Home » Eclipse Projects » Eclipse Platform » Working sets
Re: Working sets [message #327948 is a reply to message #327947] |
Fri, 09 May 2008 10:29 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
--------------070500080207000801050002
Fabio,
I found this blog demo pretty useful:
http://www.peterfriese.de/eclipse-working-sets-part-i/
You know you have to configure the explorer to show working sets via the
drop down menu in the upper right correct, right?
Fabio Mancinelli wrote:
> Dear all,
> do you know a tutorial on how to manage working sets?
> I have successfully set up the working set extension point, but
> elements in the working set are presented in the Project Explorer in a
> flat way, though my adapters correctly provide getParent() information.
> Maybe I am missing something trivial but I cannot understand what, so
> a complete tutorial would be useful.
> Thanks for the hints.
> Cheers,
> Fabio
<html>
<head>
</head>
Fabio,<br>
<br>
I found this blog demo pretty useful:<br>
<blockquote><a
href="http://www.peterfriese.de/eclipse-working-sets-part-i/">http://www.peterfriese.de/eclipse-working-sets-part-i/</a><br>
</blockquote>
the drop down menu in the upper right correct, right?<br>
<br>
<br>
<blockquote cite="mid:g017ap$f5l$1@build.eclipse.org" type="cite">Dear
all,
<br>
<br>
<br>
<br>
<br>
Maybe I am missing something trivial but I cannot understand what, so a
<br>
<br>
<br>
<br>
<br>
Fabio
<br>
</blockquote>
<br>
</body>
</html>
--------------070500080207000801050002--
Re: Working sets [message #327952 is a reply to message #327949] |
Fri, 09 May 2008 12:03 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Fabio,
The drop down menu has the choice for "Top Elements" as being "Projects"
or "Working Sets". I assume you don't have the former selected while
expect the behavior of the latter.
> Ed Merks wrote:
>> Fabio,
> I am missing something from your "configuration" remark. From the
> point of view of the upper right corner menu, the Project Explorer
> shows the classic menu with the working set options, and I have my
> working set page wizard correctly listed and open. I can create,
> remove, edit my working sets. My problems starts when I select one of
> them.
> Thank you very much for the link. I am going to read it right now!
> Cheers,
> Fabio
Re: Working sets [message #327978 is a reply to message #327952] |
Sun, 11 May 2008 18:41 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Fabio M![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=fabio.mancinelli%40gmail.com) Messages: 25 Registered: July 2009 |
Junior Member |
Ed Merks wrote:
> Fabio,
Hi Ed,
yes I have "TopLevel Elements" set on "Working Sets".
Anyway there has been a misunderstanding probably because maybe I have
asked my question in the wrong way.
I am not interested in using working sets from a user point of view, but
from a plugin developer point of view.
What happens is the following. Normally I have this:
Project
+ Contribution via Common Navigator extension points
+ Parent element A
+ Child A.1
+ Child A.2
+ Child A.3
The contribution shows elements that do not reside on the workspace (in
particular, I present a list of element available on a remote server
hierarchy).
I set up a working set type by providing an implementation of a
WizardPage for selecting elements presented through the Common Navigator
contribution. I do this through the org.eclipse.ui.workingSets extension
point.
Everything works. I am able to build a working sets containing, for
example, A, A.1, A.2. But when I activate the working set just created
instead of having in the project explorer
A
|- A.1
|- A.2
I have
A
A.1
A.2
That is parent-child relationships are not taken into account.
All the elements A, A.1, etc. are adaptable to WorkbenchAdapter and the
getParent() method correctly returns the actual parent.
I don't know what's wrong in my code since I think that I have set up
things correctly, but of course there is something that doesn't work.
That's why I was asking about a tutorial, but from the plugin developer
perspective.
Thank you for your help.
Fabio
Re: Working sets [message #327981 is a reply to message #327978] |
Sun, 11 May 2008 22:58 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
> Ed Merks wrote:
>> Fabio,
>> "Projects" or "Working Sets". I assume you don't have the former
>> selected while expect the behavior of the latter.
> Hi Ed,
> but from a plugin developer point of view.
> Project
> + Parent element A
> + Child A.1
> + Child A.2
> + Child A.3
> (in particular, I present a list of element available on a remote
> server hierarchy).
> Navigator contribution. I do this through the
> org.eclipse.ui.workingSets extension point.
> A
> |- A.1
> |- A.2
> I have
> A
> A.1
> A.2
> the getParent() method correctly returns the actual parent.
By actual parent, I assume you mean that A.1's parent is A? I get the
sense that perhaps you've somehow returning the same object as the
parent for A, A.1, and A.2. I've never used these APIs, so I doubt
what I can say will be of much help. Sorry. Hopefully someone else can
help...
> developer perspective.
> Cheers,
> Fabio
Current Time: Sun Jun 30 00:16:22 GMT 2024
Powered by FUDForum. Page generated in 0.04446 seconds
