Home » Eclipse Projects » Eclipse Platform » .syncinfo deleted RDZ
.syncinfo deleted RDZ [message #328743] Tue, 03 June 2008 10:01 Go to next message
1)A Java project is added from a repository to workspace of IBM Rational
Application Developer (RDZ7.0) Eclipse version: 3.1.1
2) Close workspace (do not close the project before closing workspace)
3) Re-open RDZ, use the same workspace try to navigate to the Java project
OBSERVED RESULT
I am getting below error message in the session log:
"Resource - <project name> - is not managed"
I found out that .syncinfo file for that particular project is being
deleted on closing the workspace. Can anybody please tell me why .syncinfo
file is being deleted?
Re: .syncinfo deleted RDZ [message #328744 is a reply to message #328743] Tue, 03 June 2008 10:14 Go to previous message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
The only place I see .syncinfo files are in the workspace's .metadata
area, not in the projects themselves. You are not pointing both of these
Eclipse's at the very same workspace are you? I've shared projects
between workspaces (via import project, though I don't remember if 3.1.1
does that, that's so long ago!) but it is dangerous to share the same
workspace itself between two very different Eclipse's.
srividya wrote:
> Hi
> OBSERVED RESULT
> .syncinfo file is being deleted?
Rich Kulp
Previous Topic:Share data between plugins?
Next Topic:Does this new P2 thing ever work?
Current Time: Fri Apr 25 22:38:02 EDT 2025
Powered by FUDForum. Page generated in 0.02537 seconds
