Home » Eclipse Projects » Eclipse Platform » [HELP] add template formatting in javaeditor exemple(always)
[HELP] add template formatting in javaeditor exemple(always) [message #328500] Mon, 26 May 2008 13:34 Go to next message
hi all
always trying to put template formatting (grrrrr, I lost my mind), I
decided to put that on the
java editor example and surprise,... that doesnt work.
What I ve done is
in the TemplatesPreferencePage I added
private String FORMATTER_PREFERENCE_KEY = "my.formatter.preference.key";
protected String getFormatterPreferenceKey() {
return FORMATTER_PREFERENCE_KEY;
protected boolean isShowFormatterSetting() {
return true;
and that add the button in the preference page (and sauvegarde it). but
that doesn't change anything in the editor.
in the XMLConfiguration I put the following code
public IAutoEditStrategy[] getAutoEditStrategies(
ISourceViewer sourceViewer, String contentType) {
return new IAutoEditStrategy[]{new
DefaultIndentLineAutoEditStrategy() };
and that doesn't anything.
in fact, the getAutoEditStrategies serve to nothing. iether the
getAutoEditStrategies is implemented or not, I have the indented line .
So if there any otherthing to implement to get the templtate formatting.
thanks
a+++
Re: [HELP] add template formatting in javaeditor exemple(always) [message #328637 is a reply to message #328500] Thu, 29 May 2008 04:53 Go to previous messageGo to next message
julien wrote:
> hi all
Surprise. This is only the preference. You have to read that preference
and then do the formatting yourself.
Dani
> What I ve done is
> return true;
> but that doesn't change anything in the editor.
> thanks
> a+++
Re: [HELP] add template formatting in javaeditor exemple(always) [message #328948 is a reply to message #328637] Sat, 07 June 2008 13:26 Go to previous message
Daniel Megert a écrit :
> julien wrote:
>> hi all
sorry for the time response, but make two things in a same time is not a
good idea.
So ok, I have to make the indent myself but where???
I ll suppose I have two do that in the subclasses of
TemplateCompletionProcessor
but is there any methods who do specialy that or have to do that in the
protected Template[] getTemplates(String contextTypeId) {}
thnaks
a+++
> Dani
>> What I ve done is
>> return true;
>> return new
>> thanks
>> a+++
Previous Topic:surcharge the open file
Next Topic:IProjectNature.configure never called when project is created with nature
Current Time: Mon Dec 01 11:35:22 EST 2025
Powered by FUDForum. Page generated in 0.03668 seconds
