Home » Eclipse Projects » Eclipse Platform » EditingSupport. Events priority.
Re: EditingSupport. Events priority. [message #327818 is a reply to message #327816] |
Sun, 04 May 2008 14:12 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Richard Desbiolles![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=richard.desbiolles%40wanadoo.fr) Messages: 23 Registered: July 2009 |
Junior Member |
Tom Schindl a écrit :
> Yes this is correct because EditingSupport is listening to MouseEvents
> which come before a SelectionEvent.
> You could attach your listener to the ColumnViewerEditor which informs
> interested parties about the starting/ending of an editor.
> If you only want to disable the cell you can always return false from
> EditingSupport#canEdit.
> Tom
> Richard Desbiolles schrieb:
>> Hi All,
>> I'm concerned with use of editors in TableViewers.
>> I'm encountering a problem :
>> Before starting the edition of a cell, I'd want to make actions on
>> the whole row of this cell (typically, conditionnaly disable the cell
>> and so forbid the edition).
>> Unfortunately, it seems that the EditingSupport.getValue method is
>> reached before the org.eclipse.jface.viewers.SelectionChangedEvent event.
>> Is it right and is there a way to solve this point ?
>> Thanks in advance,
>> Regards,
>> Richard
Thanks Tom,
A so quick response on sunday, thank you very much Tom.
I investigate an I'll come back to you for feedback.
Richard
Re: EditingSupport. Events priority. [message #327968 is a reply to message #327818] |
Sat, 10 May 2008 06:59 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Junior Member |
>> Tom
>>> Hi All,
>>> event.
>>> Thanks in advance,
>>> Regards,
>>> Richard
> Thanks Tom,
> Best regards,
> Richard
Hi Tom,
My goal is to have different behaviours (enable / disable, default
value, ...) for columns depending the current row and values of one or
more 'master columns'. So my first idea was to catch the 'change of row
event' to refreh the state of columns. Like I said, it doesn't work but,
fortunaly, It's very easy to do with the use of EditingSupport.canEdit
(), and it works fine.
Thanks a lot for your help.
I should also want to programmatically create a new row in my table when
the user tries (with TAB) to leave lhe last enabled column in the
last row. Is it possible to catch this event ?
(My activation strategy is :
boolean bStartEdition =
event.eventType == ColumnViewerEditorActivationEvent.TRAVERSAL ||
event.eventType == MOUSE_CLICK_SELECTION
|| ( event.eventType == ColumnViewerEditorActivationEvent.KEY_PRESSED
&& ( event.keyCode == SWT.CR || event.character == ' ' ))
|| event.eventType == ColumnViewerEditorActivationEvent.PROGRAMMATIC;
Richard
Re: EditingSupport. Events priority. [message #328028 is a reply to message #327968] |
Mon, 12 May 2008 19:05 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Thomas Schindl![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=tom.schindl%40bestsolution.at) Messages: 6651 Registered: July 2009 |
>>> MouseEvents which come before a SelectionEvent.
>>> informs interested parties about the starting/ending of an editor.
>>> Tom
>>>> Hi All,
>>>> cell and so forbid the edition).
>>>> event.
>>>> Thanks in advance,
>>>> Regards,
>>>> Richard
>> Thanks Tom,
>> Best regards,
>> Richard
> Hi Tom,
> the user tries (with TAB) to leave lhe last enabled column in the last
> event.eventType ==
> ColumnViewerEditorActivationEvent.TRAVERSAL || event.eventType ==
> Best regards,
> Richard
I've just answered a similar question on the nebula-newsgroup. There's
no JFace API for this at the moment you'll have to create your own
ColumnViewerEditor-Subclass and overload processTraverseEvent. For
SWT-Table this is not really simple need a lot of reflection to make it
work but it's certainly possible.
This could certainly be a thing we add in 3.5 though.
Tom
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: EditingSupport. Events priority. [message #328071 is a reply to message #328028] |
Tue, 13 May 2008 16:46 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Junior Member |
>>>> from EditingSupport#canEdit.
>>>> Tom
>>>>> Hi All,
>>>>> on the whole row of this cell (typically, conditionnaly disable the
>>>>> event.
>>>>> Thanks in advance,
>>>>> Regards,
>>>>> Richard
>>> Thanks Tom,
>>> Best regards,
>>> Richard
>> Hi Tom,
>> row event' to refreh the state of columns. Like I said, it doesn't
>> work but, fortunaly, It's very easy to do with the use of
>> EditingSupport.canEdit (), and it works fine.
>> when the user tries (with TAB) to leave lhe last enabled column in
>> the last row. Is it possible to catch this event ?
>> event.eventType ==
>> Best regards,
>> Richard
> Tom
Thanks Tom,
I investigate and come back to you for feedback.
Richard
Current Time: Mon Jul 29 21:03:34 GMT 2024
Powered by FUDForum. Page generated in 0.03842 seconds
