Home » Eclipse Projects » Eclipse Platform » Specifying *BOTH* Lable and Icon in Toolbar MenuContribution
Specifying *BOTH* Lable and Icon in Toolbar MenuContribution [message #327637] Sun, 27 April 2008 18:10 Go to next message
In Eclipse 3.3, I have noticed that any menuContribution to a toolbar that
contains a label and icon in the command only the icon gets displayed.
Is there anyway to display both a label and icon in a toolbar item menu
contribution?
Re: Specifying *BOTH* Lable and Icon in Toolbar MenuContribution [message #327639 is a reply to message #327637] Sun, 27 April 2008 18:15 Go to previous messageGo to next message
You need to specify the MODE_FORCE_TEXT mode on the IContributionItem,
or the ToolbarContributionManager will ignore the text by default. I
use this helper method so I can work with the Action API instead of
Contributions.
* Snippet to add an IAction instance to a toolbar or menu manager with
* MODE_FORCE_TEXT.
* @param manager the toolbar or menu manager
* @param action the action to add
public static void addItemWithText(IContributionManager manager,
IAction action, String groupId) {
ActionContributionItem contribution =
new ActionContributionItem(action);
contribution.setMode(ActionContributionItem.MODE_FORCE_TEXT) ;
if (groupId == null || "".equals(groupId)) {
manager.add(contribution);
else {
manager.appendToGroup(groupId, contribution);
Peter Centgraf
Re: Specifying *BOTH* Lable and Icon in Toolbar MenuContribution [message #327641 is a reply to message #327639] Sun, 27 April 2008 20:18 Go to previous messageGo to next message
Peter,
It is not clear how I would do this from the plugin.xml. I am trying to
define the maximum of my menu/toolbar contributions declaratively using the
new 3.3 menuContribution extensions.
Anyone have any luck with this?
"Peter Centgraf" <peter@centgraf.net> wrote in message
news:fv2ttv$2bi$1@build.eclipse.org...
> You need to specify the MODE_FORCE_TEXT mode on the IContributionItem, or
> the ToolbarContributionManager will ignore the text by default. I use
> Contributions.
> * MODE_FORCE_TEXT.
> else {
> Peter Centgraf
Re: Specifying *BOTH* Lable and Icon in Toolbar MenuContribution [message #327764 is a reply to message #327641] Wed, 30 April 2008 19:08 Go to previous message
Stuart Pond wrote:
> Peter,
That functionality is not available in actions or commands from the
plugin.xml until 3.4 (a new mode attribute was added to the extension
points like actionSets and menus).
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Previous Topic:Plugin.stop() called during disable or uninstalled?
Next Topic:getActivePage throws NullPointerException
Current Time: Mon Apr 28 03:14:38 EDT 2025
Powered by FUDForum. Page generated in 0.26619 seconds
