| Export-Package, Package ... does not exist after ant builder. [message #328514] |
Tue, 27 May 2008 01:39  |
--------------030708000200020901040705
Content-Type: text/plain; charset=UTF-8; format=flowed
Greeting Group!
Environment:
OS: Windows Vista
Eclipse SDK : Version: 3.4.0, Build id: I20080516-1333
A have three projects:
1. Plain jar archive, contains one package 'ru.infinet.ObjectManager'
2. Plugin project, created by wizard from existing JAR archive (
Project 1 ), and export this package thru 'Runtime' page in
MANIFEST editor.
3. RCP Application, that uses (plugin Project 2) and classes from
All worked as expected, but I'm added ANT builder to 'Project 2' this
builder simply copy fresh/latest version of jar file from 'Project 1'
into 'Project 2' directory structure and tell to refresh 'project
containing the selected resource'.
Two targets:
1. copy
2. clear
<target name="copy" description="Copy original library">
<copy todir="." file="${original.project.jar}"/>
</target>
<target name="clean" description="Clean project">
<delete file="${jar.file.name}"/>
</target>
Problem is: After 'Clean and build' all ant targets finished with
success status, package explorer contains new version of jar, but IDE
has one error marker
Description: Package 'ru.infinet.ObjectManager' does not exist in this
plug-in
Severity: Error
On element: MANIFEST.MF
In folder: ru.infinet.objectmanager/META-INF
--- MANIFEST.MF ---
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: Objectmanager Plug-in
Bundle-SymbolicName: ru.infinet.objectmanager
Bundle-Version: 1.0.0
Bundle-Vendor: Infinet Wireless Ltd.
Require-Bundle: org.eclipse.core.runtime
Bundle-RequiredExecutionEnvironment: J2SE-1.5
Bundle-ClassPath: ObjectManager.jar
Export-Package: ru.infinet.ObjectManager
Only 'Calculate Uses' button on 'Runtime' page of MANIFEST editor and
'save', removed this Error.
This is a bug? Or how i'm can resolve this situation.
Andrew Nesheret
InfiNet Wireless Ltd.
Content-Type: text/html; charset=UTF-8
<html>
<head>
</head>
Greeting Group!<br>
<br>
Environment:<br>
OS: Windows Vista<br>
Eclipse SDK : Version: 3.4.0, Build id: I20080516-1333<br>
<br>
A have three projects:<br>
<ol>
<li>Plain jar archive, contains one package 'ru.infinet.ObjectManager'<br>
</li>
<li>Plugin project, created by wizard from existing JAR archive (
Project 1 ), and export this package thru 'Runtime' page in MANIFEST
editor.<br>
</li>
<li>RCP Application, that uses (plugin Project 2) and classes from
package 'ru.infinet.ObjectManager'</li>
</ol>
containing the selected resource'.<br>
<br>
Two targets:<br>
<ol>
<li>copy</li>
<li>clear</li>
</ol>
~~~~~~~~~~~~~~~~~~~~~~<br>
<tt> <target name="copy" description="Copy original library"><br>
<copy todir="." file="${original.project.jar}"/><br>
</target><br>
<target name="clean" description="Clean project"><br>
<delete file="${jar.file.name}"/><br>
</target><br>
<br>
</tt>Problem is: After 'Clean and build' all ant targets finished with
has one error marker<br>
plug-in<br>
Severity: Error<br>
On element: MANIFEST.MF<br>
In folder: ru.infinet.objectmanager/META-INF<br>
<br>
<tt>--- </tt>MANIFEST.MF <tt>---<br>
Manifest-Version: 1.0<br>
Bundle-ManifestVersion: 2<br>
Bundle-Name: Objectmanager Plug-in<br>
Bundle-SymbolicName: ru.infinet.objectmanager<br>
Bundle-Version: 1.0.0<br>
Bundle-Vendor: Infinet Wireless Ltd.<br>
Require-Bundle: org.eclipse.core.runtime<br>
Bundle-RequiredExecutionEnvironment: J2SE-1.5<br>
Bundle-ClassPath: ObjectManager.jar<br>
Export-Package: ru.infinet.ObjectManager<br>
~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~<br>
<br>
</tt>Only 'Calculate Uses' button on 'Runtime' page of MANIFEST editor
and 'save', removed this Error.<br>
This is a bug? Or how i'm can resolve this situation.<br>
<br>
<pre class="moz-signature" cols="72">--
Andrew Nesheret
</pre>
</body>
</html>
--------------030708000200020901040705--
| Re: Export-Package, Package ... does not exist after ant builder. [message #328603 is a reply to message #328514] |
Wed, 28 May 2008 01:20   |
UP!
Environment:
OS: Windows Vista
Project 1 ), and export this package on 'Runtime' page in MANIFEST editor.
Two targets:
1. copy
2. clean
</target>
</target>
plug-in.
Severity: Error
--- MANIFEST.MF ---
Any idea? Now to automatically resolve this issue?
Andrew Nesheret
FUDForum. Page generated in 0.04083 seconds
