Home » Eclipse Projects » Eclipse Platform » Where is "Manage Configuration" gone in 3.4M6
Where is "Manage Configuration" gone in 3.4M6 [message #327761] Wed, 30 April 2008 19:36 Go to next message
Originally posted by: pschoenb.gmx.de
I just updated to Eclipse 3.4M6 and I am missing the menu action "Help >
Software Updates > Manage Configuration". I can access the corresponding
dialog via a keyboard shortcut. But where is the menu entry gone?
Patrick
Re: Where is "Manage Configuration" gone in 3.4M6 [message #327762 is a reply to message #327761] Wed, 30 April 2008 22:30 Go to previous messageGo to next message
Originally posted by: phillipus.nowhere.net
Patrick Schoenbach wrote:
Good question. It's the same in the latest Integration build.
Re: Where is "Manage Configuration" gone in 3.4M6 [message #327769 is a reply to message #327761] Wed, 30 April 2008 23:09 Go to previous messageGo to next message
That functionality has been replaced by the new p2 component, which is
intended to make updating and config management a lot better. See
http://wiki.eclipse.org/Equinox_p2
Hope this helps,
Eric
Re: Where is "Manage Configuration" gone in 3.4M6 [message #327774 is a reply to message #327761] Wed, 30 April 2008 23:30 Go to previous messageGo to next message
Paul Webster is currently offline Paul WebsterFriend
You know that Manage Configuration has been replaced by p2 and the new
software updates UI.
But you can get it back, go to Window>Preferences>General>Capabilities
and include "Classic Update"
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: Where is "Manage Configuration" gone in 3.4M6 [message #327789 is a reply to message #327762] Thu, 01 May 2008 19:05 Go to previous messageGo to next message
L. Mihalkovic is currently offline L. MihalkovicFriend
if you REAAAALLLY miss it.. make sure there is a problem with your
configuration, like the recent ECF version conflict between P2 and ...
(I was trying to install EMF + some other features - the install led to
a second version of the ECF library to get installed and crash P2) with
3.4M6a, and the old UI is going to come back. ;-)
Laurent Mihalkovic, co-author SWT/JFace in Action (www.manning.com/scarpino)
Re: Where is "Manage Configuration" gone in 3.4M6 [message #327790 is a reply to message #327762] Thu, 01 May 2008 19:05 Go to previous messageGo to next message
Re: Where is "Manage Configuration" gone in 3.4M6 [message #327824 is a reply to message #327769] Sun, 04 May 2008 21:11 Go to previous messageGo to next message
However, it seems that p2 does not (yet?) support to have several
extension locations. Is that correct?
Patrick
Re: Where is "Manage Configuration" gone in 3.4M6 [message #327831 is a reply to message #327824] Mon, 05 May 2008 12:31 Go to previous message
It supports roughly equivalent functionality. Did you read the Getting
Started page?
Eric
Previous Topic:Create programmatically User Library
Next Topic:Showing CTabItem in CTabFolder
Current Time: Sat Nov 09 05:06:54 GMT 2024
Powered by FUDForum. Page generated in 0.03441 seconds
