Home » Eclipse Projects » Eclipse Platform » File search & replace programatically?
File search & replace programatically? [message #327404] Thu, 17 April 2008 16:48 Go to next message
Is there any simple API for doing a search & replace within a single
file? I'm looking at the IFile interface and it looks like I could use
some combination of getContents() and setContents() but there would
still be a lot of coding to bridge the gap.
Is there a cleaner/simpler way?
Thanks in advance,
Eric
Re: File search & replace programatically? [message #327417 is a reply to message #327404] Fri, 18 April 2008 07:14 Go to previous message
Dani Megert is currently offline Dani MegertFriend
Use file buffers to get the document (this handles all the encoding woos
for you) and then use org.eclipse.jface.text.FindReplaceDocumentAdapter
which also supports regex.
Dani
> Thanks in advance,
> Eric
Previous Topic:Re: Can I customize when the plug-in be loaded?
Next Topic:Getting the default modifier key for hyperlinks from the preference store
Current Time: Wed Feb 05 19:00:30 GMT 2025
Powered by FUDForum. Page generated in 0.03029 seconds
