Home » Eclipse Projects » Eclipse Platform » Changing bgcolor in Section title bars...
Changing bgcolor in Section title bars... [message #328573] Tue, 27 May 2008 14:44 Go to next message
I'm trying to change the background of a Section's title bar AFTER the
section has been created and painted. I've tried using
setTitleBarBackground(Color) alone and in combination with any number of
other methods I thought might trigger a repaint but was never able to get
the section to repaint itself automatically. The color was never changed
until I interacted with the Section (in my case expand/collapse the
section).
Is there some special mechanism in the forms API I need to call after
changing a color to force a repaint to happen automatically? If so, what
is it?
Re: Changing bgcolor in Section title bars... [message #328660 is a reply to message #328573] Fri, 30 May 2008 11:29 Go to previous messageGo to next message
Anyone?
Re: Changing bgcolor in Section title bars... [message #328661 is a reply to message #328573] Fri, 30 May 2008 11:44 Go to previous messageGo to next message
Did you try asking the section to redraw()?
(not sure if this will work, it's just an idea that I'm too lazy to try
for myself).
Wayne
> section).
> is it?
Re: Changing bgcolor in Section title bars... [message #328662 is a reply to message #328661] Fri, 30 May 2008 12:43 Go to previous messageGo to next message
Yep, tried that...
Re: Changing bgcolor in Section title bars... [message #328665 is a reply to message #328662] Fri, 30 May 2008 13:33 Go to previous message
You said that it updates when you interact with the Section (i.e.
expand/collapse). Try putting a breakpoint on the setExpanded() method
in ExpandableComposite to see what happens when you expand/collapse.
I suspect that one of the layout() or reflow() methods might help.
(again, I've only just quickly glanced at the code, as I'm too lazy to
actually try it myself)
Wayne
On Fri, 2008-05-30 at 16:43 +0000, Jason Woods wrote:
> Yep, tried that...
Previous Topic:Expressions definition iterate/or condition
Next Topic:Binding keys to command sequences?
Current Time: Fri Oct 31 04:36:36 EDT 2025
Powered by FUDForum. Page generated in 1.04245 seconds
