:
>>> hi all,
>>> editor.
>>> thanks
>>> a++
Re: surcharge the open file [message #328947 is a reply to message #328946] |
Sat, 07 June 2008 17:22 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Member |
Ed Merks a écrit :
> julien,
oki thanks.
> julien wrote:
>> hi,
>> thanks
>> a++
>> Can you make it the
>>> julien wrote:
>>>> hi all,
>>>> editor.
>>>> thanks
>>>> a++
Current Time: Sat Aug 31 23:32:27 GMT 2024
Powered by FUDForum. Page generated in 0.03565 seconds
