Home » Archived » BIRT » JBoss Deployment
JBoss Deployment [message #328837] Fri, 25 January 2008 20:05 Go to next message
I am looking for a document on what to do to deploy my own BIRT 2.2 test
project report under currently working JBOSS project.
I found a description of deployment but all it says copy birt.war into
deploy directory. But I need to know what BIRT related files are needed
and where, to deploy under currently existing war file.
Alex
Re: JBoss Deployment [message #339372 is a reply to message #328837] Sat, 26 January 2008 02:46 Go to previous messageGo to next message
I've copied a bunch of BIRT related files that seemed to be needed for
JBOSS deployment.
Now when I click a link to my BIRT report(on a page I created to call my
test report) I see an empty screen in browser but there is no any errors
from JBOSS output.
Any suggestions?
Alex
Re: JBoss Deployment [message #339389 is a reply to message #328837] Mon, 28 January 2008 09:37 Go to previous message
I don't know if there's an automatic way to make it happen, but what I did
was to make a copy of BIRT's "ReportEngine" directory inside the config
directory of my JBoss server (so that I wouldn't be redeploying them
whenever I modified my application). I then wrote a bit of code to look up
that directory, using the JBoss ServerConfigImplMBean, and create the
report engine with that path. This is happening within a ReportManager
stateless session bean that then handles report requests by calling into
the engine API.
Things would probably be a lot nicer if BIRT could exist as a service that
was referenced through JNDI, but I'm not that ambitious just now. :-)
Re: JBoss Deployment [message #339447 is a reply to message #328837] Sat, 26 January 2008 02:46 Go to previous message
JBOSS deployment.
from JBOSS output.
Any suggestions?
Alex
Re: JBoss Deployment [message #339464 is a reply to message #328837] Mon, 28 January 2008 09:37 Go to previous message
the engine API.
Previous Topic:JBoss Deployment
Next Topic:JBoss Deployment
Current Time: Wed Apr 16 00:57:12 EDT 2025
Powered by FUDForum. Page generated in 0.03404 seconds
