Home » Eclipse Projects » Eclipse Platform » contribute to status line
contribute to status line [message #328127] Wed, 14 May 2008 19:55 Go to next message
Hauke Fuhrmann is currently offline Hauke FuhrmannFriend
Hi there,
I try to contribute some simple text to the status line.
I wrote a little plugin without any view, it shall simply write the
current mouse cursor position to the status line.
I tried to get some valid StatusLineManager but the only way I can get
it seems to be via a view. I don't have a view, so I try to search for
any resp. all ones:
IViewReference views[] =
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActi vePage().getViewReferences();
for (int i = 0; i < views.length; i++) {
IStatusLineManager line =
views[i].getView(false).getViewSite().getActionBars().getSta tusLineManager();
line.setMessage(msg);
line.update(true);
This is really ugly. Is there no straight forward way to contribute to
the status line without access to a certain view?
Hauke
Re: contribute to status line [message #328915 is a reply to message #328127] Fri, 06 June 2008 17:27 Go to previous message
Paul Webster is currently offline Paul WebsterFriend
No. The active part will set the status line (i.e. whatever you have
done will be overwritten the next time the active part changes).
You can put your own status label in the trim using the
org.eclipse.ui.menus extension point, however, available from 3.3 onwards.
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Previous Topic:Confused with actions
Next Topic:Getting Key Bindings to work with Text Widget in Coolbar
Current Time: Sat Dec 21 12:38:14 GMT 2024
Powered by FUDForum. Page generated in 0.03225 seconds
