Home » Eclipse Projects » Eclipse Platform » Showing two editors (Horizontal or vertical split) programmatically
Showing two editors (Horizontal or vertical split) programmatically [message #328600] Tue, 27 May 2008 18:01
Originally posted by: clandestinesnehal.gmail.com
I have made a graphical editor using GEF and I want to open two editor
instances using horizontal or vertical split, programmatically.
Eclipse workbench says only one editor can be active at a time, but i
can manually open the two editors and lay them one below the other
(using drag ans drop).
I am hoping this should not be a big deal. I am only 2 weeks old to the
eclipse world.
Any help/code will be very useful.
-Snehal
Previous Topic:The default charset setting in plugin.xml doesn't take effect
Next Topic:Showing two editors (Horizontal or vertical split) programmatically
Current Time: Thu Aug 29 12:47:23 GMT 2024
Powered by FUDForum. Page generated in 0.04940 seconds
