Home » Eclipse Projects » Eclipse Platform » iPath.getFullPath doesn"t return the device letter
iPath.getFullPath doesn"t return the device letter [message #328190] Fri, 16 May 2008 15:51 Go to next message
No real name is currently offline No real nameFriend
Member
hi all
always trying to launch a command in a specified file
I ve obtained the path of the file with this portion of code
IEditorInput Editor =
this.window.getActivePage().getActiveEditor().getEditorInput ();
if (Editor instanceof IFileEditorInput)
IFile File = ((IFileEditorInput) Editor).getFile();
System.out.println(File.getFullPath);
System.out.println(File.getFullPath().getDevice());
the prob is I have that
/test/test.yy
null
in other word, I havent the device letter who is really problematic to
launch a command in a directory.
any idea.
what I m trying to do is to launch a special command in the directory
test (who is I:\runtime-application\test\test.yy). get and parse the
result, etc...etc..
thanks
a+++
Re: iPath.getFullPath doesn"t return the device letter [message #328192 is a reply to message #328190] Fri, 16 May 2008 17:00 Go to previous messageGo to next message
Originally posted by: mircea.luchian.matrox.com
Use the URI api. You will be able to get the file with the device letter
and path from your project file.
Mircea
julien wrote:
> hi all
> /test/test.yy
> null
> any idea.
> result, etc...etc..
> thanks
> a+++
Re: iPath.getFullPath doesn"t return the device letter [message #328193 is a reply to message #328192] Fri, 16 May 2008 17:05 Go to previous messageGo to next message
Guys,
You'd want to use getLocation or getLocationURI. The getFullPath method
returns the workspace relative path, not the physical location/URI of
the resource.
Mircea Luchian wrote:
> letter and path from your project file.
> Mircea
> julien wrote:
>> hi all
>> /test/test.yy
>> null
>> to launch a command in a directory.
>> any idea.
>> result, etc...etc..
>> thanks
>> a+++
Re: iPath.getFullPath doesn"t return the device letter [message #328196 is a reply to message #328193] Fri, 16 May 2008 17:18 Go to previous message
Member
every thing works
thanks all
a++
Ed Merks a écrit :
> Guys,
> the resource.
>> Mircea
>> julien wrote:
>>> hi all
>>> /test/test.yy
>>> null
>>> any idea.
>>> result, etc...etc..
>>> thanks
>>> a+++
Previous Topic:ActiveEditorId not set on startup
Next Topic:template completion (how to)
Current Time: Sat Nov 09 05:16:21 GMT 2024
Powered by FUDForum. Page generated in 0.03235 seconds
