Home » Eclipse Projects » Eclipse Platform » Implementing an IPerspectiveFactory...
Implementing an IPerspectiveFactory... [message #327550] Thu, 24 April 2008 09:14 Go to next message
Originally posted by: j4r0d.hotmail.com
I have got a problem when I try to create my own perspective.
If fact, I've been able to create my perspective but the problem is that my
plugin requires the Run.. and Debug menu and when I run my plugin there is
no way I can get those menus. I've tried various things like :
layout.addActionSet("org.eclipse.jdt.ui.JavaActionSet");
I have also tried adding a perspectiveExtensions in my plugin.xml. In this
case, in the resource navigator view I am able to see the wanted menus, but
as soon as I click on my editor (or another view), I lose those menus.
Do you guys know about what I need to do in order to have those menus (Run..
etc) in each view of my perspective?
Thanks in advance,
J.
Re: Implementing an IPerspectiveFactory... [message #327560 is a reply to message #327550] Thu, 24 April 2008 12:56 Go to previous messageGo to next message
Hi Jarod,
layout.addActionSet(IDebugUIConstants.LAUNCH_ACTION_SET); is what you
probably need
Dimitrios
Jarod Mills wrote:
> Hello,
> Thanks in advance,
Re: Implementing an IPerspectiveFactory... [message #327572 is a reply to message #327560] Fri, 25 April 2008 01:47 Go to previous messageGo to next message
In case you prefer doing it in plugin.xml than programming, you can add
a perspective extension like this:
<extension
point="org.eclipse.ui.perspectiveExtensions">
<perspectiveExtension
targetID="your perspective id">
<actionSet
id="org.eclipse.debug.ui.launchActionSet">
</actionSet>
</perspectiveExtension>
</extension>
- Prakash
Eclipse Tips: http://blog.cypal-solutions.com
Eclipse Search: http://www.cypal.in/eclipsesearch
Dimitrios Kolovos wrote:
> Hi Jarod,
> probably need
> Cheers,
> Dimitrios
> Jarod Mills wrote:
>> Hello,
>> that my plugin requires the Run.. and Debug menu and when I run my
>> plugin there is no way I can get those menus. I've tried various
>> things like :
>> this case, in the resource navigator view I am able to see the wanted
>> menus, but as soon as I click on my editor (or another view), I lose
>> those menus.
>> (Run.. etc) in each view of my perspective?
>> Thanks in advance,
Re: Implementing an IPerspectiveFactory... [message #327574 is a reply to message #327572] Fri, 25 April 2008 04:09 Go to previous messageGo to next message
Thanks for your help Dimitrios and Prakash :-)
J.
"Prakash G.R." <grprakash@gmail.com> wrote in message
news:furra8$vtq$1@build.eclipse.org...
> In case you prefer doing it in plugin.xml than programming, you can add a
> <extension
> <actionSet
> </actionSet>
> </extension>
> - Prakash
>> Hi Jarod,
>> probably need
>> Cheers,
>> Dimitrios
>> Jarod Mills wrote:
>>> Hello,
>>> my plugin requires the Run.. and Debug menu and when I run my plugin
>>> there is no way I can get those menus. I've tried various things like :
>>> those menus.
>>> Thanks in advance,
Re: Implementing an IPerspectiveFactory... [message #327576 is a reply to message #327550] Fri, 25 April 2008 05:42 Go to previous message
Hello again,
I have another small question regarding placeholder.
I've put this into my IPerspectiveFactory implementation :
bottomLeft.addPlaceholder(IConsoleConstants.ID_CONSOLE_VIEW) ;
When I open a console view, it opens in the placeholder. So it works fine.
However, when I close the console view the placeholder is still visible
(empty grey window) and there is no way I can close it!
The weird thing is that if I simply call for the addView method rather than
the addPlaceholder; when I am closing the console view, there is nothing
remaining.
How can I have the same behavior for the placeholder? Is this possible? Am I
doing something wrong?
J.
"Jarod Mills" <j4r0d@hotmail.com> wrote in message
news:fuq1bn$o22$1@build.eclipse.org...
> Hello,
> my plugin requires the Run.. and Debug menu and when I run my plugin there
> but as soon as I click on my editor (or another view), I lose those menus.
> Thanks in advance,
> J.
Previous Topic:anonymous cvs checkout
Next Topic:[Databinding] Valuebinding: Model To Target Synchronisation
Current Time: Fri Oct 31 16:28:40 EDT 2025
Powered by FUDForum. Page generated in 0.03667 seconds
