Home » Eclipse Projects » Eclipse Platform » extending java builder in eclipse?
extending java builder in eclipse? [message #327785] Thu, 01 May 2008 14:55 Go to next message
Originally posted by: automatic.javalobby.org
hi..
is there a way to tell tthe java builder that aside from compiling the current class i'm working on, he should copy that compiled class to somewhere (with the same package directory hirarchy).
Re: extending java builder in eclipse? [message #327786 is a reply to message #327785] Thu, 01 May 2008 15:00 Go to previous messageGo to next message
Elhanan,
That's what setting an output folder in the project's
Properties...->Java Build Path->Source is for.
Elhanan Maayan wrote:
> hi..
Re: extending java builder in eclipse? [message #327799 is a reply to message #327786] Fri, 02 May 2008 04:56 Go to previous messageGo to next message
i know about that, but i'm talking about a way to copy the complied classes to ANOTHER output folder
Re: extending java builder in eclipse? [message #327802 is a reply to message #327799] Fri, 02 May 2008 07:05 Go to previous messageGo to next message
Elhanan,
I think you can write an Ant build.xml file that would be run each time
to do something fancier.
Re: extending java builder in eclipse? [message #327807 is a reply to message #327802] Fri, 02 May 2008 09:41 Go to previous message
Ed Merks wrote:
> Elhanan,
For more details, see this page in the Eclipse Help contents:
Workbench User Guide > Getting Started > Ant & external tools tutorial
I would have sworn that there was a Bugzilla requesting support for
multiple (duplicate) output folders, but I can't find it. You might want
to enter a feature request against JDT.
Eric
Previous Topic:Copy-on-write editing ?
Next Topic:[databinding] Globally convert all empty strings to null
Current Time: Fri Apr 18 19:49:50 EDT 2025
Powered by FUDForum. Page generated in 0.03278 seconds
