Home » Eclipse Projects » Eclipse Platform » TableViewerColume and editing
Re: TableViewerColume and editing [message #328301 is a reply to message #328275] |
Wed, 21 May 2008 07:46 |
Carmelo Messages: 224 Registered: July 2009 |
Hi Tom ... it doesn't work ... can u help me ... please.
Ciao
Kar
protected TableViewer createViewer(Composite parent)
TableViewer viewer = new TableViewer(parent, SWT.H_SCROLL |
SWT.V_SCROLL | SWT.BORDER
| SWT.VIRTUAL | SWT.FULL_SELECTION);
viewer.setUseHashlookup(true);
Table table = viewer.getTable();
// Turn on the header and the lines
table.setHeaderVisible(true);
table.setLinesVisible(true);
initContentProvider(viewer);
initLabelProvider(viewer);
return viewer;
private void initLabelProvider(TableViewer viewer)
TableViewerColumn column = new TableViewerColumn(viewer, SWT.NONE);
column.setLabelProvider(new NameLabelProvider(viewer));
column.setEditingSupport(new NameEditing(viewer));
column.getColumn().setWidth(200);
column.getColumn().setText("Name");
column.getColumn().setMoveable(true);
column.setLabelProvider(new SizeLabelProvider());
column.getColumn().setWidth(150);
column.getColumn().setText("Size");
column.setLabelProvider(new TypeLabelProvider());
column.getColumn().setWidth(100);
column.getColumn().setText("Type");
column.setLabelProvider(new LockedByLabelProvider());
column.getColumn().setText("Locked by");
column.setLabelProvider(new StatusLabelProvider());
column.getColumn().setText("Status");
ColumnViewerEditorActivationStrategy actSupport = new
ColumnViewerEditorActivationStrategy(
viewer)
protected boolean
isEditorActivationEvent(ColumnViewerEditorActivationEvent event)
return event.eventType ==
ColumnViewerEditorActivationEvent.TRAVERSAL
|| event.eventType ==
ColumnViewerEditorActivationEvent.MOUSE_DOUBLE_CLICK_SELECTI ON
|| (event.eventType ==
ColumnViewerEditorActivationEvent.KEY_PRESSED && event.keyCode == SWT.CR)
|| event.eventType ==
ColumnViewerEditorActivationEvent.PROGRAMMATIC;
TableViewerEditor.create(viewer, actSupport,
ColumnViewerEditor.TABBING_HORIZONTAL
| ColumnViewerEditor.TABBING_MOVE_TO_ROW_NEIGHBOR
| ColumnViewerEditor.TABBING_VERTICAL
| ColumnViewerEditor.KEYBOARD_ACTIVATION);
TableViewerEditor.create(viewer, new
ColumnViewerEditorActivationStrategy(viewer)
protected boolean
System.out.println("here ..." + event.keyCode);
return event.keyCode == SWT.F2;
}, ColumnViewerEditor.TABBING_HORIZONTAL
| ColumnViewerEditor.TABBING_VERTICAL |
"Tom Schindl" <tom.schindl@bestsolution.at> ha scritto nel messaggio
news:g0ushv$fk$1@build.eclipse.org...
> No you don't need the highlighter. It should work without it.
> Tom
> KarSc schrieb:
>> I did found the example but I was using the TableViewerEditor.create
>> without the focus cell manager ...
>> guess without doesn't work ...
>> but where do I get the FocusBorderCellHighlighter is it part of 3.4Mx?
>> thanks
>> news:g0uqvq$dvn$1@build.eclipse.org...
>>> Take a look at this snippet
>>> http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.jface.s nippets/Eclipse%20JFace%20Snippets/org/eclipse/jface/snippet s/viewers/Snippet044NoColumnTableViewerKeyboardEditing.java? view=markup
>>> Tom
>>> KarSc schrieb:
>>>> Hi Tom thanks for ur help but still not able to let table works as I
>>>> want ...
>>>> I'm sure I'm using the ColumnViewerEditorActionStrategy class in a
>>>> wrong way ...
>>>> here is my code ... what have I done wrong (the class is not called)
>>>> thanks
>>>> Kar
>>>> SWT.NONE);
>>>> new ColumnViewerEditorActivationStrategy(viewer)
>>>> @Override
>>>> protected boolean
>>>> news:g0unt8$hd3$1@build.eclipse.org...
>>>>> Sure. You'll have to tweak your ColumnViewerEditorActivationStrategy
>>>>> and only allow editor activation on PROGRAMMATIC and TABBING Events.
>>>>> Afterwards you activate an editor using TableViewer#editElement() to
>>>>> fire up the editor on keypress.
>>>>> Tom
>>>>> KarSc schrieb:
>>>>>> Hi all
>>>>>> I'm using TableViewerColum to set label provider and editing support
>>>>>> for my table viewer. (see snippet 19 about new api)
>>>>>> What I find annoying is that each time the cursor goes on the
>>>>>> editable cell immediately the cell goes in editing . is there any way
>>>>>> to stop this behaviors and use F2 (via keylistener to fire the
>>>>>> editing) or a rename action from the context menu?
>>>>>> Thanks
>>>>>> Kar
>>>>> B e s t S o l u t i o n . at
>>>>> Tom Schindl JFace-Committer
Re: TableViewerColume and editing [message #328303 is a reply to message #328275] |
Wed, 21 May 2008 08:20 |
Messaggio multiparte in formato MIME.
------=_NextPart_000_002C_01C8BB2C.58BBD8C0
Content-Type: text/plain;
charset="iso-8859-1"
sorry I forgot to remove the comment bit ...
TableViewerColumn column =3D new TableViewerColumn(viewer, =
SWT.NONE);
column =3D new TableViewerColumn(viewer, SWT.NONE);
ColumnViewerEditorActivationStrategy actSupport =3D new =
viewer)
protected boolean =
return event.eventType =3D=3D =
|| (event.eventType =3D=3D =
ColumnViewerEditorActivationEvent.KEY_PRESSED && event.keyCode =3D=3D =
SWT.F2)
=20
Content-Type: text/html;
<HTML><HEAD>
charset=3Dunicode">
<META content=3D"MSHTML 6.00.6000.16587" name=3DGENERATOR></HEAD>
<BODY id=3DMailContainerBody=20
style=3D"PADDING-RIGHT: 10px; PADDING-LEFT: 10px; PADDING-TOP: 15px"=20
bgColor=3D#ffffff leftMargin=3D0 topMargin=3D0 CanvasTabStop=3D"true"=20
name=3D"Compose message area"><FONT face=3DCalibri size=3D2>sorry I =
forgot to remove=20
the comment bit ...<BR><BR><BR> private void =
initLabelProvider(TableViewer=20
viewer)<BR> =
{<BR> =20
TableViewerColumn column =3D new TableViewerColumn(viewer,=20
SWT.NONE);<BR> =20
column.setLabelProvider(new=20
NameLabelProvider(viewer));<BR> =
=20
column.setEditingSupport(new=20
NameEditing(viewer));<BR> =20
column.getColumn().setWidth(200);<BR> =
=20
column.getColumn().setText("Name");<BR> &nbs=
p; =20
column.getColumn().setMoveable(true);<BR><BR> &nbs=
p; =20
SWT.NONE);<BR> =20
SizeLabelProvider());<BR> =20
column.getColumn().setWidth(150);<BR> =
=20
column.getColumn().setText("Size");<BR> &nbs=
p; =20
p; =20
SWT.NONE);<BR> =20
TypeLabelProvider());<BR> =20
column.getColumn().setWidth(100);<BR> =
=20
column.getColumn().setText("Type");<BR> &nbs=
p; =20
p; =20
SWT.NONE);<BR> =20
LockedByLabelProvider());<BR> =20
=20
column.getColumn().setText("Locked=20
by");<BR> =20
p; =20
SWT.NONE);<BR> =20
StatusLabelProvider());<BR> =20
=20
column.getColumn().setText("Status");<BR> &n=
bsp; =20
p; =20
ColumnViewerEditorActivationStrategy actSupport =3D new=20
ColumnViewerEditorActivationStrategy(<BR> &n=
bsp; &n bsp; =20
viewer)<BR> =20
{<BR> =20
protected boolean =
isEditorActivationEvent(ColumnViewerEditorActivationEvent=20
event)<BR> &nb=
sp;=20
{<BR> &n=
bsp; =20
return event.eventType =3D=3D=20
ColumnViewerEditorActivationEvent.TRAVERSAL<BR> &n=
bsp; &n bsp; &n b=
sp; &nb sp;=20
ColumnViewerEditorActivationEvent.MOUSE_DOUBLE_CLICK_SELECTI ON <BR> &=
nbsp; & nbsp; & n=
bsp; &n bsp; =20
|| (event.eventType =3D=3D ColumnViewerEditorActivationEvent.KEY_PRESSED =
&&=20
event.keyCode =3D=3D=20
SWT.F2)<BR> &n=
bsp; &n bsp; &n b=
sp;=20
ColumnViewerEditorActivationEvent.PROGRAMMATIC;<BR> &nbs=
p; &nbs p; =20
}<BR> =20
};<BR><BR> =20
TableViewerEditor.create(viewer,=20
actSupport,<BR> &nbs=
p; =20
ColumnViewerEditor.TABBING_HORIZONTAL<BR> &n=
bsp; &n bsp; &n b=
sp; =20
|=20
ColumnViewerEditor.TABBING_MOVE_TO_ROW_NEIGHBOR<BR> &nbs=
p; &nbs p; &nbs p=
;   ; =20
|=20
ColumnViewerEditor.TABBING_VERTICAL<BR> &nbs=
p; &nbs p; &nbs p=
; =20
|=20
ColumnViewerEditor.KEYBOARD_ACTIVATION);<BR><BR> &=
nbsp; =20
<BR> }</FONT></BODY></HTML>
------=_NextPart_000_002C_01C8BB2C.58BBD8C0--
Re: TableViewerColume and editing [message #328304 is a reply to message #328301] |
Wed, 21 May 2008 08:22 |
Thomas Schindl Messages: 6651 Registered: July 2009 |
Ah I see you have multiple columns. I thought you have only one column
and do the activation always using TableViewer#editElement(). In this
case you need a the SWTCellFocusManager like it is shown in [1]. Of
course you'll need to replace TreeViewerCellFocusManager through
TableViewerCellFocusManager the rest is the same.
Because your columns are moveable you'll have to use JFace 3.4 because
we had bugs in the case in 3.3.
Tom
[1] http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.jface.s nippets/Eclipse%20JFace%20Snippets/org/eclipse/jface/snippet s/viewers/Snippet026TreeViewerTabEditing.java?view=markup
> Ciao
> Kar
> return viewer;
> viewer)
> protected boolean
> || event.eventType ==
> || (event.eventType ==
> || event.eventType ==
> @Override
> protected boolean
>> Tom
>>> thanks
>>>> Tom
>>>>> I want ...
>>>>> wrong way ...
>>>>> called) ???
>>>>> thanks
>>>>> Kar
>>>>> SWT.NONE);
>>>>> @Override
>>>>> protected boolean
>>>>> messaggio news:g0unt8$hd3$1@build.eclipse.org...
>>>>>> ColumnViewerEditorActivationStrategy and only allow editor
>>>>>> activation on PROGRAMMATIC and TABBING Events. Afterwards you
>>>>>> activate an editor using TableViewer#editElement() to fire up the
>>>>>> editor on keypress.
>>>>>> Tom
>>>>>> KarSc schrieb:
>>>>>>> Hi all
>>>>>>> support for my table viewer. (see snippet 19 about new api)
>>>>>>> way to stop this behaviors and use F2 (via keylistener to fire
>>>>>>> the editing) or a rename action from the context menu?
>>>>>>> Thanks
>>>>>>> Kar
Re: TableViewerColume and editing [message #328309 is a reply to message #328304] |
Wed, 21 May 2008 11:26 |
I see ... thanks for ur help ... but right now I cannot move to use 3.4 so
guess I will use the old celleditor
:-) many thanks tom
Ciao
news:g10m3o$17s$1@build.eclipse.org...
> Ah I see you have multiple columns. I thought you have only one column and
> do the activation always using TableViewer#editElement(). In this case you
> need a the SWTCellFocusManager like it is shown in [1]. Of course you'll
> Because your columns are moveable you'll have to use JFace 3.4 because we
> Tom
>> Ciao
>> Kar
>> return viewer;
>> SWT.NONE);
>> viewer)
>> protected boolean
>> || event.eventType ==
>> || (event.eventType ==
>> || event.eventType ==
>> @Override
>> protected boolean
>>> Tom
>>>> thanks
>>>>> Tom
>>>>>> want ...
>>>>>> wrong way ...
>>>>>> thanks
>>>>>> Kar
>>>>>> SWT.NONE);
>>>>>> @Override
>>>>>> protected boolean
>>>>>>> Tom
>>>>>>> KarSc schrieb:
>>>>>>>> Hi all
>>>>>>>> way to stop this behaviors and use F2 (via keylistener to fire the
>>>>>>>> Thanks
>>>>>>>> Kar
Re: TableViewerColume and editing [message #328311 is a reply to message #328309] |
Wed, 21 May 2008 11:46 |
Well at least you can avoid the single click activation because this
doesn't need a focus manager, only keyboard activation needs to know
which cell holds the focus to activate the appropriate one. Activation
on double click doesn't need it because it knows which cell the user
clicked.
Tom
> so guess I will use the old celleditor
> :-) many thanks tom
> Ciao
>> Tom
>>> Ciao
>>> Kar
>>> return viewer;
>>> SWT.NONE);
>>> viewer)
>>> protected boolean
>>> || event.eventType ==
>>> || (event.eventType ==
>>> SWT.CR)
>>> || event.eventType ==
>>> @Override
>>> protected boolean
>>>> Tom
>>>>> TableViewerEditor.create without the focus cell manager ...
>>>>> thanks
>>>>> messaggio news:g0uqvq$dvn$1@build.eclipse.org...
>>>>>> Tom
>>>>>>> as I want ...
>>>>>>> a wrong way ...
>>>>>>> called) ???
>>>>>>> thanks
>>>>>>> Kar
>>>>>>> SWT.NONE);
>>>>>>> @Override
>>>>>>> protected boolean
>>>>>>>> Tom
>>>>>>>> KarSc schrieb:
>>>>>>>>> Hi all
>>>>>>>>> any way to stop this behaviors and use F2 (via keylistener to
>>>>>>>>> fire the editing) or a rename action from the context menu?
>>>>>>>>> Thanks
>>>>>>>>> Kar
>>>>>>>> Tom Schindl
>>>>>>>> JFace-Committer
Current Time: Sun Oct 06 13:13:50 GMT 2024
Powered by FUDForum. Page generated in 0.03968 seconds
