Home » Eclipse Projects » Eclipse Platform » [Accessibility] Decorations in views not read by Windows Eyes
[Accessibility] Decorations in views not read by Windows Eyes [message #328655] Fri, 30 May 2008 10:18
We're having an issue with the accessibility of the Decorations API.
Specifically, we use this API to append a suffix to a project name. The
problem is encountered when we use WindowsEyes to read the screen - the
project name is read, but not any associated decoration.
Problems also occur in the case of the markers in java editors (warnings,
errors, etc) - WindowsEyes just reads 'Image' and does not read the
associated hover-over text.
This problem occurs not only in our code, but also in base eclipse/JDT
(for example, check a project out from CVS - it will read the project name
but not the CVS repository information). Is there a way around this
problem?
Paul
Previous Topic:jface databinding: bind radio selection to boolean
Next Topic:execute Command from a Property Page
Current Time: Wed Apr 16 01:04:08 EDT 2025
Powered by FUDForum. Page generated in 0.06319 seconds
