Home » Eclipse Projects » Eclipse Platform » how to use databinding to bind dynamic data
how to use databinding to bind dynamic data [message #328356] Thu, 22 May 2008 22:44 Go to next message
I am using jface databinding feature to bind between GUI objects and model
objects. When the GUI is created, the DataBindingContext is used to bind
GUI objects and model. During the operation of the application, the model
data might be changed (model structure is not changed.). How could I use
DataBindingContext to re-bind the GUI objects to the changed model data.
Re: how to use databinding to bind dynamic data [message #328357 is a reply to message #328356] Fri, 23 May 2008 01:11 Go to previous messageGo to next message
> model objects. When the GUI is created, the DataBindingContext is used
> to bind GUI objects and model. During the operation of the application,
> the model data might be changed (model structure is not changed.). How
> could I use DataBindingContext to re-bind the GUI objects to the changed
> model data.
Your objects have expose an observer pattern in your model API, and use
an IObservable tailored to use that specific observer pattern.
Currently there are two options supported by Eclipse:
* Implement the official bean specification, and use BeansObservables to
observe bean properties.
* Implement model objects using EMF, and use EMFObservables to observe
EStructuralFeatures.
I'm not very familiar with EMF so I won't be much help there. However
with the bean spec there are just a few methods required:
public void addPropertyChangeListener(PropertyChangeListener listener)
public void removePropertyChangeListener(PropertyChangeListener listener)
public void addPropertyChangeListener(String propertyName,
public void removePropertyChangeListener(String propertyName,
This is commonly implemented using by extending a superclass such as
ModelObject as you have seen in the examples. The common pattern I use
in my setter methods is:
public void setName(String name) {
firePropertyChange("name", this.name, this.name = name);
Hope this helps,
Matthew
Re: how to use databinding to bind dynamic data [message #328363 is a reply to message #328357] Fri, 23 May 2008 06:19 Go to previous messageGo to next message
Let me explain what I am trying to ask:
For example, I have a model called Contact which has a name attribute. The
name field of the Contact is binded to a GUI text field called nameText.
When the GUI class is constructed, the following is called:
private Contact contact;
private Text nameText;
private DataBindingContext bindingContext;
//In constructor
IObservableValue contactNameObserveValue =
BeansObservables.observeValue(contact, "name");
IObservableValue nameTextTextObserveWidget =
SWTObservables.observeText(nameText, SWT.Modify);
bindingContext.bindValue(nameTextTextObserveWidget,
contactNameObserveValue, null, null);
For some reason, during the operation of the application, the contact
object is replaced with a new contact object. (Not the property name of
the contact object is changed but contact object itself is changed.) How
could I rebind the newly created contact object to nameText object?
thanks!
Re: how to use databinding to bind dynamic data [message #328364 is a reply to message #328363] Fri, 23 May 2008 06:35 Go to previous messageGo to next message
WritableValue v = new WritableValue(Contact.class);
BeansObservable.observeDetailValue(v,"name");
v.setValue(new Contact());
So in fact this is a master-detail problem :-)
Tom
> The name field of the Contact is binded to a GUI text field called
> nameText. When the GUI class is constructed, the following is called:
> //In constructor
> thanks!
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: how to use databinding to bind dynamic data [message #328370 is a reply to message #328364] Fri, 23 May 2008 09:06 Go to previous messageGo to next message
Can I use bindingContext.updateTargets() method to realize it?
Re: how to use databinding to bind dynamic data [message #328372 is a reply to message #328370] Fri, 23 May 2008 09:16 Go to previous message
You don't use updateTargets().
wv = new WritableValue(Contact.class);
wv.setValue(new Contact());
// ..... work
Tom
Previous Topic:Problems building a plugin after changing to Eclipse SDK download
Next Topic:Problem while accessing db2 from plugin project
Current Time: Wed Oct 15 05:53:00 EDT 2025
Powered by FUDForum. Page generated in 0.05007 seconds
