Home » Eclipse Projects » Eclipse Platform » Adding actions to a custom view
Adding actions to a custom view [message #327776] Thu, 01 May 2008 02:00 Go to next message
Until eclipse 3.2, for a custom view, the preffered way to add toolbar
buttons to it was programatically in the createPartControl() method
using instances of 'Action'. This way the plugin developer gets the
first shot at adding the toolbar buttons.
However since eclipse 3.3 has introduced the new 'handler' framework is
this still the preferred way of adding actions or is it better to add
them declaratively in the plugin.xml using the new 'handlers' extensions.
Prashant
Re: Adding actions to a custom view [message #327780 is a reply to message #327776] Thu, 01 May 2008 09:08 Go to previous message
preferred? Depends on what you are trying to do.
But for the most part, it's preferred to write view commands, provide
them with either a default view handler or instantiate the view handler
in your createPartControl(*), and then place them in your view menu or
toolbar using org.eclipse.ui.menus.
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Previous Topic:viewActions support of visibility element
Next Topic:compile plugins using commandline
Current Time: Wed Oct 15 00:24:38 EDT 2025
Powered by FUDForum. Page generated in 0.03940 seconds
