Home » Eclipse Projects » Eclipse Platform » 100% cpu usage when opening a class file
100% cpu usage when opening a class file [message #327893] |
Wed, 07 May 2008 17:05 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: rosec.messagingdirect.com
--------------080901090808040005040007
I don't know if this has been asked before (and you'd be amazed at how
hard it is to find specific information when your search query is
"eclipse 100% cpu usage opening class files in a jar"!) but, well,
that's what I'm getting:
When I open a class file in the editor that is contained in a jar file
anywhere on a Java project's classpath, one of my processor pegs at 100%
usage for anywhere from 15-120 seconds and eclipse becomes
non-responsive for that period of time, not even redrawing the UI.
This occurs for jars as large as the jboss client jar and the weblogic
80Mb uber-jar and for jars as small as a 241kb library jar.
Is there anything I can do to track down WHY this is happening? I end
up having to trace into third party code a lot while debugging container
behaviour and this plays merry havoc with the timeouts for remote calls,
so I'm quite motivated to suss out why it's happening.
Eclipse details are attached.
Chris Rose
Developer Planet Consulting Group
(780) 577-8433
crose@planetci.com
name="eclipse-config.txt"
Content-Disposition: inline;
filename="eclipse-config.txt"
*** Date: Wednesday, May 7, 2008 11:04:56 AM MT
*** Platform Details:
*** System properties:
eclipse.buildId=3DM20080221-1800
eclipse.commands=3D-os
linux
-ws
gtk
-arch
x86
-showsplash
-launcher
/home/rosec/app/eclipse-3.3-winter/eclipse
-name
Eclipse
--launcher.library
/home/rosec/app/eclipse-3.3-winter/plugins/org.eclipse.equin ox.launcher.g=
tk.linux.x86_1.0.3.R33x_v20080118/eclipse_1023.so
-startup
/home/rosec/app/eclipse-3.3-winter/plugins/org.eclipse.equin ox.launcher_1=
=2E0.1.R33x_v20080118.jar
-exitdata
ae50020
-vm
/usr/java/jrockit-R27.5.0-jdk1.5.0_14/bin/java
eclipse.ee.install.verify=3Dfalse
eclipse.product=3Dorg.eclipse.sdk.ide
eclipse.startTime=3D1210179047270
eclipse.vm=3D/usr/java/jrockit-R27.5.0-jdk1.5.0_14/bin/java
eclipse.vmargs=3D-XX:MaxPermSize=3D384m
-Xmx1024M
-jar
eof=3Deof
file.encoding=3DANSI_X3.4-1968
file.encoding.pkg=3Dsun.io
file.separator=3D/
java.awt.graphicsenv=3Dsun.awt.X11GraphicsEnvironment
java.awt.printerjob=3Dsun.print.PSPrinterJob
java.class.path=3D/home/rosec/app/eclipse-3.3-winter/plugins /org.eclipse.=
equinox.launcher_1.0.1.R33x_v20080118.jar
java.class.version=3D49.0
java.endorsed.dirs=3D/usr/java/jrockit-R27.5.0-jdk1.5.0_14/j re/lib/endors=
ed
java.ext.dirs=3D/usr/java/jrockit-R27.5.0-jdk1.5.0_14/jre/li b/ext
java.home=3D/usr/java/jrockit-R27.5.0-jdk1.5.0_14/jre
java.io.tmpdir=3D/tmp
java.library.path=3D/usr/java/jrockit-R27.5.0-jdk1.5.0_14/jr e/lib/i386/jr=
ockit:/usr/java/jrockit-R27.5.0-jdk1.5.0_14/jre/lib/i386:/us r/java/jrocki=
t-R27.5.0-jdk1.5.0_14/jre/../lib/i386:/home/rosec/h/docgen/a t/fc:/tcl/8.4=
=2E4-md3/lib:/opt/odbc32v53/lib:/unixODBC/2.2.11-md4/lib:/us r/lib/oracle/=
10.2.0.3/client/lib:/opt/sqlanywhere10/jre150/lib/i386/clien t:/opt/sqlany=
where10/jre150/lib/i386:/opt/sqlanywhere10/jre150/lib/i386/n ative_threads=
:/opt/sqlanywhere10/lib32:/tomboy:/usr/lib/firefox-2.0.0.13
java.runtime.name=3DJava(TM) 2 Runtime Environment, Standard Edition
java.runtime.version=3D1.5.0_14-b03
java.specification.name=3DJava Platform API Specification
java.specification.vendor=3DSun Microsystems Inc.
java.specification.version=3D1.5
java.vendor=3DBEA Systems, Inc.
java.vendor.url=3Dhttp://www.bea.com/
java.vendor.url.bug=3Dhttp://edocs.bea.com/jrockit/go2troubleshooting.htm=
l
java.version=3D1.5.0_14
java.vm.info=3Dcompiled mode
java.vm.name=3DBEA JRockit(R)
java.vm.specification.name=3DJava Virtual Machine Specification
java.vm.specification.vendor=3DSun Microsystems Inc.
java.vm.specification.version=3D1.0
java.vm.vendor=3DBEA Systems, Inc.
java.vm.vendor.url=3Dhttp://www.bea.com/
java.vm.vendor.url.bug=3Dhttp://edocs.bea.com/jrockit/go2troubleshooting.=
html
java.vm.version=3DR27.5.0-110-94909-1.5.0_14-20080204-1558-l inux-ia32
line.separator=3D
org.apache.commons.logging.Log=3Dorg.apache.commons.logging. impl.SimpleLo=
g
org.apache.commons.logging.simplelog.defaultlog=3Doff
org.apache.commons.logging.simplelog.log.httpclient.wire.hea der=3Doff
org.apache.commons.logging.simplelog.log.org.apache.commons. httpclient=3D=
off
org.eclipse.equinox.launcher.splash.location=3D/home/rosec/a pp/eclipse-3.=
3-winter/plugins/org.eclipse.platform_3.3.3.r33x_r20080129/s plash.bmp
org.eclipse.swt.browser.XULRunnerInitialized=3Dtrue
org.eclipse.swt.browser.XULRunnerPath=3D/usr/lib/firefox-2.0 .0.13
org.osgi.framework.executionenvironment=3DOSGi/Minimum-1.0,O SGi/Minimum-1=
=2E1,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5
org.osgi.framework.language=3Den
org.osgi.framework.os.name=3DLinux
org.osgi.framework.os.version=3D2.6.23.8-63.fc8
org.osgi.framework.processor=3Di386
org.osgi.framework.system.packages=3Djavax.accessibility,jav ax.activity,j=
avax.crypto,javax.crypto.interfaces,javax.crypto.spec,javax. imageio,javax=
=2Eimageio.event,javax.imageio.metadata,javax.imageio.plugin s.bmp,javax.i=
mageio.plugins.jpeg,javax.imageio.spi,javax.imageio.stream,j avax.manageme=
nt,javax.management.loading,javax.management.modelmbean,java x.management.=
monitor,javax.management.openmbean,javax.management.relation ,javax.manage=
ment.remote,javax.management.remote.rmi,javax.management.tim er,javax.nami=
ng,javax.naming.directory,javax.naming.event,javax.naming.ld ap,javax.nami=
ng.spi,javax.net,javax.net.ssl,javax.print,javax.print.attri bute,javax.pr=
int.attribute.standard,javax.print.event,javax.rmi,javax.rmi .CORBA,javax.=
rmi.ssl,javax.security.auth,javax.security.auth.callback,jav ax.security.a=
uth.kerberos,javax.security.auth.login,javax.security.auth.s pi,javax.secu=
rity.auth.x500,javax.security.cert,javax.security.sasl,javax .sound.midi,j=
avax.sound.midi.spi,javax.sound.sampled,javax.sound.sampled. spi,javax.sql=
,javax.sql.rowset,javax.sql.rowset.serial,javax.sql.rowset.s pi,javax.swin=
g,javax.swing.border,javax.swing.colorchooser,javax.swing.ev ent,javax.swi=
ng.filechooser,javax.swing.plaf,javax.swing.plaf.basic,javax .swing.plaf.m=
etal,javax.swing.plaf.multi,javax.swing.plaf.synth,javax.swi ng.table,java=
x.swing.text,javax.swing.text.html,javax.swing.text.html.par ser,javax.swi=
ng.text.rtf,javax.swing.tree,javax.swing.undo,javax.transact ion,javax.tra=
nsaction.xa,javax.xml,javax.xml.datatype,javax.xml.namespace ,javax.xml.pa=
rsers,javax.xml.transform,javax.xml.transform.dom,javax.xml. transform.sax=
,javax.xml.transform.stream,javax.xml.validation,javax.xml.x path,org.ietf=
=2Ejgss,org.omg.CORBA,org.omg.CORBA_2_3,org.omg.CORBA_2_3.po rtable,org.om=
g.CORBA.DynAnyPackage,org.omg.CORBA.ORBPackage,org.omg.CORBA .portable,org=
=2Eomg.CORBA.TypeCodePackage,org.omg.CosNaming,org.omg.CosNa ming.NamingCo=
ntextExtPackage,org.omg.CosNaming.NamingContextPackage,org.o mg.Dynamic,or=
g.omg.DynamicAny,org.omg.DynamicAny.DynAnyFactoryPackage,org .omg.DynamicA=
ny.DynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPackage ,org.omg.IOP.=
CodecPackage,org.omg.Messaging,org.omg.PortableInterceptor,o rg.omg.Portab=
leInterceptor.ORBInitInfoPackage,org.omg.PortableServer,org. omg.PortableS=
erver.CurrentPackage,org.omg.PortableServer.POAManagerPackag e,org.omg.Por=
tableServer.POAPackage,org.omg.PortableServer.portable,org.o mg.PortableSe=
rver.ServantLocatorPackage,org.omg.SendingContext,org.omg.st ub.java.rmi,o=
rg.w3c.dom,org.w3c.dom.bootstrap,org.w3c.dom.css,org.w3c.dom .events,org.w=
3c.dom.html,org.w3c.dom.ls,org.w3c.dom.ranges,org.w3c.dom.st ylesheets,org=
=2Ew3c.dom.traversal,org.w3c.dom.views ,org.xml.sax,org.xml.sax.ext,org.x=
ml.sax.helpers
org.osgi.framework.vendor=3DEclipse
org.osgi.framework.version=3D1.4.0
org.osgi.supports.framework.extension=3Dtrue
org.osgi.supports.framework.fragment=3Dtrue
org.osgi.supports.framework.requirebundle=3Dtrue
os.arch=3Di386
os.name=3DLinux
osgi.arch=3Dx86
osgi.bundles=3Dorg.eclipse.equinox.common@2:start, org.eclipse.update.con=
figurator@3:start, org.eclipse.core.runtime@start
osgi.bundlestore=3D/home/rosec/app/eclipse-3.3-winter/config uration/org.e=
clipse.osgi/bundles
osgi.compatibility.bootdelegation=3Dtrue
osgi.configuration.area=3Dfile:/home/rosec/app/eclipse-3.3-w inter/configu=
ration/
osgi.framework=3Dfile:/home/rosec/app/eclipse-3.3-winter/plu gins/org.ecli=
pse.osgi_3.3.2.R33x_v20080105.jar
osgi.framework.beginningstartlevel=3D1
osgi.framework.shape=3Djar
osgi.framework.version=3D3.3.2.R33x_v20080105
osgi.install.area=3Dfile:/home/rosec/app/eclipse-3.3-winter/
osgi.instance.area=3Dfile:/home/rosec/eclipse/workspace-3.3- old/
osgi.instance.area.default=3Dfile:/home/rosec/workspace/
osgi.logfile=3D/home/rosec/eclipse/workspace-3.3-old/.metada ta/.log
osgi.manifest.cache=3D/home/rosec/app/eclipse-3.3-winter/con figuration/or=
g.eclipse.osgi/manifests
osgi.nl=3Den_US
osgi.os=3Dlinux
osgi.splashLocation=3D/home/rosec/app/eclipse-3.3-winter/plu gins/org.ecli=
pse.platform_3.3.3.r33x_r20080129/splash.bmp
osgi.splashPath=3Dplatform:/base/plugins/org.eclipse.platfor m
osgi.syspath=3D/home/rosec/app/eclipse-3.3-winter/plugins
osgi.ws=3Dgtk
path.separator=3D:
sun.arch.data.model=3D32
sun.boot.class.path=3D/usr/java/jrockit-R27.5.0-jdk1.5.0_14/ jre/lib/i386/=
jrockit/jrockit1.5.0.jar:/usr/java/jrockit-R27.5.0-jdk1.5.0_ 14/jre/lib/i3=
86/jrockit/jmapi.jar:/usr/java/jrockit-R27.5.0-jdk1.5.0_14/j re/lib/i386/j=
rockit/jmxmapi.jar:/usr/java/jrockit-R27.5.0-jdk1.5.0_14/jre /lib/i386/jro=
ckit/rmp.jar:/usr/java/jrockit-R27.5.0-jdk1.5.0_14/jre/lib/i 386/jrockit/l=
atency.jar:/usr/java/jrockit-R27.5.0-jdk1.5.0_14/jre/lib/rt. jar:/usr/java=
/jrockit-R27.5.0-jdk1.5.0_14/jre/lib/i18n.jar:/usr/java/jroc kit-R27.5.0-j=
dk1.5.0_14/jre/lib/sunrsasign.jar:/usr/java/jrockit-R27.5.0- jdk1.5.0_14/j=
re/lib/jsse.jar:/usr/java/jrockit-R27.5.0-jdk1.5.0_14/jre/li b/jce.jar:/us=
r/java/jrockit-R27.5.0-jdk1.5.0_14/jre/lib/charsets.jar:/usr /java/jrockit=
-R27.5.0-jdk1.5.0_14/jre/classes
sun.boot.library.path=3D/usr/java/jrockit-R27.5.0-jdk1.5.0_1 4/jre/lib/i38=
6
sun.cpu.endian=3Dlittle
sun.cpu.isalist=3D
sun.desktop=3Dgnome
sun.io.unicode.encoding=3DUnicodeLittle
sun.java.launcher=3DSUN_STANDARD
sun.jnu.encoding=3DANSI_X3.4-1968
sun.management.compiler=3DBEA JRockit(R) Optimizing Compiler
sun.os.patch.level=3Dunknown
user.country=3DUS
user.dir=3D/home/rosec
user.home=3D/home/rosec
user.language=3Den
user.name=3Drosec
user.timezone=3DMST7MDT
*** Features:
org.eclipse.ajdt (1.5.0.200706070619) "AspectJ Development Tools"
org.eclipse.ajdt.source (1.5.0.200706070619) "Eclipse AspectJ Development=
Tools Source Code"
org.eclipse.cvs (1.0.2.r33x_r20080129-7C79_B_GLJwq3I9ZCD8L_) "Eclipse CVS=
Client"
org.eclipse.cvs.source (1.0.2.r33x_r20080129-7C79_B_GLJwq3I9ZCD8L_) "Ecli=
pse CVS Client SDK"
org.eclipse.datatools.connectivity.feature (1.5.2.200802201) "Data Tools =
Platform Connectivity Plug-in"
org.eclipse.datatools.connectivity.oda.designer.feature (1.5.2.200802201)=
"DTP ODA Designer UI Framework Plug-in"
org.eclipse.datatools.connectivity.oda.feature (1.5.2.200802201) "DTP Ope=
n Data Access"
org.eclipse.datatools.doc.user (1.5.2.200802201) "Data Tools Platform Use=
r Guide"
org.eclipse.datatools.enablement.apache.derby.feature (1.5.2.200802201) "=
High-level Sybase Enablement Plug-in"
org.eclipse.datatools.enablement.feature (1.5.2.200802201) "Eclipse Data =
Tools Platform Enablement"
org.eclipse.datatools.enablement.hsqldb.feature (1.5.2.200802201) "Eclips=
e Data Tools Platform Enablement"
org.eclipse.datatools.enablement.ibm.feature (1.5.2.200802201) "Eclipse D=
org.eclipse.datatools.enablement.jdbc.feature (1.5.2.200802201) "High-lev=
org.eclipse.datatools.enablement.msft.feature (1.5.2.200802201) "Eclipse =
org.eclipse.datatools.enablement.mysql.feature (1.5.2.200802201) "Eclipse=
org.eclipse.datatools.enablement.oda.designer.feature (1.5.2.200802201) "=
Eclipse Data Tools Platform XML ODA Designer"
org.eclipse.datatools.enablement.oda.feature (1.5.2.200802201) "Eclipse D=
ata Tools Platform XML ODA Runtime Driver"
org.eclipse.datatools.enablement.oracle.feature (1.5.2.200802201) "Eclips=
org.eclipse.datatools.enablement.postgresql.feature (1.5.2.200802201) "Ec=
lipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.sybase.feature (1.5.2.200802201) "High-l=
org.eclipse.datatools.modelbase.feature (1.5.2.200802201) "Eclipse Data T=
ools Platform SQLModel Plug-in"
org.eclipse.datatools.sqldevtools.feature (1.5.2.200802201) "Eclipse Data=
Tools Platform SQL Tools Common UI Plug-in"
org.eclipse.dltk.core (0.9.2.v20080226-1047-08O78E8IaRUDKuX65LAUY) "Eclip=
se Dynamic Languages Toolkit (Incubation)"
org.eclipse.dltk.tcl (0.9.2.v20080226-1047-07z3CQMUYYGcJx4N998) "Tcl Deve=
lopment Tools (Incubation)"
org.eclipse.emf (2.3.2.v200802051830) "Eclipse Modeling Framework (EMF)"
org.eclipse.emf.codegen (2.3.1.v200802051830) "EMF Template Code Generato=
r"
org.eclipse.emf.codegen.ecore (2.3.2.v200802051830) "EMF Ecore Code Gener=
ation"
org.eclipse.emf.codegen.ecore.ui (2.3.1.v200802051830) "EMF Ecore Code Ge=
neration UI"
org.eclipse.emf.codegen.ui (2.3.1.v200802051830) "EMF Template Code Gener=
ator UI"
org.eclipse.emf.common (2.3.1.v200802051830) "EMF Common"
org.eclipse.emf.common.ui (2.3.1.v200802051830) "EMF Common UI"
org.eclipse.emf.converter (2.3.1.v200802051830) "EMF Model Convert Suppor=
t"
org.eclipse.emf.ecore (2.3.2.v200802051830) "EMF Ecore"
org.eclipse.emf.ecore.edit (2.3.1.v200802051830) "EMF Ecore Edit Support"=
org.eclipse.emf.ecore.editor (2.3.1.v200802051830) "Sample Ecore Editor"
org.eclipse.emf.ecore.sdo (2.3.1.v200802051830) "EMF Service Data Objects=
(SDO)"
org.eclipse.emf.edit (2.3.2.v200802051830) "EMF Edit"
org.eclipse.emf.edit.ui (2.3.1.v200802051830) "EMF Edit UI"
org.eclipse.emf.mapping (2.3.1.v200802051830) "EMF Mapping "
org.eclipse.emf.mapping.ecore (2.3.1.v200802051830) "Eclipse Modeling Fra=
mework (EMF) - org.eclipse.emf.mapping.ecore"
org.eclipse.emf.mapping.ecore.editor (2.3.1.v200802051830) "Eclipse Model=
ing Framework (EMF) - org.eclipse.emf.mapping.ecore.editor"
org.eclipse.emf.mapping.ui (2.3.1.v200802051830) "EMF Mapping UI"
org.eclipse.gef (3.3.2.v20080129) "Graphical Editing Framework"
org.eclipse.jdt (3.3.2.r33x_r20080129-7o7jE7_EDhYDiyVEnjb1pFd7ZGD7) "Ecli=
pse Java Development Tools"
org.eclipse.jdt.source (3.3.2.r33x_r20080129-7o7jE7_EDhYDiyVEnjb1pFd7ZGD7=
) "Eclipse Java Development Tools SDK"
org.eclipse.jst (2.0.2.v200802150100-7B-7_8dDTOvmuz0di_U5vgUfz0em) "J2EE =
Standard Tools (JST)"
org.eclipse.mylyn_feature (2.3.0.v20080225-2200) "Mylyn"
org.eclipse.mylyn.bugzilla_feature (2.3.0.v20080225-2200) "Mylyn"
org.eclipse.mylyn.context_feature (2.3.0.v20080225-2200) "Mylyn"
org.eclipse.mylyn.ide_feature (2.3.0.v20080225-2200) "Mylyn"
org.eclipse.mylyn.java_feature (2.3.0.v20080225-2200) "Mylyn"
org.eclipse.mylyn.pde_feature (2.3.0.v20080225-2200) "Mylyn"
org.eclipse.pde (3.3.3.r33x_r20080129-7N7M5DQVIA_6oJsEFkEL) "Eclipse Plug=
-in Development Environment"
org.eclipse.pde.source (3.3.3.r33x_r20080129-7N7M5DQVIA_6oJsEFkEL) "Eclip=
se Plug-in Development Environment Developer Resources"
org.eclipse.platform (3.3.3.r33x_r20080129-_19UEl7Ezk_gXF1kouft) "Eclipse=
Platform"
org.eclipse.platform.source (3.3.3.r33x_r20080129-_19UEl7Ezk_gXF1kouft) "=
Eclipse Platform Plug-in Developer Resources"
org.eclipse.rcp (3.3.3.r33x_r20080129-8y8eE9UEUWI6qujeED0xT7bc) "Eclipse =
RCP"
org.eclipse.rcp.source (3.3.3.r33x_r20080129-8y8eE9UEUWI6qujeED0xT7bc) "E=
clipse RCP Plug-in Developer Resources"
org.eclipse.sdk (3.3.3.r33x_r20080129-7M7J7LB-u3aphGW6o3_VmiVfGXWO) "Ecli=
pse Project SDK"
org.eclipse.tptp.monitoring (4.4.2.v200802070100-7c7KEK28DcIJUKhJAIiNP) "=
TPTP Monitoring"
org.eclipse.tptp.monitoring.doc.user (4.3.102.v200802070100-774Aj0r733I37=
3F3533) "TPTP Monitoring Project Documentation"
org.eclipse.tptp.monitoring.examples (4.3.102.v200802070100-328a-w3119131=
91211) "User examples for the TPTP Monitoring Tools Plugins"
org.eclipse.tptp.monitoring.instrumentation (4.3.2.v200802070100-7A7951mA=
55S5A5S5855) "TPTP Instrumentation Monitoring "
org.eclipse.tptp.monitoring.la.core (4.4.2.v200802070100-7A78_A1mA55R5E5K=
5855) "Monitoring Log Analyzer Core"
org.eclipse.tptp.monitoring.managedagent (4.4.2.v200802070100-7E7D8f2hE77=
c7E7Z7A77) "Managed Agent Plugin"
org.eclipse.tptp.monitoring.managedagent.agents (4.4.100.v200802050100-33=
8Y-w311912371211) "JMX Managed Agent"
org.eclipse.tptp.monitoring.mx4j.jmx (4.4.1.v200802221314-2-2-w3119131612=
11) "MX4J"
org.eclipse.tptp.monitoring.profile.server (4.2.102.v200802070100-318a-w3=
11913191211) "TPTP Profile On Server Logging Utility"
org.eclipse.tptp.platform.analysis (4.4.2.v200802070100-7E7_Du2hE77b7L7X7=
A77) "TPTP Analysis"
org.eclipse.tptp.platform.analysis.codereview.java (4.4.101.v200802070100=
-777730r733I373I3533) "Java Code Review Plug-in"
org.eclipse.tptp.platform.analysis.engine (4.3.200.v200709030100-773Dp0r7=
33H3D3A3533) "TPTP Analysis Engine"
org.eclipse.tptp.platform.core (4.4.100.v200709030100-8Q82EeRJEPilTjotXnO=
r2) "TPTP Platform"
org.eclipse.tptp.platform.core.doc.user (4.3.200.v200709030100-7A6E9w1mA5=
5Q5N6J5855) "TPTP Platform Project Documentation"
org.eclipse.tptp.platform.doc.user (4.3.200.v200709030100-7A77E8O08IKQLvA=
sOHBfAU_O9B66) "TPTP Platform Project Documentation"
org.eclipse.tptp.platform.examples (4.3.200.v200709030100-32_7-w31181_141=
211) "TPTP Platform Examples"
org.eclipse.tptp.platform.instrumentation.ui (4.2.100.v200709050100-321-w=
311913191211) "Instrument Core UI"
org.eclipse.tptp.platform.integration.pde (4.4.1.v200802050100-330-w31191=
3161211) "TPTP Platform Integration PDE"
org.eclipse.tptp.platform.jvmti (4.3.100.v200709030100-7777_70r733I377759=
5A) "TPTP JVMTI Profiler Client"
org.eclipse.tptp.platform.la.core (4.3.200.v200709030100-328a-w3119131912=
11) "Log Analysis Core"
org.eclipse.tptp.platform.lta (4.3.200.v200709030100-773CG0r733H3D584747)=
"TPTP Log and Trace Analyzer"
org.eclipse.tptp.platform.probekit (4.3.200.v200709030100-7E5EFB2hE77Z7Z7=
K7A77) "TPTP ProbeKit"
org.eclipse.tptp.platform.probekit.doc.user (4.3.200.v200709030100-31_7-w=
31181_141211) "Probekit User Documentation"
org.eclipse.tptp.platform.profile.server (4.3.100.v200709030100-7E79_C2hE=
77b7L9R8C8A) "TPTP Profile on Server"
org.eclipse.tptp.platform.report (4.2.200.v200709030100-7A5Dq1mA55R5H5H58=
55) "TPTP Charting Service"
org.eclipse.tptp.platform.samples (4.3.200.v200709030100-7A4E9x1mA55Q5O5F=
5855) "TPTP Platform Samples"
org.eclipse.tptp.platform.statistical.ui (4.1.400.v200709030100-772Dq0r73=
3H3D584A43) "TPTP Statistical UI"
org.eclipse.tptp.platform.trace (4.3.200.v200709030100-7E7ADs2hE77a7S9M8G=
87) "TPTP Platform Trace"
org.eclipse.wst (2.0.2.v200802150100-7C-7C8k0JWR293WFMOOObjNnnqho) "Web S=
tandard Tools (WST)"
org.eclipse.xsd (2.3.2.v200802051830) "XML Schema Infoset Model (XSD)"
org.eclipse.xsd.edit (2.3.0.v200802051830) "XML Schema Edit Framework"
org.hibernate.eclipse.feature (3.2.0.GA) "Hibernate Core Plugin"
org.maven.ide.eclipse.feature (0.9.1.200803311600) "Maven Integration for=
Eclipse"
org.maven.ide.eclipse.mylyn.feature (0.9.1.200803311600) "Maven Integrati=
on for Eclipse"
org.maven.ide.eclipse.subclipse.feature (0.9.1.200803311600) "Maven Integ=
ration for Eclipse"
org.tigris.subversion.subclipse (1.2.4) "SVN Team Provider Core"
org.tigris.subversion.subclipse.mylyn (2.0.0) "Subclipse Integration for =
Mylar"
*** Plug-in Registry:
com.ibm.icu (3.6.1.v20070906) "International Components for Unicode for J=
ava (ICU4J)" [Active]
com.ibm.icu.source (3.6.1.v20070906) "International Components for Unicod=
e for Java (ICU4J) source plug-in" [Resolved]
com.jcraft.jsch (0.1.31) "JSch" [Resolved]
com.planet.core360.ebi (1.2.0) "EBI Plugin" [Active]
de.babe.eclipse.plugins.QuickREx (3.5.0) "QuickREx Plug-in" [Starting]
javax.servlet (2.4.0.v200706111738) "Servlet API Bundle" [Resolved]
javax.servlet.jsp (2.0.0.v200706191603) "Java Server Pages API Bundle" [R=
esolved]
javax.servlet.jsp.source (2.0.0.v200706191603) "Java Server Pages API Sou=
rce Bundle" [Resolved]
javax.servlet.source (2.4.0.v200706111738) "Servlet API Source Bundle" [R=
esolved]
javax.wsdl (1.4.0.v200706111329) "WSDL4J" [Resolved]
javax.wsdl15 (1.5.1.v200705290614) "WSDL4J" [Resolved]
javax.xml.rpc (1.1.0.v200706111329) "JAX-RPC" [Resolved]
javax.xml.soap (1.2.0.v200706111329) "SAAJ" [Resolved]
net.sf.jadclipse (3.3.0) "JadClipse" [Active]
net.sourceforge.lpg.lpgjavaruntime (1.1.0.v200711021030) "SourceForge LPG=
" [Resolved]
org.adarsh.jutils (3.1.0) "JUtils Plug-in" [Starting]
org.apache.ant (1.7.0.v200706080842) "Apache Ant" [Resolved]
org.apache.ant.source (1.7.0.v200706080842) "Apache Ant Source" [Resolved=
org.apache.axis (1.4.0.v200706191647) "Apache Web Services" [Resolved]
org.apache.batik.bridge (1.6.0.v200706111724) "Apache Batik Bridge/GVT/Sc=
ripting" [Resolved]
org.apache.batik.css (1.6.0.v200706111724) "Apache Batik CSS" [Resolved]
org.apache.batik.dom (1.6.0.v200706111724) "Apache Batik DOM" [Resolved]
org.apache.batik.dom.svg (1.6.0.v200706111724) "Apache Batik SVG DOM" [Re=
solved]
org.apache.batik.ext.awt (1.6.0.v200706111724) "Apache Batik AWT Utilitie=
s" [Resolved]
org.apache.batik.extension (1.6.0.v200706111724) "Apache Batik Extension"=
[Resolved]
org.apache.batik.parser (1.6.0.v200706111724) "Apache Batik Parser" [Reso=
lved]
org.apache.batik.pdf (1.6.0.v200706111329) "Bundle-Name" [Resolved]
org.apache.batik.svggen (1.6.0.v200706111724) "Apache Batik SVG Generatio=
n" [Resolved]
org.apache.batik.swing (1.6.0.v200706111724) "Apache Batik Swing" [Resolv=
ed]
org.apache.batik.transcoder (1.6.0.v200706111724) "Apache Batik Transcode=
r" [Resolved]
org.apache.batik.util (1.6.0.v200706111724) "Apache Batik Utilities" [Res=
olved]
org.apache.batik.util.gui (1.6.0.v200706111724) "Apache Batik GUI Utiliti=
es" [Resolved]
org.apache.batik.xml (1.6.0.v200706111724) "Apache Batik XML" [Resolved]
org.apache.cactus (1.7.2.v200606181221) "Cactus Resource Plug-in" [Starti=
ng]
org.apache.commons.discovery (0.2.0.v200706111329) "Jakarta-Commons Disco=
very" [Resolved]
org.apache.commons.el (1.0.0.v200706111724) "Apache Commons JSP 2.0 Expre=
ssion Language Interpreter" [Resolved]
org.apache.commons.el.source (1.0.0.v200706111724) "Apache Commons JSP 2.=
0 Expression Language Interpreter Source" [Resolved]
org.apache.commons.logging (1.0.4.v200706111724) "Apache Commons Logging =
Plug-in" [Resolved]
org.apache.commons.logging.source (1.0.4.v200706111724) "Apache Commons L=
ogging Plug-in Source" [Resolved]
org.apache.jasper (5.5.17.v200706111724) "Apache Jasper 2 Plug-in" [Resol=
ved]
org.apache.jasper.source (5.5.17.v200706111724) "Apache Jasper 2 Source P=
lug-in" [Resolved]
org.apache.log4j (1.2.13.v200706111418) "Apache Jakarta log4j Plug-in" [R=
esolved]
org.apache.lucene (1.9.1.v200706111724) "Apache Lucene" [Resolved]
org.apache.lucene.analysis (1.9.1.v200706181610) "Apache Lucene Analysis"=
[Resolved]
org.apache.lucene.analysis.source (1.9.1.v200706181610) "Apache Lucene An=
alysis Source" [Resolved]
org.apache.lucene.source (1.9.1.v200706111724) "Apache Lucene Source" [Re=
solved]
org.apache.wsil4j (1.0.0.v200706111329) "WSIL4J" [Resolved]
org.apache.xerces (2.8.0.v200705301630) "Apache Xerces-J" [Resolved]
org.apache.xml.resolver (1.1.0.v200705310020) "Apache XmlResolver" [Resol=
ved]
org.aspectj.ajde (1.5.4.200705211336) "AspectJ" [Active]
org.aspectj.runtime (1.5.4.200705211336) "AspectJ Runtime" [Resolved]
org.aspectj.weaver (1.5.4.200705211336) "AspectJ Weaver" [Resolved]
org.eclipse.ajdt.core (1.5.0.200706070619) "AspectJ Development Tools Cor=
e" [Active]
org.eclipse.ajdt.doc.user (1.5.0.200706070619) "AspectJ Development Tools=
User Documentation" [Resolved]
org.eclipse.ajdt.examples (1.5.0.200706070619) "AspectJ Examples" [Starti=
ng]
org.eclipse.ajdt.pde.build (1.5.0.200706070619) "AspectJ Plug-in Developm=
ent Environment Build Support" [Starting]
Tools Source Code" [Resolved]
org.eclipse.ajdt.ui (1.5.0.200706070619) "AspectJ Development Tools UI" [=
Active]
org.eclipse.ant.core (3.1.200.v20070522) "Ant Build Tool Core" [Starting]=
org.eclipse.ant.ui (3.2.200.v20070825_r331) "Ant UI" [Starting]
org.eclipse.aspectj (1.5.0.200706070619) "AspectJ Development Tools" [Sta=
rting]
org.eclipse.compare (3.3.2.r33x_20080128) "Compare Support" [Active]
org.eclipse.contribution.visualiser (2.2.0.200706070619) "Visualiser Plug=
-in" [Active]
org.eclipse.contribution.xref.core (1.5.0.200706070619) "Cross Reference =
Core Plugin" [Active]
org.eclipse.contribution.xref.ui (1.5.0.200706070619) "Cross Reference UI=
Plugin" [Active]
org.eclipse.core.boot (3.1.100.v20060603) "Core Boot" [Starting]
org.eclipse.core.commands (3.3.0.I20070605-0010) "Commands" [Resolved]
org.eclipse.core.contenttype (3.2.100.v20070319) "Eclipse Content Mechani=
sm" [Active]
org.eclipse.core.databinding (1.0.1.M20070822-0800) "JFace Data Binding" =
[Resolved]
org.eclipse.core.databinding.beans (1.0.1.M20070910-0800b) "JFace Data Bi=
nding for JavaBeans" [Resolved]
org.eclipse.core.expressions (3.3.0.v20070606-0010) "Expression Language"=
[Active]
org.eclipse.core.filebuffers (3.3.1.r331_v20070829) "File Buffers" [Activ=
e]
org.eclipse.core.filesystem (1.1.0.v20070606) "Core File Systems" [Active=
org.eclipse.core.filesystem.linux.x86 (1.1.0.v20070416) "Core File System=
for Linux" [Resolved]
org.eclipse.core.jobs (3.3.1.R33x_v20070709) "Eclipse Jobs Mechanism" [Ac=
tive]
org.eclipse.core.net (1.0.1.r33x_20070709) "Internet Connection Managemen=
t" [Active]
org.eclipse.core.resources (3.3.1.R33x_v20080205) "Core Resource Manageme=
nt" [Active]
org.eclipse.core.resources.compatibility (3.2.100.v20070502) "Core Resour=
ce Management Compatibility Fragment" [Resolved]
org.eclipse.core.runtime (3.3.100.v20070530) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.1.200.v20070502) "Core Runtime =
Plug-in Compatibility" [Active]
org.eclipse.core.runtime.compatibility.auth (3.2.100.v20070502) "Authoriz=
ation Compatibility Plug-in" [Active]
org.eclipse.core.runtime.compatibility.registry (3.2.100.v20070316) "Ecli=
pse Registry Compatibility Fragment" [Resolved]
org.eclipse.core.variables (3.2.0.v20070426) "Core Variables" [Active]
org.eclipse.cvs (1.0.2.r33x_r20080129) "Eclipse CVS Client" [Starting]
pse CVS Client SDK" [Resolved]
org.eclipse.datatools.connectivity (1.0.1.200802191) "Data Tools Platform=
Connectivity Plug-in" [Starting]
org.eclipse.datatools.connectivity.db.derby (1.0.0.200706071) "Eclipse Da=
ta Tools Platform Apache Derby Plug-in" [Starting]
org.eclipse.datatools.connectivity.db.generic (1.0.0.200706071) "Eclipse =
Data Tools Platform Generic DB Connectivity Plug-in" [Starting]
org.eclipse.datatools.connectivity.db.generic.ui (1.0.1.200708201) "Eclip=
se Data Tools Platform Generic DB UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.dbdefinition.derby (1.0.0.200706071) "=
Eclipse Data Tools Platform Apache Derby Database Definition" [Starting]
org.eclipse.datatools.connectivity.dbdefinition.genericJDBC (1.0.0.200706=
071) "Eclipse Data Tools Platform DBDefinition Generic JDBC Plug-in" [Sta=
rting]
org.eclipse.datatools.connectivity.derby (1.0.0.200706071) "Eclipse Data =
Tools Platform Derby Plug-in" [Starting]
org.eclipse.datatools.connectivity.derby.ui (1.0.0.200706071) "Eclipse Da=
ta Tools Platform Apache Derby UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.oda (3.1.1.200711081) "DTP Open Data A=
ccess" [Starting]
org.eclipse.datatools.connectivity.oda.consumer (3.1.2.200710011) "DTP OD=
A Consumer Helper Component Plug-in" [Starting]
org.eclipse.datatools.connectivity.oda.design (3.0.5.200709071) "DTP ODA =
Design Session Model" [Starting]
org.eclipse.datatools.connectivity.oda.design.ui (3.0.6.200710051) "DTP O=
DA Designer UI Framework Plug-in" [Starting]
org.eclipse.datatools.connectivity.oda.flatfile (3.0.5.200711091) "Eclips=
e Data Tools Platform Flat File ODA Runtime Driver" [Starting]
org.eclipse.datatools.connectivity.oda.flatfile.ui (3.0.5.200711121) "Ecl=
ipse Data Tools Platform Flat File ODA Designer" [Starting]
org.eclipse.datatools.connectivity.oda.profile (3.0.6.200710181) "DTP ODA=
Connection Profile Framework Plug-in" [Starting]
org.eclipse.datatools.connectivity.oda.template.ui (3.0.6.200710261) "DTP=
ODA New Plug-in Template Wizard" [Starting]
org.eclipse.datatools.connectivity.sqm.core (1.0.1.200801111) "Eclipse Da=
ta Tools Platform SQM Core Plug-in" [Starting]
org.eclipse.datatools.connectivity.sqm.core.ui (1.0.1.200708201) "Eclipse=
Data Tools Platform SQM UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.sqm.fe.ui (1.0.0.200706071) "Eclipse D=
ata Tools Platform FE UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.sqm.fe.ui.actions (1.0.0.200706071) "E=
clipse Data Tools Platform FE Ui Actions Plug-in" [Starting]
org.eclipse.datatools.connectivity.sqm.server.ui (1.0.0.200709141) "Eclip=
se Data Tools Platform Server UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.ui (1.0.1.200708231) "Data Tools Platf=
orm Connectivity UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.ui.dse (1.0.1.200709171) "Eclipse Data=
Tools Platform Data Source Explorer Plug-in" [Starting]
org.eclipse.datatools.doc.user (1.0.0.200706071) "Data Tools Platform Use=
r Guide" [Starting]
org.eclipse.datatools.enablement.finfo (1.5.1.200708161) "Eclipse Data To=
ols Platform Enablement" [Starting]
org.eclipse.datatools.enablement.hsqldb (1.0.0.200706071) "Eclipse Data T=
ools Platform Hypersonic DB Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.iseries.dbdefinitio n (1.0.0.2007=
06071) "DB2 UDB iSeries Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.iseries.profile (1.0.0.200706071=
) "Eclipse Data Tools Platform IBM DB2 UDB iSeries Plug-in" [Resolved]
org.eclipse.datatools.enablement.ibm.db2.luw.dbdefinition (1.0.0.20070607=
1) "Eclipse Data Tools Platform DB2 UDB Database Definition Plug-in" [Sta=
rting]
org.eclipse.datatools.enablement.ibm.db2.luw.profile (1.0.0.200706071) "E=
clipse Data Tools Platform IBM DB2 UDB LUW Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.zseries.dbdefinitio n (1.0.0.2007=
06071) "DB2 UDB Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.zseries.profile (1.0.0.200706071=
) "Eclipse Data Tools Platform IBM DB2 UDB zSeries Plug-in" [Resolved]
org.eclipse.datatools.enablement.ibm.informix.dbdefinition (1.0.0.2007060=
71) "Eclipse Data Tools Platform Informix Database Definition Plug-in" [S=
tarting]
org.eclipse.datatools.enablement.ibm.informix.profile (1.0.0.200706071) "=
Eclipse Data Tools Platform Informix Plug-in" [Resolved]
org.eclipse.datatools.enablement.msft.sqlserver.dbdefinition (1.0.0.20070=
6071) "Eclipse Data Tools Platform SQL Server Database Definition Plug-in=
" [Starting]
org.eclipse.datatools.enablement.msft.sqlserver.profile (1.0.1.200709041)=
"Eclipse Data Tools Platform Microsoft SQL Server Plug-in" [Starting]
org.eclipse.datatools.enablement.mysql (1.0.0.200706071) "Eclipse Data To=
ols Platform MySQL enablement plug-in" [Starting]
org.eclipse.datatools.enablement.mysql.dbdefinition (1.0.1.200709181) "Ec=
lipse Data Tools Platform MySQL Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.mysql.profile (1.0.0.200706071) "Eclipse=
Data Tools Platform MySQL Plug-in" [Starting]
org.eclipse.datatools.enablement.oda.ws (1.0.1.20071218) "Eclipse Data To=
ols Platform Web Services ODA Runtime Driver" [Starting]
org.eclipse.datatools.enablement.oda.ws.ui (1.0.2.200711191) "Eclipse Dat=
a Tools Platform Web Services ODA Designer" [Starting]
org.eclipse.datatools.enablement.oda.xml (1.0.3.200802141) "Eclipse Data =
Tools Platform XML ODA Runtime Driver" [Starting]
org.eclipse.datatools.enablement.oda.xml.ui (1.0.3.200711191) "Eclipse Da=
ta Tools Platform XML ODA Designer" [Starting]
org.eclipse.datatools.enablement.oracle.dbdefinition (1.0.0.200706071) "E=
clipse Data Tools Platform Oracle Database Definition Plug-in" [Starting]=
org.eclipse.datatools.enablement.oracle.profile (1.0.0.200706151) "Eclips=
e Data Tools Platform Oracle Plug-in" [Starting]
org.eclipse.datatools.enablement.postgresql.dbdefinition (1.0.0.200706071=
) "PostgreSQL DB Definition" [Resolved]
org.eclipse.datatools.enablement.postgresql.profile (1.0.1.200711121) "Po=
stgreSQL Connection Profile and Driver Template Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase (1.0.1.200707131) "High-level Syb=
ase Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.asa (1.0.0.200706071) "Sybase ASA=
Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.asa.models (1.0.0.200706071) "Syb=
ase ASA SQL Model" [Starting]
org.eclipse.datatools.enablement.sybase.ase.dbdefinition (1.0.0.200706071=
) "Eclipse Data Tools Platform Sybase Database Definition Plug-in" [Start=
ing]
org.eclipse.datatools.enablement.sybase.ase.profile (1.0.0.200706071) "Ec=
lipse Data Tools Platform Sybase ASE Plug-in" [Starting]
org.eclipse.datatools.help (1.5.0.200706181) "Data Tools Platform Help Ut=
ilities" [Resolved]
org.eclipse.datatools.modelbase.dbdefinition (1.0.0.200706071) "Eclipse D=
ata Tools Platform DBDefinition Model" [Starting]
org.eclipse.datatools.modelbase.derby (1.0.0.200706071) "Derby Plug-in" [=
Starting]
org.eclipse.datatools.modelbase.sql (1.0.0.200708161) "Eclipse Data Tools=
Platform SQLModel Plug-in" [Starting]
org.eclipse.datatools.modelbase.sql.edit (1.0.0.200706071) "Eclipse Data =
Tools Platform SQLModel Edit Plug-in" [Starting]
org.eclipse.datatools.modelbase.sql.query (1.0.0.200706151) "Eclipse Data=
Tools Platform SQL Query Model Plugin" [Starting]
org.eclipse.datatools.modelbase.sql.xml.query (1.0.0.200706151) "Eclipse =
Data Tools Platform SQL XML Query Model Plugin" [Starting]
org.eclipse.datatools.oda.cshelp (1.0.0.200708161) "DTP ODA Context-sensi=
tive Help" [Starting]
org.eclipse.datatools.sqltools.common.ui (1.0.0.200708161) "Eclipse Data =
Tools Platform SQL Tools Common UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.data.core (1.0.0.200712191) "Data Core Plu=
gin" [Starting]
org.eclipse.datatools.sqltools.data.ui (1.0.1.200711091) "Data UI Plugin"=
[Starting]
org.eclipse.datatools.sqltools.db.derby (1.0.0.200706071) "Eclipse Data T=
ools Platform Derby SQL Tools Plug-in" [Starting]
org.eclipse.datatools.sqltools.db.generic (1.0.0.200706131) "Eclipse Data=
Tools Platform SQL Tools Generic Database Plug-in" [Starting]
org.eclipse.datatools.sqltools.debugger.core (1.0.0.200709251) "Eclipse D=
ata Tools Platform SQL Debugger Framework" [Starting]
org.eclipse.datatools.sqltools.editor.core (1.0.0.200709261) "Eclipse Dat=
a Tools Platform SQL Editor Core Plug-in" [Starting]
org.eclipse.datatools.sqltools.parsers.sql (1.0.0.200801071) "Eclipse Dat=
a Tools Platform SQL Parser Plugin" [Starting]
org.eclipse.datatools.sqltools.parsers.sql.lexer (1.0.0.200801071) "Eclip=
se Data Tools Platform Lexer Plug-in" [Starting]
org.eclipse.datatools.sqltools.parsers.sql.query (1.0.0.200711281) "Eclip=
se Data Tools Platform SQL Query Parser Plugin" [Starting]
org.eclipse.datatools.sqltools.parsers.sql.xml.query (1.0.0.200706151) "E=
clipse Data Tools Platform SQL XML Query Parser Plugin" [Starting]
org.eclipse.datatools.sqltools.plan (1.0.0.200709061) "Eclipse Data Tools=
Platform SQL Execution Plan View Plug-in" [Starting]
org.eclipse.datatools.sqltools.result (1.0.0.200711021) "Eclipse Data Too=
ls Platform SQL Results View Plug-in" [Starting]
org.eclipse.datatools.sqltools.routineeditor (1.0.0.200708161) "Eclipse D=
ata Tools Platform SQL Tools Routine Editor Plug-in" [Starting]
org.eclipse.datatools.sqltools.sql (1.0.0.200706111) "Eclipse Data Tools =
Platform SQL Core Plug-in" [Starting]
org.eclipse.datatools.sqltools.sqleditor (1.0.0.200709061) "Eclipse Data =
Tools Platform SQL Editor" [Starting]
org.eclipse.datatools.sqltools.sqlscrapbook (1.0.0.200709141) "Eclipse Da=
ta Tools Platform Sqlscrapbook Plug-in" [Starting]
org.eclipse.datatools.sqltools.tabledataeditor (1.0.0.200706071) "Eclipse=
Data Tools Platform Table Data Editor Plug-in" [Starting]
org.eclipse.datatools.sqltools.tablewizard (1.0.0.200710041) "Eclipse Dat=
a Tools Platform Database Table Creation Plug-in" [Starting]
org.eclipse.debug.core (3.3.2.v20080117_r332) "Debug Core" [Active]
org.eclipse.debug.ui (3.3.2.v20080117_r332) "Debug UI" [Active]
org.eclipse.dltk (0.9.0.v20070601) "Eclipse Dynamic Languages Toolkit (In=
cubation)" [Resolved]
org.eclipse.dltk.console (0.9.0.v20070619) "Dynamic Languages Toolkit Con=
sole Core (Incubation)" [Starting]
org.eclipse.dltk.console.ui (0.9.0.v20070619) "Dynamic Languages Toolkit =
Console UI (Incubation)" [Active]
org.eclipse.dltk.core (0.9.2.v20080226-1047) "Dynamic Languages Toolkit C=
ore (Incubation)" [Active]
org.eclipse.dltk.debug (0.9.0.v20070621) "Dynamic Languages Toolkit Debug=
org.eclipse.dltk.debug.ui (0.9.0.v20070621) "Dynamic Languages Toolkit De=
bug UI (Incubation)" [Starting]
org.eclipse.dltk.launching (0.9.1.r09_v20070926) "Dynamic Languages Toolk=
it Launching Core (Incubation)" [Active]
org.eclipse.dltk.tcl (0.9.1.r09_v20070920) "Tcl Development Tools (Incuba=
tion)" [Resolved]
org.eclipse.dltk.tcl.core (0.9.1.r09_v20070920) "Dynamic Languages Toolki=
t Tcl Core (Incubation)" [Active]
org.eclipse.dltk.tcl.debug (0.9.0.v20070620) "Dynamic Languages Toolkit T=
cl Debug Core (Incubation)" [Starting]
org.eclipse.dltk.tcl.debug.ui (0.9.0.v20070619) "Dynamic Languages Toolki=
t Tcl Debug UI (Incubation)" [Starting]
org.eclipse.dltk.tcl.launching (0.9.0.v20070619) "Dynamic Languages Toolk=
it Tcl Launching Core (Incubation)" [Active]
org.eclipse.dltk.tcl.tclchecker (0.9.0.v20070619) "Dynamic Languages Tool=
kit TclChecker Support (Incubation)" [Starting]
org.eclipse.dltk.tcl.ui (0.9.2.v20080226-1047) "Dynamic Languages Toolkit=
Tcl UI (Incubation)" [Active]
org.eclipse.dltk.ui (0.9.2.v20080226-1047) "Dynamic Languages Toolkit Cor=
org.eclipse.dltk.validators.core (0.9.2.v20080226-1047) "Dynamic Language=
s Toolkit Validators Core (Incubation)" [Starting]
org.eclipse.dltk.validators.ui (0.9.2.v20080226-1047) "Dynamic Languages =
Toolkit Validators UI (Incubation)" [Starting]
org.eclipse.draw2d (3.2.100.v20070529) "Graphical Editing Framework Draw2=
d" [Starting]
org.eclipse.emf (2.3.0.v200802051830) "Eclipse Modeling Framework (EMF)" =
[Starting]
org.eclipse.emf.ant (2.3.1.v200802051830) "EMF Ant Tasks" [Starting]
r" [Starting]
ation" [Starting]
org.eclipse.emf.codegen.ecore.ui (2.3.0.v200802051830) "EMF Ecore Code Ge=
neration UI" [Starting]
org.eclipse.emf.codegen.ui (2.3.0.v200802051830) "EMF Template Code Gener=
ator UI" [Starting]
org.eclipse.emf.common (2.3.2.v200802051830) "EMF Common" [Active]
org.eclipse.emf.common.ui (2.3.1.v200802051830) "EMF Common UI" [Starting=
org.eclipse.emf.commonj.sdo (2.3.0.v200802051830) "CommonJ SDO" [Starting=
org.eclipse.emf.converter (2.3.0.v200802051830) "EMF Model Convert Suppor=
t" [Starting]
org.eclipse.emf.ecore (2.3.2.v200802051830) "EMF Ecore" [Active]
org.eclipse.emf.ecore.change (2.3.0.v200802051830) "EMF Ecore Change Mode=
l" [Starting]
org.eclipse.emf.ecore.change.edit (2.3.0.v200802051830) "EMF Ecore Change=
Edit Support" [Starting]
[Starting]
org.eclipse.emf.ecore.editor (2.3.1.v200802051830) "Sample Ecore Editor" =
[Starting]
org.eclipse.emf.ecore.sdo (2.3.0.v200802051830) "EMF Service Data Objects=
(SDO)" [Starting]
org.eclipse.emf.ecore.xmi (2.3.2.v200802051830) "EMF XMI" [Active]
org.eclipse.emf.edit (2.3.2.v200802051830) "EMF Edit" [Starting]
org.eclipse.emf.edit.ui (2.3.1.v200802051830) "EMF Edit UI" [Starting]
org.eclipse.emf.exporter (2.3.0.v200802051830) "EMF Model Export Support"=
[Starting]
org.eclipse.emf.importer (2.3.1.v200802051830) "EMF Model Import Support"=
[Starting]
org.eclipse.emf.importer.ecore (2.3.1.v200802051830) "EMF Ecore Importer"=
[Starting]
org.eclipse.emf.importer.java (2.3.1.v200802051830) "EMF Annotated Java I=
mporter" [Starting]
org.eclipse.emf.importer.rose (2.3.1.v200802051830) "EMF Rose Importer" [=
Starting]
org.eclipse.emf.mapping (2.3.0.v200802051830) "EMF Mapping" [Starting]
org.eclipse.emf.mapping.ecore (2.3.0.v200802051830) "Eclipse Modeling Fra=
mework (EMF) - org.eclipse.emf.mapping.ecore" [Starting]
org.eclipse.emf.mapping.ecore.editor (2.3.0.v200802051830) "Eclipse Model=
ing Framework (EMF) - org.eclipse.emf.mapping.ecore.editor" [Starting]
org.eclipse.emf.mapping.ecore2ecore (2.3.0.v200802051830) "Ecore to Ecore=
Mapping" [Starting]
org.eclipse.emf.mapping.ecore2ecore.editor (2.3.0.v200802051830) "Ecore t=
o Ecore Mapping Editor" [Starting]
org.eclipse.emf.mapping.ecore2xml (2.3.0.v200802051830) "Ecore to XML Map=
ping" [Starting]
org.eclipse.emf.mapping.ecore2xml.ui (2.3.0.v200802051830) "Ecore to XML =
Mapping UI" [Starting]
org.eclipse.emf.mapping.ui (2.3.0.v200802051830) "EMF Mapping UI" [Starti=
ng]
org.eclipse.equinox.app (1.0.1.R33x_v20070828) "Equinox Application Conta=
iner" [Active]
org.eclipse.equinox.common (3.3.0.v20070426) "Common Eclipse Runtime" [Ac=
tive]
org.eclipse.equinox.http.jetty (1.0.1.R33x_v20070816) "Jetty Http Service=
" [Starting]
org.eclipse.equinox.http.registry (1.0.1.R33x_v20071231) "Http Service Re=
gistry Extensions" [Resolved]
org.eclipse.equinox.http.servlet (1.0.1.R33x_v20070816) "Http Services Se=
rvlet" [Starting]
org.eclipse.equinox.jsp.jasper (1.0.1.R33x_v20070816) "Jasper Jsp Support=
Bundle" [Starting]
org.eclipse.equinox.jsp.jasper.registry (1.0.0.v20070607) "Jasper Jsp Reg=
istry Support Plug-in" [Starting]
org.eclipse.equinox.launcher (1.0.1.R33x_v20080118) "Equinox Launcher" [R=
esolved]
org.eclipse.equinox.launcher.gtk.linux.x86 (1.0.3.R33x_v20080118) "Equino=
x Launcher Linux X86 Fragment" [Resolved]
org.eclipse.equinox.preferences (3.2.101.R33x_v20080117) "Eclipse Prefere=
nces Mechanism" [Active]
org.eclipse.equinox.registry (3.3.1.R33x_v20070802) "Extension Registry S=
upport" [Active]
org.eclipse.gef (3.2.102.v20080116) "Graphical Editing Framework" [Starti=
ng]
org.eclipse.help (3.3.2.v20071126_33x) "Help System Core" [Active]
org.eclipse.help.appserver (3.1.200.v20070510) "Help Application Server" =
[Starting]
org.eclipse.help.base (3.3.1.v20070813_33x) "Help System Base" [Starting]=
org.eclipse.help.ui (3.3.2.v20071126_33x) "Help System UI" [Starting]
org.eclipse.help.webapp (3.3.2.v20071102_33x) "Help System Webapp" [Start=
ing]
org.eclipse.hyades.analysis.engine (4.3.201.v200802050100) "Symptom Model=
" [Resolved]
org.eclipse.hyades.execution (4.4.100.v200802221314) "TPTP Platform Execu=
tion Plug-In" [Starting]
org.eclipse.hyades.execution.correlation (4.1.301.v200802050100) "Hyades =
Runtime Correlation Engine" [Resolved]
org.eclipse.hyades.execution.trace (4.1.201.v200802050100) "Hyades Execut=
ion Trace" [Resolved]
org.eclipse.hyades.logging.adapter (4.3.0.v200706010100) "TPTP Monitoring=
Project Generic Log Adapter" [Starting]
org.eclipse.hyades.logging.adapter.ui (4.3.101.v200802050100) "Generic Ad=
apter UI" [Starting]
org.eclipse.hyades.logging.core (4.3.200.v200709030100) "Hyades Logging A=
gent, Common Base Events and Logging Facility Support" [Starting]
org.eclipse.hyades.logging.core.sample (4.1.201.v200802050100) "Sample fo=
r Hyades Logging Agent, Common Base Events and Logging Facility Support" =
[Starting]
org.eclipse.hyades.logging.parsers (4.3.102.v200802070100) "TPTP Monitori=
ng Project Log File Parsers" [Starting]
org.eclipse.hyades.perfmon (4.2.101.v200802050100) "Perfmon StatCon Modul=
e" [Starting]
org.eclipse.hyades.perfmon.agents (4.0.100.v200709070956) "Perfmon StatCo=
n Agents Module" [Resolved]
org.eclipse.hyades.probekit (4.2.300.v200709030100) "Hyades Probekit" [St=
arting]
org.eclipse.hyades.probekit.doc.user (4.2.200.v200709030100) "Probekit Us=
er Documentation" [Starting]
org.eclipse.hyades.probekit.ui (4.1.301.v200802050100) "Probe Editor" [St=
arting]
org.eclipse.hyades.resources.database (4.2.200.v200709030100) "Hyades Cor=
e Resource Extensions" [Resolved]
org.eclipse.hyades.sdb (4.3.101.v200711030100) "Symptom Catalog tool" [St=
arting]
org.eclipse.hyades.statistical.ui (4.2.202.v200802221710) "Statistical UI=
" [Starting]
org.eclipse.hyades.trace.sample (4.1.301.v200802050901) "Samples for the =
TPTP Monitoring Tools Plugins" [Starting]
org.eclipse.hyades.trace.ui (4.4.2.v200802221710) "Hyades Trace Core UI" =
[Starting]
org.eclipse.hyades.ui (4.2.102.v200802080100) "Hyades UI" [Starting]
org.eclipse.jdt (3.3.1.r332_v20080131) "Eclipse Java Development Tools" [=
Resolved]
org.eclipse.jdt.apt.core (3.3.1.R33x_v20071112-2330) "Java Annotation Pro=
cessing Core" [Active]
org.eclipse.jdt.apt.pluggable.core (1.0.1.R33x_v20071002-2100) "Java Comp=
iler Apt IDE" [Installed]
org.eclipse.jdt.apt.ui (3.3.1.R33x_v20071002-2100) "Java Annotation Proce=
ssing UI" [Starting]
org.eclipse.jdt.compiler.apt (1.0.1.R33x_v20071002-2100) "Java Compiler A=
pt" [Installed]
org.eclipse.jdt.compiler.tool (1.0.1.v_793_R33x) "Java Compiler Tool Supp=
ort" [Installed]
org.eclipse.jdt.core (3.3.3.v_793_R33x) "Java Development Tools Core" [Ac=
tive]
org.eclipse.jdt.core.manipulation (1.1.0.v20070606-0010) "Java Code Manip=
ulation Functionality" [Active]
org.eclipse.jdt.debug (3.3.1.v20070719_r331) "JDI Debug Model" [Active]
org.eclipse.jdt.debug.ui (3.2.102.v20071002_r332) "JDI Debug UI" [Active]=
org.eclipse.jdt.doc.isv (3.3.1.r331_v20070913) "Eclipse JDT Plug-in Devel=
oper Guide" [Starting]
org.eclipse.jdt.doc.user (3.3.2.r332_20080116-0900) "Eclipse Java Develop=
ment User Guide" [Starting]
org.eclipse.jdt.junit (3.3.2.r332_20080109-0800) "Java Development Tools =
JUnit support" [Active]
org.eclipse.jdt.junit.runtime (3.3.0.v20070606-0010) "Java Development To=
ols JUnit runtime support" [Resolved]
org.eclipse.jdt.junit4.runtime (1.0.100.v20070606-0010) "Java Development=
Tools JUnit4 runtime support" [Resolved]
org.eclipse.jdt.launching (3.3.2.v20080115_r332) "Java Development Tools =
Launching Support" [Active]
) "Eclipse Java Development Tools SDK" [Resolved]
org.eclipse.jdt.ui (3.3.2.r332_20080128) "Java Development Tools UI" [Act=
ive]
org.eclipse.jem (2.0.100.v200709051030) "Java EMF Model" [Active]
org.eclipse.jem.beaninfo (2.0.0.v200705302225) "Java EMF Model BeanInfo (=
Introspection) Support" [Starting]
org.eclipse.jem.proxy (2.0.0.v200705302225) "Java EMF Model Proxy Support=
" [Starting]
org.eclipse.jem.ui (2.0.0.v200705302225) "Java EMF Model UI" [Starting]
org.eclipse.jem.util (2.0.2.v200802192030) "Java EMF Model Utilities" [Ac=
tive]
org.eclipse.jem.workbench (2.0.1.v200710051600) "Java EMF Model Workbench=
Support" [Active]
org.eclipse.jface (3.3.2.M20080207-0800) "JFace" [Active]
org.eclipse.jface.databinding (1.1.1.M20080207-0800) "JFace Data Binding =
for SWT and JFace" [Resolved]
org.eclipse.jface.text (3.3.2.r332_20071017-0800) "JFace Text" [Resolved]=
org.eclipse.jpt.core (1.0.2.v200802140100) "Java Persistence API Tools - =
Core" [Starting]
org.eclipse.jpt.db (1.0.2.v200802140100) "Java Persistence API Tools - DB=
" [Starting]
org.eclipse.jpt.db.ui (1.0.0.v200705300001) "Java Persistence API Tools -=
DB UI" [Resolved]
org.eclipse.jpt.doc.user (1.0.1.v200709120000) "Java Persistence Document=
ation - Doc" [Starting]
org.eclipse.jpt.gen (1.0.2.v200802140100) "Java Persistence API Tools - E=
ntity Gen" [Resolved]
org.eclipse.jpt.ui (1.0.2.v200802140100) "Java Persistence API Tools - UI=
" [Starting]
org.eclipse.jpt.utility (1.0.2.v200802140100) "Java Persistence API Tools=
- Utility" [Resolved]
org.eclipse.jsch.core (1.0.0.I20070426) "JSch Core" [Active]
org.eclipse.jsch.ui (1.0.1.r33x_20070709) "JSch UI" [Starting]
org.eclipse.jst (1.0.2.v200706120315) "J2EE Standard Tools (JST)" [Resolv=
ed]
org.eclipse.jst.common.annotations.controller (1.1.2.v200708301745) "Anno=
tation Controller Plug-in" [Resolved]
org.eclipse.jst.common.annotations.core (1.1.2.v200706120315) "Annotation=
Core Plug-in" [Resolved]
org.eclipse.jst.common.annotations.ui (1.1.2.v200706120315) "Annotations =
org.eclipse.jst.common.frameworks (1.1.102.v200709122200) "Integration Pl=
ug-in" [Active]
org.eclipse.jst.common.project.facet.core (1.1.1.v200706120315) "Project =
Facet Core (Java Support)" [Starting]
org.eclipse.jst.ejb.doc.user (1.0.300.v200705302225) "EJB docs" [Starting=
org.eclipse.jst.ejb.ui (1.1.102.v200709122200) "WTP EJB UI Plug-in" [Star=
ting]
org.eclipse.jst.j2ee (1.1.106.v200802192030) "J2EE Component" [Active]
org.eclipse.jst.j2ee.core (1.1.104.v200802192030) "J2EE Core Component" [=
Active]
org.eclipse.jst.j2ee.doc.user (1.0.300.v200705302225) "J2EE tools documen=
tation" [Resolved]
org.eclipse.jst.j2ee.ejb (1.1.105.v200802192030) "EJB component Plug-in" =
[Starting]
org.eclipse.jst.j2ee.ejb.annotation.model (1.1.2.v200706120315) "EJB Anno=
tation Model Plug-in" [Starting]
org.eclipse.jst.j2ee.ejb.annotations.emitter (1.1.2.v200708301745) "EJB E=
mitter Plug-in" [Starting]
org.eclipse.jst.j2ee.ejb.annotations.ui (1.1.2.v200706191638) "EJB Annota=
tions Ui Plug-in" [Starting]
org.eclipse.jst.j2ee.ejb.annotations.xdoclet (1.1.3.v200802201934) "Xdocl=
et Annotations Plug-in" [Starting]
org.eclipse.jst.j2ee.infopop (1.0.203.v200706110217) "J2EE tools infopops=
" [Resolved]
org.eclipse.jst.j2ee.jca (1.1.105.v200802192030) "JCA Plug-in" [Starting]=
org.eclipse.jst.j2ee.jca.ui (1.1.100.v200706071630) "WTP JCA UI Plug-in" =
[Starting]
org.eclipse.jst.j2ee.navigator.ui (1.1.102.v200709122200) "J2EE Extension=
s to Common Navigator" [Active]
org.eclipse.jst.j2ee.ui (1.1.103.v200802192030) "WTP J2EE UI Plug-in" [St=
arting]
org.eclipse.jst.j2ee.web (1.1.105.v200802192030) "Web Plug-in" [Active]
org.eclipse.jst.j2ee.webservice (1.1.102.v200802192030) "Web Service Plug=
-in" [Active]
org.eclipse.jst.j2ee.webservice.ui (1.1.103.v200802192030) "WTP Webservic=
e UI Plug-in" [Active]
org.eclipse.jst.j2ee.xdoclet.runtime (1.1.2.v200706120315) "XDocletRuntim=
org.eclipse.jst.jee (1.0.2.v200802192030) "JEE common Plug-in" [Active]
org.eclipse.jst.jee.ejb (1.0.2.v200802192030) "JEE Ejb Plug-in" [Starting=
org.eclipse.jst.jee.ui (1.0.2.v200802192030) "Ui Plug-in" [Starting]
org.eclipse.jst.jee.web (1.0.2.v200802192030) "JEE Web Plug-in" [Starting=
org.eclipse.jst.jsf.common (1.0.2.v200802201120) "JavaServer Faces Tools =
- Common" [Starting]
org.eclipse.jst.jsf.common.ui (1.0.1.v20070912) "JavaServer Faces Tools -=
Common UI" [Starting]
org.eclipse.jst.jsf.core (1.0.2.v200802201120) "JavaServer Faces Tools - =
Core" [Active]
org.eclipse.jst.jsf.doc.user (1.0.1.v20070912) "JavaServer Faces Tools - =
org.eclipse.jst.jsf.facesconfig (1.0.1.v20070912) "JavaServer Faces Tools=
- FacesConfig Model" [Starting]
org.eclipse.jst.jsf.facesconfig.ui (1.0.1.v20070912) "JavaServer Faces To=
ols - FacesConfig Editor" [Starting]
org.eclipse.jst.jsf.standard.tagsupport (1.0.1.v20070912) "JavaServer Fac=
es Tools - Taglibrary Metadata" [Starting]
org.eclipse.jst.jsf.ui (1.0.1.v20070912) "JavaServer Faces Tools - UI" [S=
tarting]
org.eclipse.jst.jsp.core (1.2.1.v200709181730) "Structured Source JSP Mod=
el" [Starting]
org.eclipse.jst.jsp.ui (1.1.201.v200709061102) "SSE JSP Source Editor" [S=
tarting]
org.eclipse.jst.jsp.ui.infopop (1.0.3.v200706110217) "JSP tools infopops"=
[Resolved]
org.eclipse.jst.pagedesigner (1.0.1.v20070912) "JavaServer Faces Tools - =
Web Page Editor" [Starting]
org.eclipse.jst.pagedesigner.jsf.ui (1.0.1.v20070912) "JavaServer Faces T=
ools - Pagedesigner UI" [Starting]
org.eclipse.jst.pagedesigner.jsp.core (1.0.1.v20070912) "JavaServer Faces=
Tools - JSP Core Pagedesigner" [Starting]
org.eclipse.jst.server.core (1.0.205.v20070829b) "Java Server Support" [A=
ctive]
org.eclipse.jst.server.generic.core
Re: 100% cpu usage when opening a class file [message #327930 is a reply to message #327909] |
Thu, 08 May 2008 16:13 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
I'll look into it; I'm a bit under the gun here and can't easily upend
my development environment at this time, but hopefully I can look into
it early next week. Thanks for the pointer.
>> 100% usage for anywhere from 15-120 seconds and eclipse becomes
>> container behaviour and this plays merry havoc with the timeouts for
>> remote calls, so I'm quite motivated to suss out why it's happening.
> There was a bug regarding big JARs on the build path. Can you try
> whether this still happens using 3.4 M7. If so, please file a bug report
> with steps to reproduce. Also, please create some stack dumps while
> waiting and attach them to the bug report.
> Dani
Chris Rose
(780) 577-8433
crose@planetci.com
Current Time: Wed Jul 17 09:00:18 GMT 2024
Powered by FUDForum. Page generated in 0.02654 seconds
