Home » Eclipse Projects » Eclipse Platform » [Databinding] Valuebinding: Model To Target Synchronisation
[Databinding] Valuebinding: Model To Target Synchronisation [message #327573] |
Fri, 25 April 2008 08:06 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: eclipse.news.yahoo.de
I'm starting some experiments with the eclipse data binding in RCP
applications.
In fact, I only have a simple Text widget to be synchronized with a double
in my domain model.
So that, the following code support should support such synchronization:
DataBindingContext context = new DataBindingContext();
context.bindValue(SWTObservables.observeText(txBox, SWT.Modify),
BeansObservables.observeValue(domainData, "amount"),
null, null);
The target to model synchronization works very well. Additionally, the
'amount' is represented in the Eclipse Property View as an editable value
(via a TextPropertyDescriptor). If I edit the 'amount' via the Property
View, I would expect that the corresponding txBox is updated (since the
data binding supports also a model to target sync).
However, the model to target sync doesn't work in that case.
Is there any idea why it doesn't works and how I can solve the problem?
Re: [Databinding] Valuebinding: Model To Target Synchronisation [message #327577 is a reply to message #327573] |
Fri, 25 April 2008 10:10 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Thomas Schindl![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=tom.schindl%40bestsolution.at) Messages: 6651 Registered: July 2009 |
Does you model fire PropertyChangeEvents and does it provide a
add/removePropertyChangeListener-method.
The bad thing in 3.3 is that you won't see an error in this case as far
as I remember but the symptoms are exactly like you describe them.
Tom
H.Mueller schrieb:
> applications.
> double in my domain model.
> null, null);
> value (via a TextPropertyDescriptor). If I edit the 'amount' via the
> Property View, I would expect that the corresponding txBox is updated
> (since the data binding supports also a model to target sync).
> Thanks
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: [Databinding] Valuebinding: Model To Target Synchronisation [message #327578 is a reply to message #327577] |
Fri, 25 April 2008 10:17 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Yes, the model provides PropertyChangeEvents including their corresponding add and remove methods.
And in the set method of the 'amount' value a property change event is fired.
Hermann
Tom Schindl schrieb:
> Tom
> H.Mueller schrieb:
>> applications.
>> null, null);
>> Thanks
Re: [Databinding] Valuebinding: Model To Target Synchronisation [message #327581 is a reply to message #327578] |
Fri, 25 April 2008 10:38 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Then I'm afraid you'll need to provide a snippet for us to run and see
what's going on. Do you run youre application with -consoleLog to see if
there are any exceptions?
Tom
> fired.
> Hermann
>> far as I remember but the symptoms are exactly like you describe them.
>> Tom
>> H.Mueller schrieb:
>>> Hi,
>>> applications.
>>> null, null);
>>> the 'amount' is represented in the Eclipse Property View as an
>>> editable value (via a TextPropertyDescriptor). If I edit the 'amount'
>>> via the Property View, I would expect that the corresponding txBox is
>>> updated (since the data binding supports also a model to target sync).
>>> Thanks
Current Time: Tue Jul 16 16:45:16 GMT 2024
Powered by FUDForum. Page generated in 0.04124 seconds
