Why is it needed for java bean to implement property change support [message #328349] |
Thu, 22 May 2008 15:49 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hao Missing name![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=d95776%40yahoo.com) Messages: 115 Registered: July 2009 |
jface databinding framwork has provided a lot of help classes, such as
BeansObservables and WritableValue. Why is it still needed for java bean
to implement property change support, such as
public class Message extends ModelObject {
public class ModelObject {
private final PropertyChangeSupport propertyChangeSupport = new
PropertyChangeSupport(
this);
public void addPropertyChangeListener(PropertyChangeListener listener) {
propertyChangeSupport.addPropertyChangeListener(listener);
public void addPropertyChangeListener(String propertyName,
propertyChangeSupport.addPropertyChangeListener(propertyName , listener);
public void removePropertyChangeListener(PropertyChangeListener listener)
propertyChangeSupport.removePropertyChangeListener(listener) ;
public void removePropertyChangeListener(String propertyName,
propertyChangeSupport.removePropertyChangeListener(propertyN ame,
listener);
protected void firePropertyChange(String propertyName, Object oldValue,
Object newValue) {
propertyChangeSupport.firePropertyChange(propertyName, oldValue,
newValue);
protected void fireIndexedPropertyChange(String propertyName, int index,
Object oldValue, Object newValue) {
propertyChangeSupport.fireIndexedPropertyChange( propertyName, index,
oldValue, newValue);
[DataBinding] Re: Why is it needed for java bean to implement property change support [message #328351 is a reply to message #328349] |
Thu, 22 May 2008 16:19 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
In Eclipse 3.4, there is a new class,
org.eclipse.core.databinding.beans.PojoObservables, that supports
creating observables on objects that do not fire property change events.
The limitation, of course, is that the framework isn't notified if the
underlying objects are changed directly - that's what the property
change events provide. So if your model objects don't do that they can't
tell the data binding framework when their properties have changed.
Hope this helps,
Eric
FUDForum. Page generated in 0.03813 seconds
