extending java builder in eclipse? [message #327785] |
Thu, 01 May 2008 18:55 |
Originally posted by: automatic.javalobby.org
hi..
is there a way to tell tthe java builder that aside from compiling the current class i'm working on, he should copy that compiled class to somewhere (with the same package directory hirarchy).
Re: extending java builder in eclipse? [message #327786 is a reply to message #327785] |
Thu, 01 May 2008 19:00 |
Elhanan,
That's what setting an output folder in the project's
Properties...->Java Build Path->Source is for.
Elhanan Maayan wrote:
> hi..
Re: extending java builder in eclipse? [message #327802 is a reply to message #327799] |
Fri, 02 May 2008 11:05 |
Elhanan,
I think you can write an Ant build.xml file that would be run each time
to do something fancier.
> i know about that, but i'm talking about a way to copy the complied classes to ANOTHER output folder
Re: extending java builder in eclipse? [message #327807 is a reply to message #327802] |
Fri, 02 May 2008 13:41 |
Ed Merks wrote:
> Elhanan,
For more details, see this page in the Eclipse Help contents:
Workbench User Guide > Getting Started > Ant & external tools tutorial
I would have sworn that there was a Bugzilla requesting support for
multiple (duplicate) output folders, but I can't find it. You might want
to enter a feature request against JDT.
Eric
FUDForum. Page generated in 0.04059 seconds
