Re: Debugging plugin install problems [message #328866 is a reply to message #328850] |
Thu, 05 June 2008 14:38 |
John J Barton wrote:
> On my machine I downloaded eclipse-SDK-3.4RC2-win32 and unzipped it.
> Then I ran eclipse.exe and used the update site to install my plugin.
> Worked great: lots of things happened, then I had my new plugin working.
> Then I had Brave User #1 reproduce this procedure. All good until the
> last step, actually using the new plugin. It does not show up in the
> UI! No pref pages, context menu entries etc.
> The plugin shows up in Window-ShowView->PDE->plugins. There is a
> directory in the plugins/ folder with my stuff. The Error Log has no
> related error messages.
> How can I diagnose this and get it to work?
Start Eclipse with the -debug option (either on the command line or in
eclipse.ini). You probably should use the -clean option, too, to flush
the cache of plugin info. Oh, and run Eclipse with java.exe instead of
javaw.exe, which will give you the system.out/system.err console window
to look at.
Hope this helps,
Eric
FUDForum. Page generated in 0.05380 seconds
