Home » Eclipse Projects » Eclipse Platform » Plugin binary folder cause dependent plugins export to fail
Plugin binary folder cause dependent plugins export to fail [message #328255] Tue, 20 May 2008 11:53 Go to next message
Frederic Conrotte is currently offline Frederic ConrotteFriend
Dear all,
I have plugin A which
- contains some classes in folder classes/
- expose them to other plugins using Export-Packages statement
- has the classes on its classpath as "class folder"
In the workspace, plugin B imports those classes and use them, no issue.
Now if I try to export plugin B as "deployable plugin", PDE fails to
build Plugin B because it cannot resolves binary classes for plugin A.
Plugin B export works only if binary classes are packaged as JAR in
plugin A.
I found a trace of the issue on news.eclipse.tools in 2001 :
http://dev.eclipse.org/newslists/news.eclipse.tools/msg03906 .html
I failed to find corresponding issue in Bugzilla, is it a known bug ?
Frederic
Re: Plugin binary folder cause dependent plugins export to fail [message #328258 is a reply to message #328255] Tue, 20 May 2008 12:07 Go to previous messageGo to next message
Frederic,
I wonder what your build.properties for A looks like? In particular, I
wonder if you've properly specified to include the classes folder int he
binary result.
Frederic Conrotte wrote:
> Dear all,
> plugin A.
> Frederic
Re: Plugin binary folder cause dependent plugins export to fail [message #328259 is a reply to message #328258] Tue, 20 May 2008 12:40 Go to previous messageGo to next message
Ed,
Thanks for your answer.
Plugin A is about exposing javax.transaction classes to other OSGi bundles.
classes are contained in javax/transaction and javax/transaction/xa folders
Basically yes plugin A list the classes folder in "bin.includes"
bin.includes = META-INF/,\
javax/
Plugin A .classpath file expose binary classes from its root:
<classpathentry exported="true" kind="lib" path=""/>
Am I missing something ?
Frederic
Ed Merks a écrit :
> Frederic,
> binary result.
>> Dear all,
>> plugin A.
>> Frederic
Re: Plugin binary folder cause dependent plugins export to fail [message #328260 is a reply to message #328259] Tue, 20 May 2008 12:59 Go to previous messageGo to next message
Frederic,
Comments below.
> Ed,
> bundles.
> folders
> javax/
Do you have a javax folder in your project's root? What does your
BundleClassPath looks like in the MANIFEST.MF?
Have you been fiddling directly with the project's Properties...? When
building plugins, all changes to the classpath should be done by editing
the MANIFEST.MF not via the project's properties..
> Frederic
> Ed Merks a écrit :
>> Frederic,
>> I wonder if you've properly specified to include the classes folder
>> int he binary result.
>>> Dear all,
>>> issue.
>>> plugin A.
>>> Frederic
Re: Plugin binary folder cause dependent plugins export to fail [message #328261 is a reply to message #328260] Tue, 20 May 2008 13:11 Go to previous messageGo to next message
Ed,
Answers below as well.
FYI I'm using Eclipse 3.3.1
Frederic
Ed Merks a écrit :
> Frederic,
> Comments below.
>> Ed,
>> bundles.
>> folders
>> javax/
Yes I do
> What does your BundleClassPath looks like in the MANIFEST.MF?
It includes only the plugin's root (I think it could even be skipped as
it's added by default)
Manifest-Version: 1.0
Ant-Version: Apache Ant 1.7.0
Created-By: 1.5.0_12-b04 (Sun Microsystems Inc.)
Bundle-Name: Java Transaction API
Bundle-ClassPath: .
Bundle-ManifestVersion: 2
Bundle-SymbolicName: javax.transaction
Export-Package: javax.transaction;version="1.0.1",javax.transaction.xa
;version="1.0.1"
Bundle-Version: 1.0.1.200805201053
I used the Manifest editor.
>> Frederic
>> Ed Merks a écrit :
>>> Frederic,
>>>> Dear all,
>>>> issue.
>>>> plugin A.
>>>> Frederic
Re: Plugin binary folder cause dependent plugins export to fail [message #328266 is a reply to message #328261] Tue, 20 May 2008 14:42 Go to previous messageGo to next message
--------------080905000301010303090103
Frederic,
I expect your .classpath to look like this:
<classpath>
<classpathentry kind="src" path="src/"/>
<classpathentry kind="con"
path=" org.eclipse.jdt.launching.JRE_CONTAINER/org.eclipse.jdt.inte rnal.debug.ui.launcher.StandardVMType/J2SE-1.5 "/>
path="org.eclipse.pde.core.requiredPlugins"/>
<classpathentry kind="output" path="bin"/>
</classpath>
For us the build.properties looks like this:
bin.includes = about.html,\
plugin.properties,\
plugin.xml,\
model/,\
META-INF/,\
schema/
src.includes = about.html
source.. = src/
output.. = bin/
exclude.. = **/doc-files/**
I'm confused about that "classes" folder you mentioned. So I get the
sense that something fishy is going on with your classpath related to
this javax thing. I think you should be specifying that it's part of
the output.. rather than what you've done...
> Ed,
> Frederic
> Ed Merks a
Re: Plugin binary folder cause dependent plugins export to fail [message #328302 is a reply to message #328266] Wed, 21 May 2008 08:04 Go to previous messageGo to next message
Ed,
I should have done this from the beginning, show us the code ;)
I zipped the 2 plugins (A and B), you'll find them here:
http://www.covariance.lu/docs/eclipse.platform/Plugin_binary _folder_test.zip
the TransactionConsumer plugin imports classes from the
javax.transaction plugin.
When exporting the TransactionConsumer plugin, PDE (of Eclipse v3.3.1)
produces a logs.zip containing the following compiling error:
# 21/05/08 9:52:55 CEST
# Eclipse Java Compiler 0.780_R33x, 3.3.1, Copyright IBM Corp 2000,
2007. All rights reserved.
1. ERROR in
(...snip...)\TransactionConsumer\src\org\example\Transaction Consumer.java
(at line 3)
import javax.transaction.TransactionManager;
The import javax.transaction.TransactionManager cannot be resolved
2. ERROR in
(at line 7)
public TransactionConsumer(TransactionManager aTransactionManager) {
TransactionManager cannot be resolved to a type
2 problems (2 errors)
Though in the workspace, TransactionConsumer.java compiles.
Frederic
Ed Merks a écrit :
> Frederic,
> <classpath>
> </classpath>
> plugin.properties,\
> plugin.xml,\
> model/,\
> META-INF/,\
> schema/
> source.. = src/
> output.. = bin/
>> Ed,
>> Frederic
>> Ed Merks a écrit :
>>> Frederic,
>>> Comments below.
>>>> Ed,
>>>> bundles.
>>>> folders
>>>> javax/
>> Yes I do
>> as it's added by default)
>> Bundle-ClassPath: .
>> ;version="1.0.1"
>>> When building plugins, all changes to the classpath should be done by
>>> editing the MANIFEST.MF not via the project's properties..
>>>> Frederic
>>>> Ed Merks a écrit :
>>>>> Frederic,
>>>>> particular, I wonder if you've properly specified to include the
>>>>> classes folder int he binary result.
>>>>>> Dear all,
>>>>>> issue.
>>>>>> to build Plugin B because it cannot resolves binary classes for
>>>>>> plugin A.
>>>>>> in plugin A.
>>>>>> Frederic
Re: Plugin binary folder cause dependent plugins export to fail [message #328327 is a reply to message #328302] Wed, 21 May 2008 16:02 Go to previous messageGo to next message
Frederic,
It sounds like you're using a different JDK in that case. Not sure how
to control that...
> Ed,
> 1. ERROR in
> (at line 3)
> 2. ERROR in
> (at line 7)
> Frederic
> Ed Merks a écrit :
>> Frederic,
>> <?xml version="1.0" encoding="UTF-8"?>
>> <classpath>
>> </classpath>
>> plugin.properties,\
>> plugin.xml,\
>> model/,\
>> META-INF/,\
>> schema/
>> source.. = src/
>> output.. = bin/
>> the sense that something fishy is going on with your classpath
>> related to this javax thing. I think you should be specifying that
>> it's part of the output.. rather than what you've done...
>>> Ed,
>>> Frederic
>>> Ed Merks a écrit :
>>>> Frederic,
>>>> Comments below.
>>>>> Ed,
>>>>> bundles.
>>>>> javax/
>>> Yes I do
>>> Bundle-ClassPath: .
>>> ;version="1.0.1"
>>>> by editing the MANIFEST.MF not via the project's properties..
>>>>> Frederic
>>>>> Ed Merks a écrit :
>>>>>> Frederic,
>>>>>>> Dear all,
>>>>>>> no issue.
>>>>>>> fails to build Plugin B because it cannot resolves binary
>>>>>>> in plugin A.
>>>>>>> bug ?
>>>>>>> Frederic
Re: Plugin binary folder cause dependent plugins export to fail [message #330062 is a reply to message #328327] Mon, 14 July 2008 10:31 Go to previous message
Originally posted by: automatic.javalobby.org
For whom it might interest, I experienced same issue while importing classes of log4j bundle from Eclipse Orbit project, so I finally reported an issue there:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=240649
Previous Topic:Re: Problem switching from Europa to Ganymede
Next Topic:How to show files in Outline View or similar like this
Current Time: Sat Nov 02 17:14:42 GMT 2024
Powered by FUDForum. Page generated in 0.04174 seconds
