[Databinding] Use converter when binding to TableViewer [message #327788] |
Thu, 01 May 2008 19:00 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: tskaufma.gmail.com
I have a model which has java.util.Date objects and I've created a custom
converter for Date to String conversion.
I would like to use my converter with a TableViewer. I currently use the
ObservableListContentProvider and ObservableMapLabelProvider classes to fill
the TableViewer. Is there some easy way to attach the converter this setup?
If not, is there a per-column label provider for use with Databinding so I
only have to write a custom label provider for my Date columns?
Trevor Kaufman
Re: [Databinding] Use converter when binding to TableViewer [message #327798 is a reply to message #327791] |
Thu, 01 May 2008 22:26 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hello Tom,
ColumnLabelProvider is a per column, yes, but there is no
ObservableColumnLabelProvider that I can find.. and
ObservableMapLabelProvider doesn't implement ColumnLabelProvider.
If I switch to a per column system, I'd only want to write custom label
providers for my Date columns and use an Obversable label provider for the
other columns.
Hope that clarifies my issue,
Trevor Kaufman
"Tom Schindl" <tom.schindl@bestsolution.at> wrote in message
news:fvd7bt$eln$1@build.eclipse.org...
> Sure ColumnLabelProvider?
> Tom
> Trevor Kaufman schrieb:
>> Hello,
>> fill the TableViewer. Is there some easy way to attach the converter this
>> setup?
>> I only have to write a custom label provider for my Date columns?
>> Thanks,
>> Trevor Kaufman
> B e s t S o l u t i o n . at
> Tom Schindl JFace-Committer
FUDForum. Page generated in 0.04062 seconds
