Home » Eclipse Projects » Eclipse Platform » Ant compile is slow with java 1.6.0_6
Ant compile is slow with java 1.6.0_6 [message #327357] Wed, 16 April 2008 07:12 Go to next message
I'm using Eclipse 3.3.2 with java 1.6.0_6. Suddenly a trivial ANT
compile takes 14 seconds, when before it took 1 second.
I can change my Eclipse JRE from U6 to U5 to U4, and the only JRE that
causes a problem is U6. Basically, an ANT compile takes 1 second in U4 and
U5, and 14 seconds in U6.
Anyone know what is causing this?
Re: Ant compile is slow with java 1.6.0_6 [message #327362 is a reply to message #327357] Wed, 16 April 2008 11:05 Go to previous messageGo to next message
"Denis Molony" <denis@bytezone.com> wrote in message
news:42f2d497439b4f57feff39038f4fc717$1@www.eclipse.org...
Sounds like U6 is causing this. (<slap> sorry, I deserved that...)
But seriously, it sounds like you've found a problem with U6, and the
question is how best to track it down and find a way to report it to Sun,
and in the meanwhile probably stick with U5.
Does the problem happen when you launch your Ant build from the command
line?
Can you isolate a particular file, package, line of code, etc. that makes
the problem happen?
I don't remember what the differences between U5 and U6 were supposed to be,
but ISTR they were security-related? I might be confused on that.
Re: Ant compile is slow with java 1.6.0_6 [message #327381 is a reply to message #327362] Wed, 16 April 2008 18:53 Go to previous messageGo to next message
To be honest, I'm not so sure. The compile does work, and it works just as
fast as usual when ANT isn't involved (i.e. just Eclipse). It feels as
though the ANT compile is having to search for the U6 compiler, and
eventually finds it and everything finally proceeds.
I can't find anywhere in Eclipse (say, the ANT preferences) to tell it
where the compiler is, I assume it just uses the 'current' JRE. And as I
said, that works fine for U4 and U5.
Re: Ant compile is slow with java 1.6.0_6 [message #327383 is a reply to message #327381] Wed, 16 April 2008 22:37 Go to previous messageGo to next message
I tried it on another machine, with no problems at all. So I went back to
the first machine to see what differences there might be, and as soon as
the machine booted, it worked properly.
I hate computers.
Sorry everyone.
Re: Ant compile is slow with java 1.6.0_6 [message #327402 is a reply to message #327383] Thu, 17 April 2008 12:27 Go to previous message
news:221aed63e0d6c52c649d48db27ba4522$1@www.eclipse.org...
> I hate computers.
Amen to that.
Previous Topic:Update manager to a site that requires basic authentication
Next Topic:multi-threading an IncrementalProjectBuilder??
Current Time: Sat Nov 08 23:38:36 EST 2025
Powered by FUDForum. Page generated in 0.03929 seconds
