Home » Eclipse Projects » Eclipse Platform » Problem with builders not copying .xml files to bin directory
Problem with builders not copying .xml files to bin directory [message #327763] |
Wed, 30 April 2008 22:50 |
Originally posted by: david_whiteman.us.ibm.com
Has anyone noticed in M5 or M6 a problem where if you have an .xml file
in the src directory of a Java project, it does not get copied to the
bin directory by the java builder? It seems any other file does get
copied except .xml files. I tried files named "foo", "foo.java",
"foo.xsd", "foo.xma", and "foo.xml", and the only one that was not
transferred to "bin" was foo.xml. Is this a known bug? If not, where
should I report it?
I am using the Eclipse IDE for Java Developers, Ganymede M6 build, on
Windows.
Thanks in advance,
David
Re: Problem with builders not copying .xml files to bin directory [message #327770 is a reply to message #327763] |
Wed, 30 April 2008 23:12 |
> should I report it?
There is a preference for controlling what files NOT to copy to the
output directory during a build - maybe XML files are included there
somehow. You can check the Preference dialog - enter "filtered" (without
quotes) into the search field at the top of the dialog.
Report back if you find *.xml or something similar there, or not.
Eric
Re: Problem with builders not copying .xml files to bin directory [message #327792 is a reply to message #327770] |
Thu, 01 May 2008 20:24 |
>> file in the src directory of a Java project, it does not get copied
>> to the bin directory by the java builder? It seems any other file
>> does get copied except .xml files. I tried files named "foo",
>> "foo.java", "foo.xsd", "foo.xma", and "foo.xml", and the only one that
>> was not transferred to "bin" was foo.xml. Is this a known bug? If
>> not, where should I report it?
> Eric
That's exactly what it was. Thanks, Eric! I wasn't aware of that
change. Seems to be a pretty arbitrary list of file types that are
excluded. We have .xml files that are test resources in a JUnit
project, and they are accessed using the class loader, so that's why we
need them copied to the bin directory. Fortunately, you can configure
this preference on a per-project basis.
David
Re: Problem with builders not copying .xml files to bin directory [message #327808 is a reply to message #327792] |
Fri, 02 May 2008 13:54 |
>>> that was not transferred to "bin" was foo.xml. Is this a known bug?
>>> If not, where should I report it?
>> (without quotes) into the search field at the top of the dialog.
>> Eric
It's not really arbitrary - I believe that plugins contribute to that
list files that they "know" should not generally be included in the
build output. For example, EMF adds *.ecore to the list so your model
source does not get copied.
Anyway, it is strange that XML files ended up in your list. I would
definitely consider that a bug, but the trick is finding out how it got
there. Is there any chance you accidentally did it or someone else did
it per-project and checked in their .settings files? If you're pretty
sure that's not the case, you should look at the plugins you have
installed and try to figure out which one might have done it.
I checked both my 3.3.x and my 3.4M6 installations and XML was not
included in the list (I have quite a few plugins installed, including
EMF, WTP, DTP, and much more), so it must be something else you have
installed.
Eric
Re: Problem with builders not copying .xml files to bin directory [message #332201 is a reply to message #327808] |
Thu, 09 October 2008 23:12 |
Brett Randall Messages: 17 Registered: July 2009 |
Junior Member |
>>>> bug? If not, where should I report it?
>>> Eric
>> we need them copied to the bin directory. Fortunately, you can
>> configure this preference on a per-project basis.
> installed.
> Eric
This exact problem has just happened to me, I suspect at the time that I
picked up the 3.4.1 M20080911-1700 and other updates, but I too have a
bunch of additional plugins on-top of the base Ganymede, so I don't know
which one to point the finger at.
Thanks for posting this and the solution.
Brett
Re: Problem with builders not copying .xml files to bin directory [message #332205 is a reply to message #332201] |
Fri, 10 October 2008 13:27 |
Note: copying this to the JDT newsgroup since this is a JDT feature
we're talking about.
JDT gurus: can you help us track down who is putting *.xml in the
"Filtered Resources" list for the JDT builder? I thought it would be an
extension point that we could look for, but I couldn't find any such
extension point. Looking at JavaBuildPreferencePage I tried to decipher
how that preference gets pre-populated by pulgins but I got lost.
Any hints?
Eric
>>>>> copied to the bin directory by the java builder? It seems any
>>>>> other file does get copied except .xml files. I tried files named
>>>>> "foo", "foo.java", "foo.xsd", "foo.xma", and "foo.xml", and the
>>>>> only one that was not transferred to "bin" was foo.xml. Is this a
>>>>> known bug? If not, where should I report it?
>>>> Eric
>> got there. Is there any chance you accidentally did it or someone else
>> did it per-project and checked in their .settings files? If you're
>> pretty sure that's not the case, you should look at the plugins you
>> have installed and try to figure out which one might have done it.
>> installed.
>> Eric
> Brett
Re: Problem with builders not copying .xml files to bin directory [message #332209 is a reply to message #332205] |
Fri, 10 October 2008 15:30 |
Jerome Lanneluc Messages: 572 Registered: July 2009 |
It might be TPTP. See https://bugs.eclipse.org/bugs/show_bug.cgi?id=230050
Jerome
> Any hints?
> Eric
>>>>> there somehow. You can check the Preference dialog - enter
>>>>> "filtered" (without quotes) into the search field at the top of the
>>>>> dialog.
>>>>> Eric
>>> else did it per-project and checked in their .settings files? If
>>> you're pretty sure that's not the case, you should look at the
>>> plugins you have installed and try to figure out which one might have
>>> done it.
>>> installed.
>>> Eric
>> I picked up the 3.4.1 M20080911-1700 and other updates, but I too have
>> a bunch of additional plugins on-top of the base Ganymede, so I don't
>> know which one to point the finger at.
>> Brett
Re: Problem with builders not copying .xml files to bin directory [message #332243 is a reply to message #332205] |
Tue, 14 October 2008 10:29 |
Originally posted by: mauro.molinari.cardinis.com
Eureka, someone having this problem at last!!!!
A co-worker of mine periodically encounters this problem and has to
rebuild his workspace from scratch, because we couldn't understand what
was the source of the problem until now. I made a search in Bugzilla
three or four times without success! :-(
Mauro.
Current Time: Sun Jun 30 14:27:39 GMT 2024
Powered by FUDForum. Page generated in 0.03850 seconds
