Home » Eclipse Projects » Eclipse Platform » Shortcuts for run and debug OSGi framework partly removed since 3.3.2 - accidental?
Shortcuts for run and debug OSGi framework partly removed since 3.3.2 - accidental? [message #327812] Sat, 03 May 2008 10:47 Go to next message
Originally posted by: groups.pellaton.li
I diffed the keyboard shortcuts of 3.3.2 and 3.4.0.M7 and I found that
the shortcut
[ctrl]+[shift]+[d], [o] "debug osgi"
was removed. However, the shortcut
[ctrl]+[shift]+[x], [o] "run osgi"
is still around (plain Eclipse installation; new clean workspace).
For consistency, either the remaining shortcut should be removed or the
removed one should be added again.
Is this a regression issue that I shall report in bugzilla? And if so,
to which component shall I report it (equinox, jdt)?
Michael Pellaton
Re: Shortcuts for run and debug OSGi framework partly removed since 3.3.2 - accidental? [message #327832 is a reply to message #327812] Mon, 05 May 2008 08:51 Go to previous messageGo to next message
Yes, you can open a bug against Eclipse PDE UI at
https://bugs.eclipse.org/bugs/
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: Shortcuts for run and debug OSGi framework partly removed since 3.3.2 - accidental? [message #327850 is a reply to message #327812] Tue, 06 May 2008 01:39 Go to previous message
Bug submitted: https://bugs.eclipse.org/bugs/show_bug.cgi?id=230332
Previous Topic:Open WORD on IFileStore
Next Topic:Standalone Help
Current Time: Tue Apr 29 02:00:44 EDT 2025
Powered by FUDForum. Page generated in 0.07292 seconds
