Home » Eclipse Projects » Eclipse Platform » Binding the attribute of a bean object wrapped in a WritableValue object
Binding the attribute of a bean object wrapped in a WritableValue object [message #328347] Thu, 22 May 2008 10:58 Go to next message
I have a java bean such as Contact which has attributes such as name,
address, email. The object presented to my code is a Wrapped WritableValue
object, i.e. IObservableValue.
For instance,
IObservableValue contactObservable = new WritableValue(new Contact(),
Contact.class);
I tried to bind the name attributed of Contact bean wrapped in
contactObservable to a text field. I did the following:
IObservableValue bindedNameTextObserveWidget =
SWTObservables.observeText(text);
IObservableValue selectedContactNameObserveDetailValue =
BeansObservables.observeDetailValue(Realm.getDefault(), contactObservable,
"name", java.lang.String.class);
bindingContext.bindValue(bindedNameTextObserveWidget, contactObservable,
null, null);
I did not get any error but this kind of binding does not work.
Any one knows how to bind the attribute of a writableValue object to a gui
field instead of binding the attribute of a java bean to a gui field.
[DataBinding] Re: Binding the attribute of a bean object wrapped in a WritableValue object [message #328348 is a reply to message #328347] Thu, 22 May 2008 12:22 Go to previous messageGo to next message
> contactObservable, "name", java.lang.String.class);
> contactObservable, null, null);
It looks like you're binding to the wrong observable. You have:
bindingContext.bindValue(bindingNameTextObserveWidget,
contactObservable, // <-- wrong observable
null,
null);
But I think it should be:
selectedContactNameObserveDetailValue,
null,
null);
Matthew
Re: [DataBinding] Re: Binding the attribute of a bean object wrapped in a WritableValue object [message #328352 is a reply to message #328348] Thu, 22 May 2008 16:02 Go to previous messageGo to next message
You are right. It is a typo. But it still does not work.
Re: Binding the attribute of a bean object wrapped in a WritableValue object [message #328367 is a reply to message #328347] Fri, 23 May 2008 07:37 Go to previous messageGo to next message
Originally posted by: malloovidio.bluewin.ch
Hi Hao,
are you binding the "name" attribute to an SWT Text instance (and not
a Label or so)? If so, SWTObservables#observeText(Control) is the wrong
method as it does not apply to Text instances. Instead, you should use
the method SWTObservables#observeText(Control, int). In the methods'
JavaDoc you can see which controls are supported by the individual
methods.
However, using the wrong method above should result in an exception being
thrown so maybe this is not your problem...
Ovidio
> WritableValue object, i.e. IObservableValue. For instance,
> Contact.class);
> gui field instead of binding the attribute of a java bean to a gui field.
Re: Binding the attribute of a bean object wrapped in a WritableValue object [message #328393 is a reply to message #328367] Fri, 23 May 2008 15:04 Go to previous message
That could be the problem. Try this:
SWTObservables.observeText(text, SWT.Modify);
Matthew
Ovidio Mallo wrote:
> Hi Hao,
> methods.
> Ovidio
>> Contact.class);
Previous Topic:Cannot add problem marker to project in custom classpath container code
Next Topic:classes appearing twice in my plugin
Current Time: Wed Nov 05 02:04:05 EST 2025
Powered by FUDForum. Page generated in 0.05298 seconds
