| execute Command from a Property Page [message #327925] |
Thu, 08 May 2008 10:15  |
from a PropertyPage, i'm trying to execute a Command that opens another
Window/Dialog:
What i get is the following Exception:
org.eclipse.core.commands.ExecutionException: No activeWorkbenchWindow
found while executing org.eclipse.ui.help.aboutAction
What is wrong?
Help is greatly appreciated.
Simon
Detailed Code:
public class APropertyPage extends PropertyPage {
protected Control createContents(Composite parent) {
Composite composite = new Composite(parent, SWT.NONE);
composite.setLayout(new GridLayout(2, true));
Link link = new Link(composite, SWT.LEFT);
link.setText("<a>Command...</a>");
link.addListener(SWT.Selection, new Listener() {
public void handleEvent(Event event) {
final IHandlerService handlerService = (IHandlerService) PlatformUI
.getWorkbench().getService(IHandlerService.class);
try {
handlerService
.executeCommand(
"org.eclipse.ui.help.aboutAction",
event);
catch (Exception e) {
e.printStackTrace();
return composite;
Stack Trace:
at org.eclipse.ui.handlers.HandlerUtil.noVariableFound(HandlerU til.java:38)
org.eclipse.ui.handlers.HandlerUtil.getVariableChecked(Handl erUtil.java:86)
org.eclipse.ui.handlers.HandlerUtil.getActiveWorkbenchWindow Checked(HandlerUtil.java:188)
at org.eclipse.ui.internal.about.AboutHandler.execute(AboutHand ler.java:34)
org.eclipse.ui.internal.handlers.HandlerProxy.execute(Handle rProxy.java:240)
at org.eclipse.core.commands.Command.executeWithChecks(Command. java:475)
org.eclipse.ui.internal.handlers.HandlerService.executeComma nd(HandlerService.java:174)
at APropertyPage$1.handleEvent(ZuglaufPropertyPage.java:73)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:962)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:947)
at org.eclipse.swt.widgets.Link.wmNotifyChild(Link.java:932)
at org.eclipse.swt.widgets.Control.wmNotify(Control.java:4563)
at org.eclipse.swt.widgets.Composite.wmNotify(Composite.java:15 81)
at org.eclipse.swt.widgets.Control.WM_NOTIFY(Control.java:4216)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3724 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4364 )
at org.eclipse.swt.internal.win32.OS.CallWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.CallWindowProc(OS.java:217 9)
at org.eclipse.swt.widgets.Link.callWindowProc(Link.java:124)
at org.eclipse.swt.widgets.Widget.wmLButtonUp(Widget.java:1817)
at org.eclipse.swt.widgets.Control.WM_LBUTTONUP(Control.java:40 12)
at org.eclipse.swt.widgets.Link.WM_LBUTTONUP(Link.java:784)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3706 )
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:22 65)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3291)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:820 )
at org.eclipse.jface.window.Window.open(Window.java:796)
org.eclipse.ui.dialogs.PropertyDialogAction.run(PropertyDial ogAction.java:156)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:546)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:490)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:402)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3682)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3293)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
ch.sbb.rcsd.client.application.internal.RCSDApplication.star t(RCSDApplication.java:36)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
at org.eclipse.equinox.launcher.Main.main(Main.java:1148)
FUDForum. Page generated in 0.03515 seconds
