PopupMenu objectContribution [message #327353] |
Wed, 16 April 2008 09:40 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: jefftymc.yahoo.com
I currently have a popupMenu in an objectContribution for
IResource. The plugin.xml is:
<?eclipse version="3.2"?>
<plugin>
<extension point="org.eclipse.ui.popupMenus">
<objectContribution
adaptable="true"
id="test.ResourceMapperContributions"
objectClass="org.eclipse.core.resources.mapping.ResourceMapping ">
<action
class="com.test.TestAction"
enablesFor="+"
id="test.action"
label="test">
</action>
</objectContribution>
</extension>
</plugin>
While right clicking on file, folder or project in the Package
Explorer, the action will display in the popupMenu. But it disappears
when I click on a file in "Synchronize" viewer of "Team Synchronizing"
perspective.
When created the plug-in project I choosed "Eclipse 3.4" in the
field of "Target Platform". Does it matter?
Would you please help about this?
Thanks in advance.
Re: PopupMenu objectContribution [message #327385 is a reply to message #327353] |
Thu, 17 April 2008 07:32 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
I modified the contribution like this:
<viewerContribution
id="com.test"
targetID="org.eclipse.team.ccvs.ui.RepositoriesView">
<action
definitionId="org.eclipse.ui.edit.paste1"
enablesFor="*"
menubarPath="miscGroup"
label="testLabel">
</action>
</viewerContribution>
TestAction extends ActionDelegate and implements IViewActionDelegate,
the action display in "CVS Repositories" (the id is
"org.eclipse.team.ccvs.ui.RepositoriesView") View.
So I think if I change the targetID to "Synchronize" View's ---
"org.eclipse.team.sync.views.SynchronizeView" the action will display in
the context menu of Synchronize View.
But it didn't. What's wrong with that?
Thanks a lot!
jeffty wrote:
> I currently have a popupMenu in an objectContribution for IResource.
> The plugin.xml is:
> <plugin>
> <objectContribution
> adaptable="true"
> <action
> enablesFor="+"
> id="test.action"
> label="test">
> </action>
> </extension>
> </plugin>
> perspective.
> Thanks in advance.
Re: PopupMenu objectContribution [message #327411 is a reply to message #327396] |
Fri, 18 April 2008 00:58 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Then we cann't add a menuItem to this View manually?
Paul Webster wrote:
>> IViewActionDelegate, the action display in "CVS Repositories" (the id
>> is "org.eclipse.team.ccvs.ui.RepositoriesView") View.
>> in the context menu of Synchronize View.
> The Sync view doesn't register a context menu with the system (at least
> it doesn't look like it does, from ALT+SHIFT+F1) so there's nothing to
> add to.
> PW
Re: PopupMenu objectContribution [message #327430 is a reply to message #327428] |
Fri, 18 April 2008 14:59 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Thanks Paul, I won't waste time on the popupmenu then. :)
Paul Webster 写道:
> Not to the popup menu, only to the view dropdown menu.
> PW
FUDForum. Page generated in 0.04816 seconds
