Re: get the current directory of the current project [message #328152 is a reply to message #328146] |
Thu, 15 May 2008 16:31 |
No real name Messages: 64 Registered: July 2009 |
Member |
hi, thanks,
I ll look.
in fact, I really need the directory cause I need to launch a command
in the directory. it's a tropical command for a tropical language
etc...etc...
thanks
a++
Wayne Beaton a écrit :
> I assume that you mean at runtime.
> As a matter of practice, you shouldn't be playing with directories in
> your project at runtime. When you deploy as a JAR file, there won't be
> any directories to navigate.
> You probably want to access some files inside your project, right?
> Look at the MyClass.class.getResource() and getResourceAsStream()
> methods. Be sure to read the part about the leading '/'.
> HTH,
> Wayne
> On Thu, 2008-05-15 at 07:27 +0200, julien wrote:
>> hi all, I would like know how to do to get the current directory of the
>> current project open.
>> thanks
>> a++
Re: get the current directory of the current project [message #328153 is a reply to message #328152] |
Thu, 15 May 2008 16:35 |
Julien,
I think you'd need to find the navigator/project explore/package explore
view from the current workbench page and check its selection.
julien wrote:
> hi, thanks,
> I ll look.
> etc...etc...
> thanks
> a++
>> HTH,
>> Wayne
>>> the current project open.
>>> thanks
>>> a++
FUDForum. Page generated in 0.03815 seconds
