Creating subfolders [message #327950] |
Fri, 09 May 2008 11:51 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: nospam.nospam.com
Suppose I have the following folder structure:
folderA/folderB
Is it possible to create a subfolder such as:
folderA/folderB/folder1/folder2/folder3
with one call, or do I have to create each of these separately in a loop?
First create folder1 then folder2 then folder3.
Re: Creating subfolders [message #327954 is a reply to message #327950] |
Fri, 09 May 2008 12:13 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
The Java doc lists a reason for IFolder creation failure as:
* <li> The parent of this resource does not exist.</li>
So I think you need to create each one in turn.
> folderA/folderB
> loop? First create folder1 then folder2 then folder3.
FUDForum. Page generated in 0.02757 seconds
