Home » Eclipse Projects » Eclipse Platform » Problem creating image from a file in a bundle
Problem creating image from a file in a bundle [message #327745] Wed, 30 April 2008 03:54 Go to next message
Hi there,
in my plugin I try to create an image using a file in a separate
directory of my plugin. I use the code below to do this. But when doing
so, the image has a width and height of -1. Does anyone have a hint to
resolve this problem?
Image img =
ImageDescriptor.createFromURL(FileLocator.find(Activator.get Default().getBundle(),
new Path("data/EclipseBannerPic.jpg"),
null)).createImage(parent.getDisplay());
Thanks in advance
Jan
Re: Problem creating image from a file in a bundle [message #327751 is a reply to message #327745] Wed, 30 April 2008 08:11 Go to previous messageGo to next message
Jan,
Have you inspected the URL that comes back? What does it look like?
Does openStream on the URL return a stream without throwing an
exception? The "data" folder is at the root of your plugin? Usually
people use an "icons" folder. You've specified it in your
build.properties so it's included in the final jarred plugin when you
export?
Jan Weidauer wrote:
> Hi there,
> Image img =
> Thanks in advance
> Jan
Re: Problem creating image from a file in a bundle [message #327772 is a reply to message #327745] Wed, 30 April 2008 19:23 Go to previous message
also, most of the logic is already written for you in
org.eclipse.ui.plugin.AbstractUIPlugin.imageDescriptorFromPl ugin(String,
String)
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Previous Topic:Popup Menu "Test" definition not working
Next Topic:[Databinding] ObservableListContentProvider for TreeViewers?
Current Time: Thu Oct 23 22:34:56 EDT 2025
Powered by FUDForum. Page generated in 0.04379 seconds
