Home » Eclipse Projects » Eclipse Platform » Extrange behaviours in Ganymedes M7 workbench
Extrange behaviours in Ganymedes M7 workbench [message #328150] Thu, 15 May 2008 15:55 Go to next message
Victor Roldan Betancort is currently offline Victor Roldan BetancortFriend
Hi!
I moved lately to M7, and I noticed that the workbench (in comparison
with M6) has become somehow more unstable. I'm cannot find a pattern to
reproduce these behaviours, but seem easy to appear. I'm using Eclipse
3.4 M7 (I20080502-0100) and Windows XP SP2
First I noticed that, just a few times, one view became crashed and the
all it's buttons dissapear. Then the whole workbench became unstable and
had to force it's closing. I got to do this only two times. I've tried,
but can get to reproduce it now.
What I get most is and odd behaviour with pop-up menus. Try it: clean
installation M7. Execute it, create new java project in Java
perspective, and then right click over it in the project explorer. The
one the options that I see is "Create Watch Expression"! Doesn't that
belong to debug perspective?
The most critic problem I've found with pop-up menus regarding M7 is
something that only appears when a tree view has plenty of nodes: when
pointing with the mouses' over sub-menus witch initially seemed enabled,
the submenu becomes disabled (grey color) and I cannot enter it. In this
case, it happened to me in two different cases: within the project
explorer, in a workspace I have with more than 60 plugin projects (for
instance, "Team", "Source", "Refactor" or "New"). It also happened to me
in the generated editor by EMF.editor ("create child" or "create
sibling" become disabled once I pointed over it with the mouse cursor).
Curiously enought, you can avoid this problem if your are fast enough to
be able to click over the submenu option before the popup delay time ends.
All this is very strange, and I don't know if I'm being clear. Try
putting many projects in the workspace and then right-clicking and
trying to access submenus.
I'll try to make a video, it might be more clarifying.
Regards to the best open source community!
Víctor.
Open Canarias.
Re: Extrange behaviours in Ganymedes M7 workbench [message #328210 is a reply to message #328150] Sun, 18 May 2008 11:30 Go to previous messageGo to next message
Originally posted by: jack.NO.SPAM
Víctor Roldán Betancort a écrit :
> Hi!
I got it too !! But only one time.
Re: Extrange behaviours in Ganymedes M7 workbench [message #328918 is a reply to message #328150] Fri, 06 June 2008 17:31 Go to previous message
Paul Webster is currently offline Paul WebsterFriend
This has been fixed in RC3 ... the workbench delays plugin loaded as
much as possible, but that means some contributions visible/enabled
clauses are not accurate (until the plugin is loaded).
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Previous Topic:Getting Key Bindings to work with Text Widget in Coolbar
Next Topic:Programatically Fire a Selection Event
Current Time: Thu Dec 26 11:42:20 GMT 2024
Powered by FUDForum. Page generated in 0.02982 seconds
