Home » Eclipse Projects » Eclipse Platform » Error Attaching Source beginRule does not match outer scope rule ...
Error Attaching Source beginRule does not match outer scope rule ... [message #328158] Thu, 15 May 2008 21:55 Go to next message
John J. Barton is currently offline John J. BartonFriend
I am still trying to get javadoc and source for Ganymede M6 to work. I
downloaded the Ganymede jee and rcp packages and copied all of the
*.source* files from rcp plugins to jee plugins. Nothing good happened,
no javadoc for examle. When I navigate to a declaration in eg
org.eclipse.ui.externaltools, I get a Source Not Found decompiled page
with a button Change Attached Source. When I use the button and navigate
to the source jar I get a popup
Error Attaching Source, Attempted to beginRule: R/, does not match
outer scope rule: P/org.eclipse.ui.externaltools.
I must be doing something way wrong, it can't be this hard. Any suggestions?
John.
Re: Error Attaching Source beginRule does not match outer scope rule ... [message #334035 is a reply to message #328158] Fri, 16 January 2009 08:14 Go to previous message
Originally posted by: leshek.techie.com
I am running into what looka like the same problem but with different jar
(not a plugin). In erlier Eclipse version it worked just fine in 3.3 I get
the same error when I go to a definition of a class and hit attach source
button.
In http://webui.sourcelabs.com/eclipse/issues/243692 I found a hint:
"Configure Build Path..." and editing the source attachment in
the libraries tab.
and... it worked for me... it smells like Eclipse 3.3 but to me.... but... I
am not an expert.
Cheers...
"John J Barton" <johnjbarton@johnjbarton.com> wrote in message
news:g0iasu$6bj$1@build.eclipse.org...
>*.source* files from rcp plugins to jee plugins. Nothing good happened, no
>org.eclipse.ui.externaltools, I get a Source Not Found decompiled page with
>a button Change Attached Source. When I use the button and navigate to the
> Error Attaching Source, Attempted to beginRule: R/, does not match outer
> suggestions?
> John.
Previous Topic:Common Navigator DND
Next Topic:Project nature icon displayed in the Navigator but not in the Project Explorer
Current Time: Thu Aug 29 12:37:56 GMT 2024
Powered by FUDForum. Page generated in 0.03604 seconds
