Home » Eclipse Projects » Eclipse Platform » CoreException when using property tester to hide action in popup menu
CoreException when using property tester to hide action in popup menu [message #327415] Fri, 18 April 2008 02:53 Go to next message
In my plugin.xml, i used objectContribution/enablement/test to make an
action of a popup menu visible if the selection is a Project and contains
certain file.
Created a property tester that checks if it contains the file.
plugin.xml
<extension point="org...popupMenus">
<objectContribution
adaptable="true"
objectClass="org.eclipse.core.resources.IProject"
<enablement>
<test property="x.y.z.hasFile" />
</enablement>
<action...
</extension>
<extension point="org...propertyTesters" >
<propertyTester id="x.y.z.MyTester"
type="org.eclipse.core.resources.IProject"
namespace="x.y.z"
properties="hasFile"
class="x.y.z.MyTester"
</propertyTester>
</extension>
MyTester.java
public boolean test(...) {
// do something and return boolean
However, I got CoreException "No property tester contributes a property
hasFile to type class org.eclipse.core.internal.resources.Project"
What's wrong with what I did?
My guess is in my plugin.xml, I defined IProject type. But as you can see
in the exception "...No property tester... to type class org...Project"
I've been searching a lot of related threads here but none seems to be the
same as what I have encountered..
Any help will be appreciated, thanks.
Re: CoreException when using property tester to hide action in popup menu [message #327429 is a reply to message #327415] Fri, 18 April 2008 10:32 Go to previous messageGo to next message
Leo E wrote:
> plugin.xml
> <objectContribution
> adaptable="true"
> <enablement>
> </enablement>
> <action...
> </extension>
> namespace="x.y.z"
> </propertyTester>
> </extension>
Your XML certainly looks correct. Are there any errors/warnings
associated with the type="..." line in your plugin.xml from the PDE
builder? Does your plugin depend on org.eclipse.core.expressions
(probably) and org.eclipse.core.resources?
When you run, are there any other exceptions in your log?
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: CoreException when using property tester to hide action in popup menu [message #327455 is a reply to message #327429] Mon, 21 April 2008 03:21 Go to previous messageGo to next message
Hi Paul,
Regarding your questions,
1. Are there any warnings/errors associated with the type="..."
- Nope,
2. Yes it depends on core.expressions and core.resources
3. When I right-clicked a project in the Package Explorer, the exception
occurs and is displayed in the Error log. No other exception besides this
happens performing the action.
org.eclipse.core.runtime.CoreException: No property tester contributes a
property hasPOM to type class org.eclipse.core.internal.resources.Project
org.eclipse.core.internal.expressions.TypeExtensionManager.g etProperty(TypeExtensionManager.java:109)
org.eclipse.core.internal.expressions.TestExpression.evaluat e(TestExpression.java:95)
at ....
Thanks for taking a look at this problem
Re: CoreException when using property tester to hide action in popup menu [message #327461 is a reply to message #327455] Mon, 21 April 2008 12:59 Go to previous messageGo to next message
> this happens performing the action.
> at
> at
> at ....
it says hasPOM ... is that just different from your example (hasFile)?
PW
Paul Webster
Re: CoreException when using property tester to hide action in popup menu [message #327480 is a reply to message #327461] Mon, 21 April 2008 22:06 Go to previous message
Yeah. Sorry about that. The actual code I use is hasPOM. I just used the
hasFile for posting purpose.
Previous Topic:hyperlink detector in the text framework
Next Topic:Update Manager through proxy server failed
Current Time: Tue Jul 01 09:17:35 EDT 2025
Powered by FUDForum. Page generated in 0.04094 seconds
