Home » Eclipse Projects » Eclipse Platform » Virtual JFace Viewers - add(Objects[])
Virtual JFace Viewers - add(Objects[]) [message #328703] Mon, 02 June 2008 10:29 Go to next message
Hi there,
I am using Virtual TableViewer. According to
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.jface.s nippets/Eclipse%20JFace%20Snippets/org/eclipse/jface/snippet s/viewers/Snippet029VirtualTableViewer.java?view=markup
it should be possible to have a virtual viewer supporting sorting. The
required condition is to use a StructuredContentProvider and not A Lazy
one.
It seems to work when using the set input method nevertheless I have some
troubles when using the Viewer.add(Objects[] objects) method. According to
this method specification elements should be inserted at the right
position if there is an associated Comparator. In my case elements are
appended at the end of the viewer and the appended elements are not the
good ones : they are "copy" of the existing elements.
Before opening a bugzilla entry and because I think I missed something
from my side I want to know if anybody already encountered such a problem
? Any help / comments / suggestion is welcomed ;o)
Manu
Re: Virtual JFace Viewers - add(Objects[]) [message #328704 is a reply to message #328703] Mon, 02 June 2008 10:33 Go to previous message
Please give me a snippet to test.
Tom
Manuel Selva schrieb:
> Hi there,
> one.
> some troubles when using the Viewer.add(Objects[] objects) method.
> According to this method specification elements should be inserted at
> the right position if there is an associated Comparator. In my case
> elements are appended at the end of the viewer and the appended elements
> are not the good ones : they are "copy" of the existing elements.
> problem ? Any help / comments / suggestion is welcomed ;o)
> Regards
> Manu
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Previous Topic:Can I open several workspaces with one running Eclipse instance
Next Topic:FileTransfer drag and drop (dnd) from remote server to Windows Explorer
Current Time: Tue Apr 29 01:55:50 EDT 2025
Powered by FUDForum. Page generated in 0.07573 seconds
