Home » Archived » BIRT » To Jason : XML DataSet Problem
To Jason : XML DataSet Problem [message #327711] Tue, 29 January 2008 07:30
Originally posted by: suryakant.in.ibm.com
Hello
I need some help regarding XML datasource.
When we create XML datasource it asks fot XML URL. For creating a dataset
it asks for the option to either use the URL mentioned in the datasource
editor wizard or provide a new filepath or URL. when the second option is
used, it doesnt work and uses the same URL that was mentioned in the
datasource.
Is it possible to change the XML url for any new data set created from XML
datasource
surya
Previous Topic:To Jason : XML DataSet Problem
Next Topic:To Jason : XML DataSet Problem
Current Time: Thu Dec 26 17:59:24 GMT 2024
Powered by FUDForum. Page generated in 0.02927 seconds
