Home » Eclipse Projects » Eclipse Platform » May I customize Problems view for markers?
May I customize Problems view for markers? [message #327667] Mon, 28 April 2008 15:59 Go to next message
Originally posted by: reg.zhuce.163.com
Besides "errors", "warnings" and "infos",may I add other category with a
different icon?
Is there any extention point I can use?
Re: May I customize Problems view for markers? [message #327768 is a reply to message #327667] Wed, 30 April 2008 23:12 Go to previous messageGo to next message
Paul Webster is currently offline Paul WebsterFriend
You can add different types of markers in 3.3 ... check out the
org.eclipse.ui.ide.* extension points to do with markers
In 3.4 the markers view itself is extensible.
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: May I customize Problems view for markers? [message #327804 is a reply to message #327768] Fri, 02 May 2008 11:59 Go to previous messageGo to next message
It seems that org.eclipse.ui.ide.markerSupport helps.
But I really don't know how to, even though I have tried a lot.
It is still listed as error ,warning or info.
Can you give a example for more details?
Paul Webster 写道:
> PW
Re: May I customize Problems view for markers? [message #327805 is a reply to message #327804] Fri, 02 May 2008 12:15 Go to previous messageGo to next message
I would start with
http://www.eclipse.org/articles/Article-Mark%20My%20Words/ma rk-my-words.html
and the information in the Help>Help Contents>Platform Plug-in Developer
Guide
PW
Paul Webster
Re: May I customize Problems view for markers? [message #327811 is a reply to message #327805] Sat, 03 May 2008 07:36 Go to previous message
Paul Webster 写道:
> I would start with
> Guide
In fact,I have read this article and the help contents before I asked
here,and I have indeed realized a marker of my own.
But that can only have a self-defined marker style in the editor,not in
the problems view.
So my question is that I have not found any information telling how to
obtain a self-defined marker type in the problems view.
Maybe I can not understand the help contents completely.
Any tips?
> PW
Previous Topic:Is there something such as a Jface Viewer CheckStateProvider
Next Topic:Problems with new Update Mechanism of 3.4M6
Current Time: Thu Dec 26 18:01:43 GMT 2024
Powered by FUDForum. Page generated in 0.04028 seconds
