Re: Suggestion: Syntax Coloring Eclipse 3.4 [message #328024 is a reply to message #328022] |
Mon, 12 May 2008 17:59 |
Wayne Beaton Messages: 554 Registered: December 2017 |
Open a bug report and report the id for it.
FWIW, I disagree with you, but you should still open the bug report.
Wayne
On Mon, 2008-05-12 at 17:46 +0000, Ricardo Ferreira wrote:
> The new 3.4 java syntax coloring is so bad that at first i could hardly
> understand the code. Things ought to look better as in previous versions.
> I suggest for comments (0,128,0), for keywords (0,0,255) as in String as
> well.
> I think the rest is fine, but those changes are really needed.
Re: Suggestion: Syntax Coloring Eclipse 3.4 [message #328032 is a reply to message #328022] |
Mon, 12 May 2008 20:21 |
> well.
Are you aware that you can change the syntax coloring in the
Preferences? Just type "syntax" (without quotes) in the search box at
the top of the Preferences dialog, and you'll find the settings to change.
Eric
FUDForum. Page generated in 0.03256 seconds
