Home » Eclipse Projects » Eclipse Platform » eclipse 3.4M6 won't run from NFS disk
eclipse 3.4M6 won't run from NFS disk [message #327899] Wed, 07 May 2008 21:21 Go to next message
Mark Geib is currently offline Mark GeibFriend
We are trying to host our eclipse install(s) on a server, then export the
installs via NFS, or Samba, etc.
We have the exported path mounted on a client, and eclipse installed, this
is all Linux, but running eclipse results in the following...
.../3.4M6/eclipse-java$ ./eclipse
!ENTRY org.eclipse.osgi 4 0 2008-05-07 14:29:23.326
!MESSAGE Application error
!STACK 1
java.lang.IllegalStateException: Unable to acquire application service.
Ensure that the org.eclipse.core.runtime bundle is resolved and started
(see config.ini).
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:74)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:362)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:175)
Can someone give me any ideas on what is wrong here.??
I have install 3.4M6 in many other directories and it runs with no
problems at all.
Mark.
Re: eclipse 3.4M6 won't run from NFS disk [message #327901 is a reply to message #327899] Wed, 07 May 2008 21:52 Go to previous message
Eclipse Webmaster is currently offline Eclipse WebmasterFriend
NFS is likely not the problem. I run lots of Eclipse instances from
various NFS mounts on a whole bunch of platforms.
> the installs via NFS, or Samba, etc.
> this is all Linux, but running eclipse results in the following...
> !STACK 1
> (see config.ini).
> at
> at
> at
> at
> at
> at java.lang.reflect.Method.invoke(Method.java:597)
> problems at all.
> Mark.
Previous Topic:Ganymede IHandler2/AbstractHandler execute() method not recognized in @Override
Next Topic:The JAR of this class file belongs to contain 'Plug-in Dependencies' which does not allow modificati
Current Time: Fri Nov 08 22:44:30 GMT 2024
Powered by FUDForum. Page generated in 0.03350 seconds
