Re: Does this new P2 thing ever work? [message #328747 is a reply to message #328742] |
Tue, 03 June 2008 10:55  |
Originally posted by: phillipus.nowhere.net
Eric Rizzo wrote:
> Phillipus wrote:
>> Very frustating!
>> Trying out Eclipse 3.4 RC3, thought I'd get GEF using the new update.
>> Impossible:
>> An error occurred while collecting items to be installed
>> Problems downloading artifact:
>> osgi.bundle,org.eclipse.draw2d,3.4.0.v20080401.
>> Exception connecting to
>> http://giano.com.dist.unige.it/eclipse/releases/ganymede/plu gins/org.eclipse.draw2d_3.4.0.v20080401.jar.
> It seems fairly obvious that this is not a site managed by eclipse.org -
> it is a mirror. You should look to see if p2 has any bugs reported about
> what happens if a selected mirror is unavailable; if you don't find one,
> enter your own to suggest that p2 should proceed to another mirror in
> that scenario.
> http://bugs.eclipse.org.bugs
> As you yourself pointed out, this is pre-release software; the only way
> it can get better is for early adopters like yourself to report the
> problems they find. The newsgroups are good for discussion, but are not
> the mechanism by which to report problems so that they get appropriate
> attention.
> Eric
Yes, that's as maybe. If it is failing this close to a final release,
then I think there is something sereiously wrong with the whole P2
business - ie. half baked. My original post is expressed with the
persona of a new user.
FUDForum. Page generated in 0.08059 seconds
