Update Site Project - some issues [message #328016] |
Mon, 12 May 2008 16:50 |
Omar Messages: 7 Registered: July 2009 |
Junior Member |
Hi everybody.
I create two Eclipse-based plugins, and now I want to create a feature
project
and a correlated update-site project.
Its the first time I do these operations, so I have some questions for you:
1. My plugins need some dependencies (org.eclipse.wst) that I inserted in
the
feature.xml file under the <requires> section. The required features must
be on
the same site where the project is hosted, or can be downloaded from
another
site? Do I have to include only the main package or the subpackages too
(org.eclipse.wst.common_core.feature, etc)?
2. I need an external library (DLL) to make a plugin to work. How can I
insert
it into the project?
3. The two plugin can be inserted in a single feature project? Or it's
better to
create two distinct feature project and then use a composite feature that
contains them?
Thanks in advance.
FUDForum. Page generated in 0.03587 seconds
