ZipException being thrown at Plug-In startup. [message #327794] |
Thu, 01 May 2008 17:37 |
Originally posted by: marcio.debarros.gmail.com
Hi, I am runing Eclipse 3.3.1, and whenever I the plug-in I am
developing I am getting ZipException thrown several times on the log file.
All the other ZipException problems and information I search are related
to different methods for opening .jar files, or corrupted .jar files,
which seems not to be this case since the exception happens even before
any of my own classes are called.
Below the stack trace for the very first occurrence of the exception in
the log file:
!SESSION 2008-05-01 17:14:17.778
eclipse.buildId=M20071023-1652
java.version=1.5.0_11
Framework arguments: -product org.eclipse.sdk.ide
Command-line arguments: -product org.eclipse.sdk.ide -data C:\My
Runtimes/TestClient -dev file:C:/My
Workspaces/TestClient/.metadata/.plugins/org.eclipse.pde.cor e/TestClient/dev.properties
-console
!ENTRY org.eclipse.core.resources 2 10035 2008-05-01 17:14:19.529
!MESSAGE The workspace exited with unsaved changes in the previous
session; refreshing workspace to recover changes.
!ENTRY com.acme.testclient 4 0 2008-05-01 17:14:22.281
!MESSAGE
!STACK 0
java.util.zip.ZipException: error in opening zip file
at java.util.zip.ZipFile.open(Native Method)
at java.util.zip.ZipFile.<init>(Unknown Source)
org.eclipse.osgi.framework.util.SecureAction.getZipFile(Secu reAction.java:251)
org.eclipse.osgi.baseadaptor.bundlefile.ZipBundleFile.basicO pen(ZipBundleFile.java:79)
org.eclipse.osgi.baseadaptor.bundlefile.ZipBundleFile.getZip File(ZipBundleFile.java:92)
org.eclipse.osgi.baseadaptor.bundlefile.ZipBundleFile.checke dOpen(ZipBundleFile.java:65)
org.eclipse.osgi.baseadaptor.bundlefile.ZipBundleFile.getEnt ry(ZipBundleFile.java:237)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findCla ssImpl(ClasspathManager.java:452)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClassImpl(ClasspathManager.java:430)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:413)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:189)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:340)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:408)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:369)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:357)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Unknown Source)
at java.lang.Class.getConstructor0(Unknown Source)
at java.lang.Class.newInstance0(Unknown Source)
at java.lang.Class.newInstance(Unknown Source)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:136)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:970)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:260)
org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:400)
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:417)
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:289)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1269)
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:160)
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:788)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugi n.java:252)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.java:248)
org.eclipse.ui.internal.registry.ViewDescriptor.createView(V iewDescriptor.java:69)
org.eclipse.ui.internal.ViewReference.createPartHelper(ViewR eference.java:327)
at org.eclipse.ui.internal.ViewReference.createPart(ViewReferen ce.java:227)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:592)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:29 9)
at org.eclipse.ui.internal.ViewPane.setVisible(ViewPane.java:53 1)
org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:179)
org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(PresentablePartFolder.java:268)
org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(LeftToRightTabOrder.java:65)
org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.selectPart(TabbedStackPresentation.java:400)
org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:1256)
at org.eclipse.ui.internal.PartStack.createControl(PartStack.ja va:668)
at org.eclipse.ui.internal.PartStack.createControl(PartStack.ja va:576)
org.eclipse.ui.internal.PartSashContainer.createControl(Part SashContainer.java:564)
org.eclipse.ui.internal.PerspectiveHelper.activate(Perspecti veHelper.java:270)
at org.eclipse.ui.internal.Perspective.onActivate(Perspective.j ava:931)
org.eclipse.ui.internal.WorkbenchPage.onActivate(WorkbenchPa ge.java:2515)
org.eclipse.ui.internal.WorkbenchWindow$23.run(WorkbenchWind ow.java:2837)
org.eclipse.ui.internal.WorkbenchWindow.setActivePage(Workbe nchWindow.java:2818)
org.eclipse.ui.internal.WorkbenchWindow$17.runWithException( WorkbenchWindow.java:2135)
org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3659)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3296)
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:801)
org.eclipse.ui.internal.Workbench$25.runWithException(Workbe nch.java:1342)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2309)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
at org.eclipse.equinox.launcher.Main.main(Main.java:1148)
FUDForum. Page generated in 0.05080 seconds
