Home » Eclipse Projects » Eclipse Platform » get the current directory of the current project
get the current directory of the current project [message #328137] Thu, 15 May 2008 01:27 Go to next message
hi all, I would like know how to do to get the current directory of the
current project open.
thanks
a++
Re: get the current directory of the current project [message #328146 is a reply to message #328137] Thu, 15 May 2008 09:45 Go to previous messageGo to next message
I assume that you mean at runtime.
As a matter of practice, you shouldn't be playing with directories in
your project at runtime. When you deploy as a JAR file, there won't be
any directories to navigate.
You probably want to access some files inside your project, right?
Look at the MyClass.class.getResource() and getResourceAsStream()
methods. Be sure to read the part about the leading '/'.
HTH,
Wayne
> thanks
> a++
Re: get the current directory of the current project [message #328152 is a reply to message #328146] Thu, 15 May 2008 12:31 Go to previous messageGo to next message
hi, thanks,
I ll look.
in fact, I really need the directory cause I need to launch a command
in the directory. it's a tropical command for a tropical language
etc...etc...
thanks
a++
> HTH,
> Wayne
>> thanks
>> a++
Re: get the current directory of the current project [message #328153 is a reply to message #328152] Thu, 15 May 2008 12:35 Go to previous message
Julien,
I think you'd need to find the navigator/project explore/package explore
view from the current workbench page and check its selection.
julien wrote:
> hi, thanks,
> I ll look.
> etc...etc...
> thanks
> a++
>> HTH,
>> Wayne
>>> the current project open.
>>> thanks
>>> a++
Previous Topic:100% cpu usage when opening a class file
Next Topic:Status of the Remote help Proposal
Current Time: Wed Oct 15 12:25:42 EDT 2025
Powered by FUDForum. Page generated in 0.05738 seconds
